mình mới học còn gà đang rất gấp .mong các anh em giúp
đây là main.c
#include <16F877A.h>
#device adc=8
#FUSES NOWDT //No Watch Dog Timer
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPUT //No Power Up Timer
#FUSES NOPROTECT //Code not protected from reading
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOBROWNOUT //No brownout reset
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD //No EE protection
#FUSES NOWRT //Program memory not write protected
#use delay(clock=20000000)
#define LCD_RS_PIN PIN_D1
#define LCD_RW_PIN PIN_D2
#define LCD_ENABLE_PIN PIN_D3
#define LCD_DATA4 PIN_D4
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D6
#define LCD_DATA7 PIN_D7
#include <lcd.c>
#include "key.c"
int8 temp;
void main()
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_comparator(NC_NC_NC_NC);
setup_vref(FALSE);
delay_ms(500);
lcd_init();
lcd_putc("\f");
lcd_gotoxy(1,1);
printf(lcd_putc,"Phim Bam:");
key_init();
while(true)
temp = key_loai1();
if(temp != 15)
if(temp == 11)
lcd_gotoxy(10,1);
lcd_putc(" ");
lcd_gotoxy(10,1);
lcd_putc("*");
else if(temp == 12)
lcd_gotoxy(10,1);
lcd_putc(" ");
lcd_gotoxy(10,1);
lcd_putc("#");
else
lcd_gotoxy(10,1);
lcd_putc(" ");
lcd_gotoxy(10,1);
printf(lcd_putc,"%02d", temp);
-----------------------------------còn đây là key.c--------------------------------
#include "KEY.h"
#define cot_1 PIN_B0
#define cot_2 PIN_B1
#define cot_3 PIN_B2
#define hang_A PIN_B4
#define hang_B PIN_B5
#define hang_C PIN_B6
#define hang_D PIN_B7
void key_init()
set_tris_b(0xF0);
//set cac chan Hang_A-D la input
output_high(hang_A);
output_high(hang_B);
output_high(hang_C);
output_high(hang_D);
//set cac chan cot1-3 la dau output
output_low(cot_1);
output_low(cot_2);
output_low(cot_3);
unsigned char key_loai1()
output_low(cot_1);
output_high(cot_2);
output_high(cot_3);
if(input(hang_A) == 0)
delay_ms(200);
return 1; //phim 1 dc bam
if(input(hang_B) == 0)
delay_ms(200);
return 4; //phim 4 dc bam
if(input(hang_C) == 0)
delay_ms(200);
return 7; //phim 7 dc bam
if(input(hang_D) == 0)
delay_ms(200);
return 11; //phim * dc bam
delay_ms(5);
output_high(cot_1);
output_low(cot_2);
output_high(cot_3);
delay_ms(200);
return 2; //phim 2 dc bam
delay_ms(200);
return 5; //phim 5 dc bam
delay_ms(200);
return 8; //phim 8 dc bam
delay_ms(200);
return 0; //phim 0 dc bam
delay_ms(5);
output_high(cot_1);
output_high(cot_2);
output_low(cot_3);
delay_ms(200);
return 3; //phim 3 dc bam
delay_ms(200);
return 6; //phim 6 dc bam
delay_ms(200);
return 9;
delay_ms(200);
return 12; //phim # dc bam
delay_ms(5);
return 15; //khong co phim nao dc bam
BÂY GIỜ MÌNH MUỐN NÓ HIỂN THỊ MÀ BẤM CÁC KÝ TỰ LIÊN TIẾP MÀ KÝ TỰ TRƯỚC ĐÓ KHÔNG BỊ XÓA THÌ LÀM NTN NHỈ
đây là main.c
#device adc=8
#include <lcd.c>
#include "key.c"
int8 temp;
void main()
setup_adc(ADC_OFF);
setup_vref(FALSE);
delay_ms(500);
lcd_init();
lcd_putc("\f");
lcd_gotoxy(1,1);
key_init();
while(true)
temp = key_loai1();
if(temp != 15)
if(temp == 11)
lcd_gotoxy(10,1);
lcd_putc(" ");
lcd_gotoxy(10,1);
lcd_putc("*");
else if(temp == 12)
lcd_gotoxy(10,1);
lcd_putc(" ");
lcd_gotoxy(10,1);
lcd_putc("#");
else
lcd_gotoxy(10,1);
lcd_putc(" ");
lcd_gotoxy(10,1);
#include "KEY.h"
void key_init()
set_tris_b(0xF0);
output_low(cot_1);
output_low(cot_2);
output_low(cot_3);
output_low(cot_1);
output_high(cot_2);
output_high(cot_3);
delay_ms(200);
delay_ms(200);
delay_ms(200);
delay_ms(200);
delay_ms(5);
output_high(cot_1);
output_low(cot_2);
output_high(cot_3);
delay_ms(200);
delay_ms(200);
delay_ms(200);
delay_ms(200);
delay_ms(5);
output_high(cot_1);
output_high(cot_2);
output_low(cot_3);
delay_ms(200);
delay_ms(200);
delay_ms(200);
return 9;
delay_ms(200);
delay_ms(5);
![32](http://dientuvietnam.net/forums/images/smilies/32.gif)
