Pic16f877a, demo limit
  • Pic16f877a, demo limit
    cho e hỏi bị lỗi này thì làm sao ạ, demo limit code thì đúng nhưng khi dịch dùng mikroc 8.0 lại báo lỗi đó e fai làm sao.
    đây là code của e. mọi người giúp e với
    /* KHAI BAO BIEN ************************************************** ************/
    unsigned short second, minute, hour, day, date, month, year;
    unsigned short minute_al, hour_al, type_al, count_al;
    unsigned short flag_time, delay10s_1 = 0, delay10s_2 = 0;
    unsigned short mode;
    char *day_txt;
    /* KHOI TAO ************************************************** *****************/
    void INIT_MAIN() {
    /* Khoi tao cong A -----------------------------------------------------------*/
    TRISA = 0xFF; // Dinh nghia cong A la Digital Input
    PORTA = 0x00;
    /* Khoi tao cong B -----------------------------------------------------------*/
    TRISB = 0xFF; // Dinh nghia cong B la Digital Input
    PORTB = 0x00;
    /* Khoi tao cong C -----------------------------------------------------------*/
    TRISC = 0x00;
    PORTC = 0x00;
    /* Khoi tao cong D -----------------------------------------------------------*/
    TRISD = 0x00; // Dinh nghia cong D la Digital Output
    PORTD = 0x00;
    /* Khoi tao cong E -----------------------------------------------------------*/
    ADCON1 = 0x0E; // Dinh nghia cong E la Digital + su dung A/D channel AN0
    TRISE = 0x00; // Dinh nghia cong E la Output
    PORTE = 0x00; // Xoa du lieu cu tren cong E
    /* Khoi tao LCD --------------------------------------------------------------*/
    Lcd_Config(&PORTD,4,7,6,3,2,1,0);
    Lcd_Init(&PORTD);
    Lcd_Cmd(Lcd_CLEAR);
    Lcd_Cmd(Lcd_CURSOR_OFF);
    /* Khoi tao truyen thong I2C -------------------------------------------------*/
    I2C_Init(100000);
    /* Khoi tao DS1307 -----------------------------------------------------------*/
    /* I2C_Start();
    I2C_Wr(0xD0);
    I2C_Wr(0x00); // Khoi tao cac gia tri ban dau cho cac thanh ghi thoi gian
    I2C_Wr(0x13); // chi lam 1 lan.
    I2C_Wr(0x03);
    I2C_Wr(0x02);
    I2C_Wr(0x03);
    I2C_Wr(0x05);
    I2C_Wr(0x03);
    I2C_Wr(0x03);
    I2C_Wr(0x90);
    I2C_Stop(); */
    /* Khoi tao ngat ngoai va Timer0 ---------------------------------------------*/
    INTCON = 0x90; // Mo ngat toan cuc, mo ngat ngoai, xoa co ngat ngoai, xoa co ngat Timer0
    OPTION_REG = 0x87; // Chon suon len cho ngat ngoai va Timer0, bo chia ti le 1:256 cho Timer0
    TMR0 = 0x00;
    /* Khoi tao cac bien luu trong EEPROM*/
    hour_al = Eeprom_Read(0x00);
    minute_al = Eeprom_Read(0x01);
    type_al = Eeprom_Read(0x02);
    /* CHUONG TRINH CON ************************************************** *********/
    /* Doc du lieu RTC tu DS1307 -------------------------------------------------*/
    void READ_RTC() {
    I2C_Start();
    I2C_Wr(0xD0);
    I2C_Wr(0x00);
    I2C_Repeated_Start();
    I2C_Wr(0xD1);
    second = I2C_Rd(1u);
    minute = I2C_Rd(1u);
    hour = I2C_Rd(1u);
    day = I2C_Rd(1u);
    date = I2C_Rd(1u);
    month = I2C_Rd(1u);
    year = I2C_Rd(1u);
    I2C_Stop();
    /* Xu ly du lieu Date RTC ----------------------------------------------------*/
    void TRANSFORM_RTC() {
    switch (day) {
    case 1: day_txt = "ERO"; break;
    case 2: day_txt = "T.2"; break;
    case 3: day_txt = "T.3"; break;
    case 4: day_txt = "T.4"; break;
    case 5: day_txt = "T.5"; break;
    case 6: day_txt = "T.6"; break;
    case 7: day_txt = "T.7"; break;
    case 8: day_txt = "C.N"; break;
    /* Xu ly du lieu RTC ---------------------------------------------------------*/
    void BCD(unsigned short x, unsigned short y,unsigned short var) {
    unsigned short var1, var2;
    var1 = (var >> 4) + 0x30;
    LCD_Chr(x,y,var1);
    var2 = (var & 0x0F) + 0x30;
    LCD_Chr_Cp(var2);
    /* Hien thi ra LCD -----------------------------------------------------------*/
    void LCD_DISPLAY() {
    LCD_Out(1,1,day_txt);
    BCD(1,7,date);
    LCD_Chr_Cp('/');
    BCD(1,10,month);
    LCD_Out_Cp("/20");
    BCD(1,15,year);
    if (type_al == 1) Lcd_Out(2, 1,"Chuong");
    else Lcd_Out(2, 1," ");
    BCD(2,9,hour);
    LCD_Chr_Cp(':');
    BCD(2,12,minute);
    LCD_Chr_Cp(':');
    BCD(2,15,second);
    /* Cap nhat thoi gian --------------------------------------------------------*/
    void UPDATE_TIME() {
    READ_RTC();
    TRANSFORM_RTC();
    LCD_DISPLAY();
    PORTE.F0 = ~PORTE.F0;
    /* Xu ly Du lieu Nhiet do tu LM335 -------------------------------------------*/
    void TEMPERATURE() {
    unsigned short temp1, temp2;
    char degree[5];
    temp1 = Adc_Read(0);
    temp2 = (temp1 - 558)/2;
    ByteToStr(temp2, degree);
    LCD_Out_CP(degree);
    LCD_Chr_Cp(223);
    LCD_Chr_Cp('C');
    /* XOA TIMER0 ----------------------------------------------------------------*/
    void CLEAR_TIMER0() {
    delay10s_1 = 0;
    delay10s_2 = 0;
    TMR0 = 0;
    /* Tinh so ngay Julius -------------------------------------------------------*/
    unsigned long jdFromDate(char dd, char mm, char yy) {
    char a, m;
    unsigned y;
    unsigned long jd;
    a = (14 - mm)/12;
    y = (2000 + yy) + 4800 - a;
    m = mm + 12*a - 3;
    jd = dd + (153*m + 2)/5 + 365*y + y/4 - y/100 + y/400 - 32045;
    if (jd < 2299161) jd = dd + (153*m + 2)/5 + 365*y + y/4 - 32083;
    return jd;
    /* Tinh ngay soc -------------------------------------------------------------*/
    char getNewMoonDay(unsigned long k) {
    double T, T2, T3, dr, Jd1, M, Mpr, F, C1, deltat, JdNew;
    T = k/1236.85;
    T2 = T * T;
    T3 = T2 * T;
    dr = 3.1415926/180;
    Jd1 = 2415020.75933 + 29.53058868*k + 0.0001178*T2 - 0.000000155*T3;
    Jd1 = Jd1 + 0.00033*sin((166.56 + 132.87*T - 0.009173*T2)*dr);
    M = 359.2242 + 29.10535608*k - 0.0000333*T2 - 0.00000347*T3;
    Mpr = 306.0253 + 385.81691806*k + 0.0107306*T2 + 0.00001236*T3;
    F = 21.2964 + 390.67050646*k - 0.0016528*T2 - 0.00000239*T3;
    C1=(0.1734 - 0.000393*T)*sin(M*dr) + 0.0021*sin(2*dr*M);
    C1 = C1 - 0.4068*sin(Mpr*dr) + 0.0161*sin(dr*2*Mpr);
    C1 = C1 - 0.0004*sin(dr*3*Mpr);
    C1 = C1 + 0.0104*sin(dr*2*F) - 0.0051*sin(dr*(M+Mpr));
    C1 = C1 - 0.0074*sin(dr*(M-Mpr)) + 0.0004*sin(dr*(2*F+M));
    C1 = C1 - 0.0004*sin(dr*(2*F-M)) - 0.0006*sin(dr*(2*F+Mpr));
    C1 = C1 + 0.0010*sin(dr*(2*F-Mpr)) + 0.0005*sin(dr*(2*Mpr+M));
    if (T < -11) deltat = 0.001 + 0.000839*T + 0.0002261*T2 - 0.00000845*T3 - 0.000000081*T*T3;
    else deltat= -0.000278 + 0.000265*T + 0.000262*T2;
    JdNew = Jd1 + C1 - deltat;
    return (JdNew + 0.5 + 7/24);
    /* Tinh toa do mat troi ------------------------------------------------------*/
    char getSunLongitude(unsigned long jdn) {
    double T, T2, dr, M, L0, DL, L;
    T = (jdn - 2451545.5 - 7/24) / 36525;
    T2 = T*T;
    dr = 3.1415926/180;
    M = 357.52910 + 35999.05030*T - 0.0001559*T2 - 0.00000048*T*T2;
    L0 = 280.46645 + 36000.76983*T + 0.0003032*T2;
    DL = (1.914600 - 0.004817*T - 0.000014*T2)*sin(dr*M);
    DL = DL + (0.019993 - 0.000101*T)*sin(dr*2*M) + 0.000290*sin(dr*3*M);
    L = L0 + DL;
    L = L*dr;
    L = L - 3.1415926*2*(L/(3.1415926*2));
    return (L / 3.1415926 * 6);
    /* Tim ngay bat dau thang 11 am lich -----------------------------------------*/
    char getLunarMonth11(char yy) {
    unsigned long k, off, nm, sunLong;
    off = jdFromDate(31, 12, (2000 + yy)) - 2415021;
    k = (off / 29.530588853);
    nm = getNewMoonDay(k);
    sunLong = getSunLongitude(nm);
    if (sunLong >= 9) nm = getNewMoonDay(k-1);
    return nm;
    /* Xac dinh thang nhuan ------------------------------------------------------*/
    char getLeapMonthOffset(unsigned long a11) {
    unsigned long k, last, arc, i;
    char tmp;
    k = (a11 - 2415021.076998695) / 29.530588853 + 0.5;
    last = 0;
    i = 1;
    tmp = getNewMoonDay(k+i);
    arc = getSunLongitude(tmp);
    do {
    last = arc;
    i++;
    while (arc != last && i < 14);
    return i-1;
    /* Tinh am lich --------------------------------------------------------------*/
    void AM_LICH() {
    unsigned long k, dayNumber, monthStart, a11, b11, lunarDay, lunarMonth, lunarYear, lunarLeap, diff, leapMonthDiff;
    char dd, mm, yy;
    unsigned short ld, lm, ly;
    dd = Bcd2Dec(date);
    mm = Bcd2Dec(month);
    yy = Bcd2Dec(year);
    dayNumber = jdFromDate(dd, mm, (2000+yy));
    k = (dayNumber - 2415021.076998695) / 29.530588853;
    monthStart = getNewMoonDay(k+1);
    if (monthStart > dayNumber) monthStart = getNewMoonDay(k);
    a11 = getLunarMonth11(2000+yy);
    b11 = a11;
    if (a11 >= monthStart) {
    lunarYear = 2000+yy;
    a11 = getLunarMonth11(2000+yy-1);
    else {
    lunarYear = 2000+yy+1;
    b11 = getLunarMonth11(2000+yy+1);
    lunarDay = dayNumber-monthStart+1;
    diff = (monthStart - a11)/29;
    lunarLeap = 0;
    lunarMonth = diff+11;
    if (b11 - a11 > 365) {
    leapMonthDiff = getLeapMonthOffset(a11);
    if (diff >= leapMonthDiff) {
    lunarMonth = diff + 10;
    if (diff == leapMonthDiff) lunarLeap = 1;
    if (lunarMonth > 12) lunarMonth = lunarMonth - 12;
    if (lunarMonth >= 11 && diff < 4) lunarYear -= 1;
    ld = Dec2Bcd (lunarDay);
    lm = Dec2Bcd (lunarMonth);
    BCD(1,10,ld);
    Lcd_Chr_Cp(':');
    BCD(1,13,lm);
    /* MODE BUTTON ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~*/
    /* Hien thi lich am ----------------------------------------------------------*/
    void MODE_1() {
    Lcd_Cmd(Lcd_CLEAR);
    Lcd_Out(1, 1, "AM LICH: SORRY");
    Lcd_Out(2, 1, "Next Update");
    // AM_LICH();
    mode = 1;
    Mode_1l:
    if (PORTB.F1 == 0) goto Mode_1l;
    /* Hien thi nhiet do moi truong ----------------------------------------------*/
    void MODE_2() {
    Lcd_Cmd(Lcd_CLEAR);
    Lcd_Out(1, 1, "NHIET DO:");
    TEMPERATURE();
    mode = 2;
    Mode_2l:
    if (PORTB.F1 == 0) goto Mode_2l;
    /* Hien thi cai dat chuong bao thuc ------------------------------------------*/
    void MODE_3() {
    Lcd_Cmd(Lcd_CLEAR);
    Lcd_Out(1, 1, "CHUONG BAO THUC");
    if (type_al == 0) Lcd_Out(2, 1,"Khong su dung");
    else {
    BCD(2,6,hour_al);
    LCD_Chr_Cp(':');
    BCD(2,9,minute_al);
    mode = 3;
    Mode_3l:
    if (PORTB.F1 == 0) goto Mode_3l;
    /* Hien thi thong tin ve Version thiet ke ------------------------------------*/
    void MODE_4() {
    Lcd_Cmd(Lcd_CLEAR);
    Lcd_Out(1, 3, "PIC VIET NAM");
    Lcd_Out(2, 1, "Version 1 - 2007");
    mode = 4;
    Mode_4l:
    if (PORTB.F1 == 0) goto Mode_4l;
    /* Xu ly phim bam Mode -------------------------------------------------------*/
    void MODE_BUTTON() {
    INTCON.INTE = 0; // OFF ngat ngoai
    PORTE = 0x02; // Bat LED 2
    MODE_1(); // Vao man hinh MODE 1
    INTCON.T0IE = 1; // Kich hoat Timer0 dem thoi gian tre man hinh 10s
    while (delay10s_2 < 5) { // Quet phim MODE
    Delay_ms(200); // Khu rung phim
    if (PORTB.F1 == 0) {
    mode++;
    CLEAR_TIMER0();
    switch (mode) {
    case 1 : MODE_1(); break;
    case 2 : MODE_2(); break;
    case 3 : MODE_3(); break;
    case 4 : MODE_4(); break;
    case 5 : goto OUT_MODE;
    OUT_MODE: // Ra khoi vong quet
    PORTE = 0x00; // OFF LED 2
    Lcd_Cmd(Lcd_CLEAR); // Xoa man hinh
    CLEAR_TIMER0(); // Xoa bo dem thoi gian tre man hinh
    /* SET BUTTON ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~*/
    /* Cap nhat du lieu cai dat --------------------------------------------------*/
    void SET_DATA() {
    I2C_Start();
    I2C_Wr(0xD0);
    I2C_Wr(0x00);
    I2C_Wr(second);
    I2C_Wr(minute);
    I2C_Wr(hour);
    I2C_Wr(day);
    I2C_Wr(date);
    I2C_Wr(month);
    I2C_Wr(year);
    I2C_Stop();
    EEprom_Write(0x00, hour_al);
    EEprom_Write(0x01, minute_al);
    EEprom_Write(0x02, type_al);
    /* Up data -------------------------------------------------------------------*/
    unsigned short UP_BUTTON(unsigned short var) {
    Delay_ms(200);
    CLEAR_TIMER0();
    var = Bcd2Dec(var);
    var++;
    var = Dec2Bcd(var);
    return var;
    /* Down data -----------------------------------------------------------------*/
    unsigned short DOWN_BUTTON(unsigned short var) {
    Delay_ms(200);
    CLEAR_TIMER0();
    var = Bcd2Dec(var);
    if (var == 0) var = 101;
    else var--;
    var = Dec2Bcd(var);
    return var;
    /* Nhap nhay underline cursor ------------------------------------------------*/
    void BLINK_CURSOR() {
    Lcd_Cmd(LCD_MOVE_CURSOR_LEFT);
    Lcd_Cmd(LCD_UNDERLINE_ON);
    /* Hieu chinh gio ------------------------------------------------------------*/
    void SET_HOUR() {
    Delay_ms(200);
    hour_lb:
    if (PORTB.F2 == 0) {
    CLEAR_TIMER0();
    goto hour_lb;
    while ((delay10s_2 < 5) && (PORTB.F2)) {
    Delay_ms(100);
    if (PORTB.F3 == 0) hour = UP_BUTTON(hour);
    if (Bcd2Dec(hour) == 24) hour = Dec2Bcd(0);
    if (PORTB.F4 == 0) hour = DOWN_BUTTON(hour);
    if (Bcd2Dec(hour) == 101 ) hour = Dec2Bcd(23);
    Lcd_Cmd(LCD_CURSOR_OFF);
    BCD(2,5,hour);
    BLINK_CURSOR();
    /* Hieu chinh phut -----------------------------------------------------------*/
    void SET_MINUTE() {
    Delay_ms(100);
    minute_lb:
    CLEAR_TIMER0();
    goto minute_lb;
    Delay_ms(200);
    if (PORTB.F3 == 0) minute = UP_BUTTON(minute);
    if (Bcd2Dec(minute) == 60) minute = Dec2Bcd(0);
    if (PORTB.F4 == 0) minute = DOWN_BUTTON(minute);
    if (Bcd2Dec(minute) == 101 ) minute = Dec2Bcd(59);
    BCD(2,8,minute);
    BLINK_CURSOR();
    /* Hieu chinh giay -----------------------------------------------------------*/
    void SET_SECOND() {
    Delay_ms(200);
    second_lb:
    CLEAR_TIMER0();
    goto second_lb;
    Delay_ms(100);
    if (PORTB.F3 == 0) second = UP_BUTTON(second);
    if (Bcd2Dec(second) == 60) second = Dec2Bcd(0);
    if (PORTB.F4 == 0) second = DOWN_BUTTON(second);
    if (Bcd2Dec(second) == 101 ) second = Dec2Bcd(59);
    BCD(2,11,second);
    BLINK_CURSOR();
    /* Cai dat thoi gian CLOCK ---------------------------------------------------*/
    void SET_1() {
    Lcd_Cmd(Lcd_CLEAR);
    LCD_Out(1,1,"Cai dat dong ho:");
    BCD(2,5,hour);
    LCD_Chr_Cp(':');
    BCD(2,8,minute);
    LCD_Chr_Cp(':');
    BCD(2,11,second);
    Delay_ms(200);
    Set_1l:
    if (PORTB.F2 == 0) goto Set_1l;
    SET_HOUR();
    SET_MINUTE();
    SET_SECOND();
    /* Cai dat Thu (DAY) ---------------------------------------------------------*/
    void SET_DAY() {
    Delay_ms(200);
    day_lb:
    CLEAR_TIMER0();
    goto day_lb;
    Delay_ms(100);
    if (PORTB.F3 == 0) day = UP_BUTTON(day);
    if (Bcd2Dec(day) == 9) day = Dec2Bcd(2);
    if (PORTB.F4 == 0) day = DOWN_BUTTON(day);
    if (Bcd2Dec(day) == 1) day = Dec2Bcd(8);
    TRANSFORM_RTC();
    LCD_Out(2,1,day_txt);
    BLINK_CURSOR();
    /* Cai dat ngay (DATE) -------------------------------------------------------*/
    void SET_DATE() {
    Delay_ms(200);
    date_lb:
    CLEAR_TIMER0();
    goto date_lb;
    Delay_ms(100);
    if (PORTB.F3 == 0) date = UP_BUTTON(date);
    if (Bcd2Dec(date) == 32) date = Dec2Bcd(1);
    if (PORTB.F4 == 0) date = DOWN_BUTTON(date);
    if (Bcd2Dec(date) == 0 ) date = Dec2Bcd(31);
    BCD(2,7,date);
    BLINK_CURSOR();
    /* Cai dat thang (MONTH) -----------------------------------------------------*/
    void SET_MONTH() {
    Delay_ms(100);
    month_lb:
    CLEAR_TIMER0();
    goto month_lb;
    Delay_ms(200);
    if (PORTB.F3 == 0) month = UP_BUTTON(month);
    if (Bcd2Dec(month) == 13) month = Dec2Bcd(1);
    if (PORTB.F4 == 0) month = DOWN_BUTTON(month);
    if (Bcd2Dec(month) == 0 ) month = Dec2Bcd(12);
    BCD(2,10,month);
    BLINK_CURSOR();
    /* Cai dat nam (YEAR) --------------------------------------------------------*/
    void SET_YEAR() {
    Delay_ms(200);
    year_lb:
    CLEAR_TIMER0();
    goto year_lb;
    Delay_ms(100);
    if (PORTB.F3 == 0) year = UP_BUTTON(year);
    if (Bcd2Dec(year) == 100) year = Dec2Bcd(0);
    if (PORTB.F4 == 0) year = DOWN_BUTTON(year);
    if (Bcd2Dec(year) == 101) year = Dec2Bcd(99);
    BCD(2,15,year);
    BLINK_CURSOR();
    /* Cai dat lich duong CALENDAR ---------------------------------------------- */
    void SET_2() {
    Lcd_Cmd(Lcd_CLEAR);
    LCD_Out(1,1,"Cai dat Lich:");
    BCD(2,7,date);
    LCD_Chr_Cp('/');
    BCD(2,10,month);
    LCD_Out_Cp("/20");
    BCD(2,15,year);
    Delay_ms(200);
    Set_2l:
    if (PORTB.F2 == 0) goto Set_2l;
    SET_DAY();
    SET_DATE();
    SET_MONTH();
    SET_YEAR();
    /* Cai dat gio bao thuc ------------------------------------------------------*/
    void TIME_ALARM() {
    Lcd_Cmd(Lcd_CLEAR);
    Lcd_Out(1,1,"Gio rung Chuong:");
    BCD(2,6,hour_al);
    Lcd_Out(2,8,":");
    BCD(2,9,minute_al);
    Delay_ms(200);
    Set_4l:
    if (PORTB.F2 == 0) goto Set_4l;
    Delay_ms(200);
    hour_al_lb:
    CLEAR_TIMER0();
    goto hour_al_lb;
    Delay_ms(200);
    Delay_ms(100);
    if (PORTB.F3 == 0) hour_al = UP_BUTTON(hour_al);
    if (Bcd2Dec(hour_al) == 24) hour_al = Dec2Bcd(0);
    if (PORTB.F4 == 0) hour_al = DOWN_BUTTON(hour_al);
    if (Bcd2Dec(hour_al) == 101 ) hour_al = Dec2Bcd(23);
    BCD(2,6,hour_al);
    BLINK_CURSOR();
    Delay_ms(200);
    minute_al_lb:
    CLEAR_TIMER0();
    goto minute_al_lb;
    Delay_ms(100);
    if (PORTB.F3 == 0) minute_al = UP_BUTTON(minute_al);
    if (Bcd2Dec(minute_al) == 60) minute_al = Dec2Bcd(0);
    if (PORTB.F4 == 0) minute_al = DOWN_BUTTON(minute_al);
    if (Bcd2Dec(minute_al) == 101 ) minute_al = Dec2Bcd(59);
    BCD(2,9,minute_al);
    BLINK_CURSOR();
    /* Cai dat bao thuc ----------------------------------------------------------*/
    void SET_3() {
    Lcd_Cmd(Lcd_CLEAR);
    Lcd_Out(1,1,"Cai dat Chuong:");
    Delay_ms(200);
    Set_3l:
    if (PORTB.F2 == 0) goto Set_3l;
    Delay_ms(200);
    Delay_ms(200);
    if ((PORTB.F3 == 0) || (PORTB.F4 == 0)) {
    if (type_al == 0) type_al = 1;
    else type_al =0;
    CLEAR_TIMER0();
    if (type_al == 0) Lcd_Out(2, 1,"Khong");
    if (type_al == 1) Lcd_Out(2, 1,"Co ");
    if (type_al == 1) TIME_ALARM();
    /* Xu ly nut bam Set ---------------------------------------------------------*/
    void SET_BUTTON() {
    PORTE = 0x04; // Bat LED 3
    INTCON.T0IE = 1; // Kich hoat Timer0 dem thoi gian tre man hinh 30s
    SET_1();
    SET_2();
    SET_3();
    PORTE = 0x00; // OFF LED 3
    Lcd_Cmd(Lcd_CURSOR_OFF); // OFF con tro man hinh
    SET_DATA(); // Cap nhat du lieu
    /* Nhay bao chuong -----------------------------------------------------------*/
    void BLINK_ALARM() {
    PORTE = 0x00;
    Lcd_Cmd(Lcd_CLEAR);
    Lcd_Out(1,1,"Bay gio la ");
    BCD(1,12,hour_al);
    Lcd_Out(1,14,":");
    BCD(1,15,minute_al);
    BCD(2,7,date);
    LCD_Chr_Cp('/');
    BCD(2,10,month);
    LCD_Out_Cp("/20");
    BCD(2,15,year);
    while ((count_al < 100) && (PORTB.F1 == 1) && (PORTB.F2 == 1) && (PORTB.F3 == 1) && (PORTB.F4 == 1)) {
    Delay_ms(200);
    PORTE = ~PORTE;
    count_al++;
    Lcd_Cmd(Lcd_CLEAR);
    PORTE = 0x00;
    /* Quet phim -----------------------------------------------------------------*/
    void CYCLE_BUTTON() {
    while(1) {
    INTCON.T0IE = 0;
    INTCON.INTE = 1;
    if (flag_time == 1) {
    UPDATE_TIME();
    flag_time = 0;
    Delay_ms(200);
    if (PORTB.F1 == 0) MODE_BUTTON();
    if (PORTB.F2 == 0) SET_BUTTON();
    if ((hour == hour_al) && (minute == minute_al) && (second == 0x00)) BLINK_ALARM();
    count_al = 0;
    /* XU LY NGAT ************************************************** ***************/
    void interrupt() {
    if (INTCON.T0IF) {
    delay10s_1++;
    if (delay10s_1 == 200) {
    delay10s_2++;
    delay10s_1 = 0;
    INTCON.T0IF = 0;
    if (INTCON.INTF) {
    flag_time = 1;
    INTCON.INTF = 0; // Xoa co ngat ngoai
    /* CHUONG TRINH CHINH ************************************************** *******/
    void MAIN() {
    INIT_MAIN();
    CYCLE_BUTTON();
    /* KET THUC ************************************************** *****************/
    phải sửa làm sao có ai giúp e được ko
      Một Chương trình cực kì bá đạo !
      Bạn nên tính ngày âm bằng tra bảng. Đơn giản và dễ sử dụng. Cần 3 mảng lưu các giá trị như sau:
      Ngày Âm lịch đầu tháng Dương lịch, Tháng ÂL, Số ngày trong tháng ÂL.VD tháng 1 năm 2013 cần
      lưu giá trị sau 21,11,30
      Bảng tra trong 5 năm , bạn có thể tạo thêm.
      PHP Code:
      const unsigned char AL_DauThang[100][12] = {
      //   1  2  3  4  5  6  7  8  9 10 11 12
      {20,21,20,21,22,23,24,25,26,27,28,29},//2013
      12123456889,10},//2014
      {11,13,11,13,13,15,16,17,19,19,20,20},//2015
      {22,23,23,24,25,26,27,291123},//2016
      4545678,10,11,12,13,14}//2017
      const
      unsigned char AL_Thang[100][12] = {
      {11,12123456789,10},//2013
      {121234567899,10},//2014
      {11,12123456789,10},//2015
      {11,1212345689,10,11},//2016
      {121234566789,10}//2017
      const
      unsigned char AL_SoNgay[100][12] = {
      {30,29,30,29,30,29,30,30,29,30,29,30},//2013
      {30,29,30,29,30,29,30,29,30,30,29,30},//2014
      {29,30,29,30,29,29,30,29,30,30,30,29},//2015
      {30,29,30,29,30,29,29,30,30,30,29,30},//2016
      {30,29,30,29,30,29,29,30,29,30,29,30}//2017
      code tính ngày âm:
      PHP Code:
      int8 daydatemonthyear;                  //Dương lịch.
      int8 date_lunar,month_lunar,year_lunar;   // Âm lịch.
      void lunar_calculate()
      int8 x,y;
      ds1307_read_date(&day,&date,&month,&year);
      AL_DauThang[year-13][month -1];
      AL_SoNgay[year-13][month-1];
      date_lunar date 1;
         if(
      date_lunar y)
      date_lunar =  date_lunar-y;
      month_lunar = (int)(AL_Thang[year-13][month-1]+1);
         else
      month_lunar = (int)(AL_Thang[year-13][month-1]);
         if(
      month month_lunar)   year_lunar = (int)(year-1);
         else
      year_lunar = (int)year;
        "Demo-limit"
        => Dùng hàng Free thì chỉ được thế thôi. Cách giải quyết : Một là viết ít, 2 là mua bản quyền, 3 là "cờ dách" .
        wavemagic Tìm hiểu thêm về wavemagic
