Giao tiếp 1-wire DS18b20
  • Giao tiếp 1-wire DS18b20
    Ai đã làm vs DS18b20 rồi kiểm tra giúp em , đoạn code của e sai chỗ nào được ko ak. sao giá trị hàm ds18b20_read() thu được cứ =0 thôi ak
    Code:
    void onewire_write(int8 data) {
       unsigned  int8 count;
        for(count = 0; count < 8; ++count) {
            output_low(ONE_WIRE_PIN);
            delay_us(2);                // pull 1-wire low to initiate write time-slot.
            output_bit(ONE_WIRE_PIN, shift_right(&data, 1, 0)); // set output bit on 1-wire
            delay_us(60);               // wait until end of write slot.
            output_float(ONE_WIRE_PIN); // set 1-wire high again,
            delay_us(2);                // for more than 1us minimum.
     * onewire_read()
     * Description: reads and returns a byte of data from the device.
    int8 OneWire_Read()
     int8 count, data=0;
     for (count=0; count<8; ++count)
      output_low(ONE_WIRE_PIN);//Thiet lap dau ra
      ONE_WIRE_PIN=0;
      delay_us( 2 );
      input(ONE_WIRE_PIN);//Thiet lap dau vao
      delay_us( 8 );
      if(ONE_WIRE_PIN)
      data|=0x01<<count;
      delay_us( 120 );
     return( data );
    float ds18b20_read() {
        int8  temp1, temp2;
        signed int16 temp3;
        float result;
        onewire_reset();
        onewire_write(0xCC);            //Skip ROM, address all devices
        onewire_write(0x44);            //Start temperature conversion
        delay_us(200);
        onewire_reset();
        onewire_write(0xBE);            //Read scratchpad
        temp1 = onewire_read();
        temp2 = onewire_read();
        temp3 = make16(temp2, temp1);
        //result = (float) temp3 / 2.0;   //Calculation for DS18S20 with 0.5 deg C resolution
        result = (float) temp3 / 16.0;    //Calculation for DS18B20 with 0.1 deg C resolution
        delay_ms(200);     // ??????
        return (result);
    void ds18b20_configure(int8 TH, int8 TL, int8 config) {
        onewire_reset();
        onewire_write(0x4E);            //Write to scratchpad
        onewire_write(TH);
        onewire_write(TL);
        onewire_write(config);
ngocnhat95 Tìm hiểu thêm về ngocnhat95
