#include <16F877A.h>
#include <def_877a.h>
#device *=16 adc=10
#FUSES NOWDT,HS,NOPUT,NOPROTECT,NODEBUG,NOBROWNOUT,NOLVP, NOCPD,NOWRT
#use delay(clock=20000000)
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7, bits=9)
#include <lcd_lib_4bit.c> // Thu vien ham cho LCD
int8 low,high,key,mode,min,max,mode1,i;
int1 do_F;
void convert_bcd(int8 x);
void bao_dong();
void test();
void main()
float value;
on_off =1;
min =15; //nhiet do min default
max =35; //nhiet do max default
do_F =0 ;
i = 50 ;
mode =0 ;
mode1 = 0 ;
trisa = 0xFF;
trisb = 0x01;
trisd = 0x00;
LCD_init();
Printf(LCD_putchar,"Lop DT8 - BKHN");
LCD_putcmd(0xC0);
Printf(LCD_putchar,"Khoi tao...");
// Khoi tao cho ngat ngoai
enable_interrupts (INT_EXT);
ext_int_edge(H_TO_L);
enable_interrupts (GLOBAL);
// Khoi tao che do cho bo ADC
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_INTERNAL);
delay_us(10);
// Lay mau nhiet do lan dau tien
value=(float)read_adc();
value = (value - 558.5)/2.048; // For 5V supply
// value = (value - 754.8)/2.048; // For 3.7V Supply
// value = (value - 698.2)/2.048; // For 4V supply
convert_bcd((int8)value); // Tach so tram, chuc, donvi de hien thi len LED 7
delay_ms(1000);
LCD_putcmd(0xC0);
Printf(LCD_putchar,"Khoi tao xong");
while(1)
if (i==50)
value = read_adc();
value=(value-558.5)/2.048;
if (do_F==1) value=1.8*value+32;
printf("\n\rNhiet do phong: %u",value);// Gui gia tri len may tinh
LCD_putcmd(0xC0);
printf(LCD_putchar," Temp = ");
LCD_putchar(high); LCD_putchar(low);
if (do_F==0) printf(LCD_putchar," C");
else printf(LCD_putchar," F");
i=0;
i++;
if(((int8)value > 40) || ((int8)value < 15)) on_off=1;
else
on_off = 0;
LCD_Putcmd(0xCF);
LCD_putchar(" ");
blink=0;
if (on_off==1)
if (blink==0) {
LCD_Putcmd(0xCF);LCD_putchar("!");blink=1;delay_ms (250);}
else {LCD_Putcmd(0xCF);LCD_putchar(" ");blink=0;delay_ms(250);}
}//end main-----------------------------------------------------------
#INT_EXT
void test()
if (do_F == 1) do_F=0;
else do_F=1;
low=x%10; //chia lay phan du, so hang don vi
high=x/10; //tach hang tram va hang chuc
low = low + 0x30;
high = high + 0x30;
void bao_dong(){
int8 i;
if (blink == 0) blink = 1;
else blink=0;
for(i=0;i<50;i++)
LCD_Putcmd(0xCF);
if (blink==0) LCD_putchar("!");
else LCD_putchar(" ");
nó cứ báo lỗi khi dịch ccs nản các bạn xem ntn cái
#device *=16 adc=10
int1 do_F;
void bao_dong();
void test();
void main()
float value;
on_off =1;
do_F =0 ;
i = 50 ;
mode =0 ;
mode1 = 0 ;
trisa = 0xFF;
trisb = 0x01;
trisd = 0x00;
LCD_init();
LCD_putcmd(0xC0);
delay_us(10);
delay_ms(1000);
LCD_putcmd(0xC0);
while(1)
if (i==50)
value = read_adc();
LCD_putcmd(0xC0);
i=0;
i++;
else
on_off = 0;
LCD_Putcmd(0xCF);
LCD_putchar(" ");
blink=0;
if (on_off==1)
if (blink==0) {
#INT_EXT
void test()
else do_F=1;
low = low + 0x30;
high = high + 0x30;
void bao_dong(){
int8 i;
else blink=0;
for(i=0;i<50;i++)
LCD_Putcmd(0xCF);
