Code:
#include <16f874a.h> #use delay(clock = 20,000,000) #Fuses HS,NOWDT,NOPUT,NOBROWNOUT,NOLVP #Fuses LVP,CPD,PROTECT #include "lcd_driver.c" #include <ctype.h> //============================== int1 sensor1=0,sensor2=0,sensor3=0,sensor4=0; int timer0=0, duty_left = 0, duty_right = 0 ; int status_old = 0, status_new = 0; int16 a = 0,time=0; //------------------------------ void int_sys(); void detected_line(); // phat hien line int measure_distance(); // do khoan cach void control_motor_left(int duty); void control_motor_right(int duty); /* * */ #define BUT PIN_B0 // xac dinh #define SENSOR_1 PIN_C0 #define SENSOR_2 PIN_C1 #define SENSOR_3 PIN_C2 #define SENSOR_4 PIN_C3 #define PWM11 PIN_D4 #define PWM12 PIN_D5 #define PWM21 PIN_D6 #define PWM22 PIN_D7 #define TRIG PIN_B1 #define ECHO PIN_B2 //---------------------------------------------- #INT_TIMER0 void timer0_isr() { if(status_old != status_new) { timer0 = 0; status_old = status_new; } timer0++;time++; if(timer0 >= 10) timer0 = 0; // control motor left if((status_new == 2))// dao chieu ??ng co left { output_bit(PWM11,0); if(timer0 < duty_left) { output_bit(PWM12,1); } else output_bit(PWM12,0); } else { output_bit(PWM12,0); if(timer0 < duty_left) { output_bit(PWM11,1); } else output_bit(PWM11,0); } // control motor right if(status_new == 3)// dao chieu ??ng co right { output_bit(PWM22,0); if(timer0 < duty_right) output_bit(PWM21,1); else output_bit(PWM21,0); } else { output_bit(PWM21,0); if(timer0 < duty_right) output_bit(PWM22,1); else output_bit(PWM22,0); } if(status_new == 4)// dao chieu ??ng co right and left { output_bit(PWM11,0); if(timer0 < duty_left) { output_bit(PWM12,1); } else output_bit(PWM12,0); output_bit(PWM21,0); if(timer0 < duty_right) output_bit(PWM22,1); else output_bit(PWM22,0); } // measure distance } //============================================== void int_sys() { set_tris_B(0x01); set_tris_C(0x0f); set_tris_D(0x00); output_bit(PWM12,0); output_bit(PWM21,0); output_bit(PWM22,0); output_bit(PWM11,0); output_bit(PWM22,0); setup_timer_0 (T0_DIV_32|T0_INTERNAL); lcd_init(); } //============================================= void detected_line()// detect = 0, non detect = 1 { sensor1 = input(SENSOR_1); sensor2 = input(SENSOR_2); sensor3 = input(SENSOR_3); sensor4 = input(SENSOR_4); begin: if((sensor3 == 1)&&(sensor2 == 1)) { status_new = 1; duty_left = 3, duty_right = 3; } if((sensor3 == 0)&&(sensor2 == 1))// sensor3 deteted { status_new = 2; while((input(SENSOR_3)==0)&&(input(SENSOR_2)==1)) { duty_left = 4, duty_right = 4; } if((sensor3 == 1)&&(sensor2 == 1)) { goto begin; } } if((sensor2 == 0)&&(sensor3 == 1))//rc1 = detect { status_new = 3; while((input(SENSOR_3)==1)&&(input(SENSOR_2)==0)) { duty_left = 4, duty_right = 4; } if((sensor3 == 1)&&(sensor2 == 1)) { goto begin; } } if((sensor2 == 0)&&(sensor3 == 0)&&(sensor1 == 1)&&(sensor4 == 1))// stop { status_new = 4; while((input(SENSOR_3)==0)&&(input(SENSOR_2)==0)) { duty_left = 5, duty_right = 5; } if((sensor3 == 1)&&(sensor2 == 1)) { goto begin; } } if((sensor2 == 0)&&(sensor3 == 0)&&(sensor1 == 0)&&(sensor4 == 0))// stop { status_new = 5; duty_left = 0, duty_right = 0; } } //============================================ int measure_distance() { int16 echo_time=0, distance = 0; SET_TRIS_B(0X01); output_bit(TRIG,1); delay_us(15); output_bit(TRIG,0); SET_TRIS_B(0x05); while(input(ECHO)==0); while(input(ECHO)==1) { echo_time++; delay_us(1); } distance = echo_time/58;// conver time to cm return distance; } //=========================================== void main() { // unsigned int16 a =0; int_sys(); lcd_gotoxy(1,1); printf(lcd_putc," X "); lcd_gotoxy(1,0); printf(lcd_putc," Y "); delay_ms(3000); lcd_gotoxy(1,1); printf(lcd_putc," BAT DAU "); lcd_gotoxy(1,0); printf(lcd_putc,"KHOANG CACH: "); enable_interrupts(GLOBAL); enable_interrupts(INT_TIMER0); while(1) { while(input(BUT)==1) {delay_ms(10);} while(1) { detected_line(); if(time >= 1000) { disable_interrupts(INT_TIMER0); a = measure_distance(); lcd_gotoxy(13,0); printf(lcd_putc,"%03lu",a); time = 0; enable_interrupts(INT_TIMER0); } } } }
