#include <16f877a.h>
#include <def_877A.h>
#fuses NOWDT,NOLVP,NOPROTECT,HS
#use delay(clock=20000000)
/////////khai bao ngo vao ra
#define RS RD5
#define RW RD6
#define E RD7
#define LCD PORTB
#define door RA0///khoa
#define alarm RA1///den bao
#define loa RA2 ///loa bao
//////////khai bao su dung port dung de xuat nhap du lieu
#use fast_io(b)
#use fast_io(d)
//////khai bao bien.....
int8 i,j,ss;
int8 a[7],y[7],b[7]={1,1,1,1,1,1},t[7];//bien luu gtri nhap vao
int8 test,dem,mp,alert;
const char st0[17]={" MOI NHAP PASS "};//0-15
const char st1[17]={"SAI PASS "};//0-15
const char st2[17]={"OK DA MO KHOA "};//0-15
const char st3[17]={" Nhap pass moi "};//0-15
const char st4[17]={"*you got new pw*"};//0-15
const char st5[17]={"*you got old pw*"};//0-15
const char s1[17]={"Enter pass cu "};//0-15
const char s2[17]={"Xac nhan pass "};//0-15
/*xxxxxxxxxxxxxxxxxxxxxxxxxx*/
/* procedures and functions */
////////khai bao cac chuong trinh con//////////////
void con_wrt(int8);
void data_wrt(int8);
void setup_lcd();
void scan_keyPress();//chuong trinh con quet phim
void erase();//chuong trinh con xoa
void write_PW();//chuong trinh con ghi
void display_error();//chuong trinh con hien thi khi nhap sai pass
void sub_main();
void display_ok();//ham hien thi khi nhap pass 0k
void compare();
void display();// hien thi
void confirm_pw();//xac nhan pass moi
void new_pw();//pass moi
void old_pw();//pass cu
void main()///ham chuong trinh chinh
trisc=0x0f;//C[7:4] xuat;C[3:0] vao bthuong cao
trisb=trisd=trisa=0;
setup_lcd();
alert=0;
write_PW();
for(i=0;i<6;i++) a=t=0;
n: door=0;alarm=0; loa=0;//turn off
con_wrt(0x01);//con tro dau dong 1
for(i=0;i<=15;i++) data_wrt(st0); //hien thi moi nhap pass
erase();
k1: if(alert==3) { alarm = 1; loa = 1;}//turn on alarm
scan_keypress(); //kiem tra phim matrix
if (mp==0xff) goto k1;
else
display();
if(j==6)
{ while((mp!=10)&&(mp!=11))//wait for pushing 10 or 11
scan_keypress();
if(mp==10) {erase(); goto k1;}
display(); goto n;
else goto k1;//if j is not 5 then turn back
//xxxxxxxxxxxxxxxx functions & procedures xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
void con_wrt(int8 dat)
lcd=dat;
RS=0;// instruction
RW=0;
E=1;delay_ms(3);
E=0;
delay_ms(5);
void data_wrt(int8 dat)
lcd=dat;
RS=1;// du lieu
RW=0;
E=1;delay_ms(3);
E=0;
DELAY_ms(5);
void setup_lcd()///ham hien thi ki tu tren lcd
delay_ms(100);
con_wrt(0x38);
con_wrt(0x0c);
con_wrt(0x01);
con_wrt(0x06);
//Program of Scanning KeyPress:
void scan_keyPress()///chuong trinh con quet phim matran
dem=4;
mp=0;
portc=0b11101111;
kat: test=portc&0x0f;
switch(test)
case 0b00001111: {
mp=mp+4;
portc=(portc<<1)+0;
dem--;
if(dem!=0) goto kat;//keep testing
else mp=0xff;//no pushing button
break;
case 0b00001110: {
delay_ms(20);while(!rc0); loa=1; delay_ms(20);//wait for leaving button
mp=mp+0;//nhan phim 0; 4; 8; 12
break;
case 0b00001101: {
delay_ms(20);while(!rc1);loa=1; delay_ms(20);//wait for leaving button
mp=mp+1;//nhan phim 1; 5; 9; 13
//display();
break;
case 0b00001011: {
delay_ms(20);while(!rc2);loa=1; delay_ms(20);//wait for leaving button
mp=mp+2;//nhan phim 2; 6; 10; 14
break;
case 0b00000111: {
delay_ms(20);while(!rc3);loa=1; delay_ms(20);//wait for leaving button
mp=mp+3;//nhan phim 3; 7; 11; 15
delay_ms(30); loa = 0;////thoi gian loa keu
void erase()///chuong trinh con xoa khi ta nhan sai pass
ss=j=0;
con_wrt(0xc0);
for (i=0;i<16;i++)
if(i<6) a=0;
data_wrt(0x20);// ' ' character
con_wrt(0xc0);
void write_PW()///ghi pass
for(i=0;i<6;i++) write_eeprom(i,b);
alert++;
erase();
for(i=0;i<=15;i++) data_wrt(st1);
delay_ms(1500);
erase();
//Program of control while you get in
void sub_main()
door=1; delay_ms(2000); door=0;//door=o thi khoa,door=1 thi mo khoa
k2: scan_keypress();
switch(mp)
case 12: door = 1;delay_ms(2000); door=0;;goto k2;
case 13: alarm = ~alarm;goto k2;
case 14: old_pw();goto k2;
case 15: break;
default: goto k2;
void display_ok()///man hinh hien thi luc nhap 0k
alert=0;
erase();
con_wrt(0x01);
for(i=0;i<=15;i++) data_wrt(st2);
con_wrt(0xc0);//con tro dau dong 2
sub_main();
void compare()//TH nhan phim OK
for(i=0;i<6;i++) if(a==read_eeprom(i)) ss++;////doc du lieu tu eeprom
if (ss==6) display_ok();
else display_error();
void display()///hien thi
switch(mp)
case 0: case 1: case 2: case 3: case 4: case 5: case 6: case 7: case 8: case 9:
if(j==6) break;
a[j]=mp;
data_wrt(mp+0x30);
delay_ms(10);
con_wrt(0xc0+j);
data_wrt('*');
j++;
break;
case 10: erase();break;
case 11: compare();break;
default: break;
void old_pw(void)///ham nhap pass cu
erase();
con_wrt(0x01);
for(i=0;i<=15;i++) data_wrt(s1);
k5: scan_keypress();///quet phim matrix
switch(mp)
if(j==6) goto k5;
y[j]=mp;
data_wrt(mp+0x30);
delay_ms(100);
con_wrt(0xc0+j);
data_wrt( '*');
j++;
} goto k5;
case 10: erase(); goto k5;
case 11: if(j==0) goto k5;
else new_pw();
case 15: erase();con_wrt(1);for(i=0;i<=15;i++) data_wrt(st2);break;
default: goto k5;
void new_pw(void)///ham nhap pass moi
erase();
con_wrt(0x01);
for(i=0;i<=15;i++) data_wrt(st3);
k3: scan_keypress();
switch(mp)
if(j==6) goto k3;
b[j]=mp;
data_wrt(mp+0x30);
delay_ms(100);
con_wrt(0xc0+j);
data_wrt('*');
j++;
} goto k3;
case 10: erase(); goto k3;
case 11: confirm_pw();
case 15: break;
default: goto k3;
void confirm_pw(void)///ham nhap lai pass cu
erase();
con_wrt(0x01);
for(i=0;i<=15;i++) data_wrt(s2);
k4: scan_keypress();
switch(mp)///mp tu viet tat MA PHIM MATRIX
if(j==6) goto k4;
t[j]=mp;
data_wrt(mp+0x30);
delay_ms(100);
con_wrt(0xc0+j);
data_wrt('*');
j++;
} goto k4;
case 10: erase(); goto k4;
case 11: for(i=0;i<6;i++) if( (y==read_eeprom(i)) && (b==t) ) ss++;
if(ss==6) {write_PW(); erase();for(i=0;i<=15;i++) data_wrt(st4);delay_ms(1200);}
else {erase(); for(i=0;i<=15;i++) data_wrt(st5);delay_ms(1200);}
erase(); break;
case 15: break;
default: goto k4;
CODE CỦA MÌNH ĐÂY MÌNH ĐÃ KHÓA ĐƯỢC 1 CƯA
BÂY GIỜ MÌNH MUỐN QUẢN LÝ 2 CỬA CÓ NGHĨA TA THÊM 1 MẢNG PASS CHO CỬA THỨ 2
BẤM PHÍM ĐÚNG PASS CỬA NÀO THÌ CỬA ĐÓ MỞ
CÁC BẠN GIÚP MÌNH VỚI MÌNH ĐANG RẤT CẦN
THANKS
#define RS RD5
#define RW RD6
#define E RD7
#define LCD PORTB
#use fast_io(b)
#use fast_io(d)
int8 i,j,ss;
void con_wrt(int8);
void setup_lcd();
void sub_main();
void compare();
setup_lcd();
alert=0;
write_PW();
erase();
else
display();
if(j==6)
scan_keypress();
display(); goto n;
lcd=dat;
RS=0;// instruction
RW=0;
E=1;delay_ms(3);
E=0;
delay_ms(5);
lcd=dat;
RS=1;// du lieu
RW=0;
E=1;delay_ms(3);
E=0;
DELAY_ms(5);
delay_ms(100);
con_wrt(0x38);
con_wrt(0x0c);
con_wrt(0x01);
con_wrt(0x06);
dem=4;
mp=0;
portc=0b11101111;
switch(test)
case 0b00001111: {
mp=mp+4;
portc=(portc<<1)+0;
dem--;
break;
case 0b00001110: {
break;
case 0b00001101: {
//display();
break;
case 0b00001011: {
break;
case 0b00000111: {
ss=j=0;
con_wrt(0xc0);
for (i=0;i<16;i++)
if(i<6) a=0;
con_wrt(0xc0);
alert++;
erase();
delay_ms(1500);
erase();
void sub_main()
switch(mp)
case 15: break;
default: goto k2;
alert=0;
erase();
con_wrt(0x01);
sub_main();
switch(mp)
if(j==6) break;
a[j]=mp;
data_wrt(mp+0x30);
delay_ms(10);
con_wrt(0xc0+j);
data_wrt('*');
j++;
break;
default: break;
erase();
con_wrt(0x01);
switch(mp)
if(j==6) goto k5;
y[j]=mp;
data_wrt(mp+0x30);
delay_ms(100);
con_wrt(0xc0+j);
data_wrt( '*');
j++;
} goto k5;
else new_pw();
default: goto k5;
erase();
con_wrt(0x01);
switch(mp)
if(j==6) goto k3;
b[j]=mp;
data_wrt(mp+0x30);
delay_ms(100);
con_wrt(0xc0+j);
data_wrt('*');
j++;
} goto k3;
case 15: break;
default: goto k3;
erase();
con_wrt(0x01);
if(j==6) goto k4;
t[j]=mp;
data_wrt(mp+0x30);
delay_ms(100);
con_wrt(0xc0+j);
data_wrt('*');
j++;
} goto k4;
erase(); break;
case 15: break;
default: goto k4;
THANKS
![Smilie](http://dientuvietnam.net/forums/images/smilies/smile.gif)
