Em dùng MikroC viết đoạn code test sau xuất UART, khi compile thì nó báo lỗi Reentrancy is not allowed: function 'UART1_Write' called from two threads __Lib_UART_c67.c, muốn khắc phục thì phải xóa hàm UART1_Write_Text("TEST HARDWARE UART"); khỏi main thì nó mới chạy. Ai gặp lỗi này chỉ dùm em cách khắc phục với ah
Code:
/******************************************************************************* ** Function name: main () ** Description : main program ******************************************************************************/ int main(void) { /* Init System */ Port_Init(); HardwareUart_Config(); UART1_Write_Text("TEST HARDWARE UART"); while (1) { } } /******************************************************************************* ** Function name: Interrupt (void) ** Description : None ******************************************************************************/ void Interrupt (void) { unsigned char HardUART_Rx = 0; /* UART Rx INTERRUPT ---------------------------------------------- * */ if(RCIE_bit && RCIF_bit) { RCIF_bit = 0; if(UART1_Data_Ready()) { HardUART_Rx = UART1_Read(); UART1_Write(HardUART_Rx); } } }
