PIC 16f887+module thu phat RF FSI000A,PCR1A
  • PIC 16f887+module thu phat RF FSI000A,PCR1A
    bác nào co kinh nghiệm về module thu phát này thì xin giúp em với.em loay hoay 2 ngày rồi mà vẫn không chạy được.
    đây là code được viết trong mikroC , nguồn từ 4room nay:
    http://www.mikroe.com/forum/viewtopi...23831&start=15
    code bên phát:
    // Manchester module connections
    //sbit MANRXPIN at RC0_bit;
    //sbit MANRXPIN_Direction at TRISC0_bit;
    sbit MANTXPIN at RC1_bit;
    sbit MANTXPIN_Direction at TRISC1_bit;
    // End Manchester module connections
    char index, character;
    char s1[] = "This is the test Data from Master Tx unit";
    char noise = 0;
    void main() {
    ANSEL = 0; // Configure AN pins as digital I/O
    ANSELH = 0;
    C1ON_bit = 0; // Disable comparators
    C2ON_bit = 0;
    TRISC.F2 = 0;
    TRISC.F3 = 0;
    PORTC.F2 = 0;
    PORTC.F3 = 0;
    Man_Send_Init(); // Initialize transmitter
    while (1) { // Endless loop
    for (noise = 0; noise <= 4; noise++){
    Man_Send(0x80);
    Delay_ms(100);
    Man_Send(0xCA);
    Delay_ms(100);
    PORTC.F2 = 1; // Start byte sent indicator
    Man_Send(0xC3); // Send "start" byte
    Delay_ms(500); // Wait for a while
    character = s1[0]; // Take first char from string
    index = 0; // Initialize index variable
    while (character) { // String ends with zero
    PORTC.F3 = 1; // LCD data sending indicator
    Man_Send(character); // Send character
    Delay_ms(90); // Wait for a while
    index++; // Increment index variable
    character = s1[index]; // Take next char from string
    Man_Send(0xCF); // Send "end" byte
    PORTC.F2 = 0; // Start byte sent indicator
    PORTC.F3 = 0; // LCD data sending indicator
    Delay_ms(2000);
    Đây là code bên nhận:
    // Manchester module connections Start
    // End Manchester module connections End
    unsigned char error = 0, ErrorCount = 0, temp = 0;
    void main() {
    ANSELH = 0;
    C2ON_bit = 0;
    PORTC.F2 = 0; // Clear Start bit found indicator
    PORTC.F3 = 0; // Clear Update UART indicator
    TRISC.F2 = 0; // Set as output used for Start bit found indicator
    TRISC.F3 = 0; // Set as output used for Update UART indicator
    PORTC.F5 = 0;
    TRISC.F5 = 0;
    UART1_Init(19200);
    Man_Receive_Init(); // Initialize Receiver
    do{ // Rx Routine forever loop
    GET_BYTE:
    temp = Man_Receive(&error); // Attempt byte receive
    if (error) goto ERROR_BYTE; // if comm's error goto error handler
    goto START_BYTE; // if good byte Received goto start handler
    ERROR_BYTE:
    UART1_Write_Text("ErrorByte count = "); // Write error and count to UART
    ErrorCount++; // Update error counter
    UART1_Write(ErrorCount+48);
    UART1_Write_Text("\n\r");
    if(ErrorCount > 5) goto RE_SYNC;
    goto GET_BYTE;
    START_BYTE:
    if (temp == 0xC3){ // "Start" byte value expected is 0xC3
    PORTC.F2 = 1; // Set Start bit found indicator
    // a valid Start Byte has been found
    goto DISPLAY_BYTE; // goto the Display routine
    }// Exit if
    goto NOISE_BYTE; // Valid data byte found is not a start byte
    // go to noise reporting loop
    DISPLAY_BYTE:
    if(temp == 0xCF) goto STOP_BYTE; // Valid Stop Byte found Exit
    UART1_Write_Text("Valid Data Found\n\r"); // Send Activity to UART
    while (1){ // loop to collect all valid data
    if (temp == 0xCF)break; // Stop condition found Exit while loop
    PORTC.F3 = 1; // Set Update UART indicator
    UART1_Write(temp); // write received byte on UART
    UART1_Write_Text("\n\r"); // new line + Carriage Return
    goto STOP_BYTE; // Exit UART write loop
    NOISE_BYTE:
    UART1_Write_Text("Synchronized But Data Found is Noise = "); // Send Activity to UART
    UART1_Write(temp);
    goto GET_BYTE; // Exit noise detect loop
    RE_SYNC:
    UART1_Write_Text("Synchronizing\n\r"); // Display Activity on 2nd Row
    delay_ms(50);
    temp = Man_Synchro(); // Try to synchronize again
    //Man_Receive_Init(); // Alternative, try to Initialize Receiver again
    ErrorCount = 0; // Reset error counter
    if (temp == 0xFF) goto RE_SYNC; // Sync failed try again
    goto GET_BYTE; // Sync complete start over again
    STOP_BYTE:
    if (temp == 0xCF){ // If "End" byte was received
    UART1_Write_Text("Valid Stop Found\n\r"); // Send Activity to UART
    delay_ms(100);
    goto GET_BYTE; // start over again
    }while(1); // Rx Routine
    } // main
    code viết rất dễ hiểu.nhung không hiếu sao em chỉ nhận được dữ liệu đúng trong lần phát đầu tiên.cho dù em phát 1000 kí tự đi nữa tjì trong lần phát đầu tiên em cung nhận đúng 1000 kí tự,nhưng tói lần phát 2 thì không đúng nữa.
    và em không hiểu đoạn code này để làm gì
    Man_Send(0x80);
    Delay_ms(100);
    Man_Send(0xCA);
    Delay_ms(100);
    xin giúp em.thanks
    mấy con ic thu va phat này ban mua ở đâu vậy
    Tư vấn thiết kế hệ thống điện-điện tử theo yêu cầu.
    Tel: 0903 702 417. Email: web:
    giakien Tìm hiểu thêm về giakien
      hôm nay, 13:11
      hôm nay, 09:25
      hôm nay, 09:10
    • Ng.Phuong.5
      bởi Ng.Phuong.5
      Mấy con...
      Hôm qua, 19:44
    • viettinh
      bởi viettinh
      Hôm qua, 18:12
      Cách đơn giản...
      Hôm qua, 00:04
      08-01-2025, 19:02
      08-01-2025, 15:43
      08-01-2025, 15:28
      08-01-2025, 11:44
