Nguyên văn bởi heliman
& là mã dùng để hiển thị dấu '&' trong một trang web. Bạn cứ thay hết các & bằng ký tự '&' là xong. Ví dụ
Code:
output_bit ( LCD_D4, cX & 0x01 );
printf(lcd_PutChar,"PICVIETNAM"); //???
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx //lcd_lib.c // The six bus pins are defined here. // this example happens to use PIC port B3, B4, B5, B6 for LCD data // and port B5 for LCD ENABLE and port B6 for LCD RS. //2 dong nay chac ho viet nham so voi define o duoi #define LCD_D4 PIN_B1 #define LCD_D5 PIN_B2 #define LCD_D6 PIN_B3 #define LCD_D7 PIN_B4 #define LCD_EN PIN_B5 #define LCD_RS PIN_B6 #define LINE_1 0x00 #define LINE_2 0x40 #define CLEAR_DISP 0x01 // prototype statements #separate void LCD_Init ( void ); #separate void LCD_SetPosition ( unsigned int cX ); #separate void LCD_PutChar ( unsigned int cX ); #separate void LCD_PutCmd ( unsigned int cX ); #separate void LCD_PulseEnable ( void ); #separate void LCD_SetData ( unsigned int cX ); // whatever pins you assign to the display // MUST be in a bus that is a CCS type "standard_io". //#use standard_io ( A ) #use standard_io ( B ) //#use standard_io ( C ) toi bo 2 dong nay vi bao loi va ko can thiet #separate void LCD_Init ( void ) { LCD_SetData ( 0x00 ); delay_ms ( 200 ); /* wait enough time after Vdd rise */ output_low ( LCD_RS ); LCD_SetData ( 0x03 ); /* init with specific nibbles to start 4-bit mode */ LCD_PulseEnable(); LCD_PulseEnable(); LCD_PulseEnable(); LCD_SetData ( 0x02 ); /* set 4-bit interface */ LCD_PulseEnable(); /* send dual nibbles hereafter, MSN first */ LCD_PutCmd ( 0x2C ); /* function set (all lines, 5x7 characters) */ LCD_PutCmd ( 0x0C ); /* display ON, cursor off, no blink */ LCD_PutCmd ( 0x01 ); /* clear display */ LCD_PutCmd ( 0x06 ); /* entry mode set, increment & scroll left */ } #separate void LCD_SetPosition ( unsigned int cX ) { /* this subroutine works specifically for 4-bit Port A */ LCD_SetData ( swap ( cX ) | 0x08 ); LCD_PulseEnable(); LCD_SetData ( swap ( cX ) ); LCD_PulseEnable(); } #separate void LCD_PutChar ( unsigned int cX ) { /* this subroutine works specifically for 4-bit Port A */ // if ( !cSkip ) //dong nay chac can khi co phan cung { output_high ( LCD_RS ); LCD_SetData ( swap ( cX ) ); /* send high nibble */ LCD_PulseEnable(); LCD_SetData ( swap ( cX ) ); /* send low nibble */ LCD_PulseEnable(); output_low ( LCD_RS ); } } #separate void LCD_PutCmd ( unsigned int cX ) { /* this subroutine works specifically for 4-bit Port A */ LCD_SetData ( swap ( cX ) ); /* send high nibble */ LCD_PulseEnable(); LCD_SetData ( swap ( cX ) ); /* send low nibble */ LCD_PulseEnable(); } #separate void LCD_PulseEnable ( void ) { output_high ( LCD_EN ); delay_us ( 3 ); // was 10 output_low ( LCD_EN ); delay_ms ( 3 ); // was 5 } #separate void LCD_SetData ( unsigned int cX ) { output_bit ( LCD_D4, cX & 0x01 ); output_bit ( LCD_D5, cX & 0x02 ); output_bit ( LCD_D6, cX & 0x04 ); output_bit ( LCD_D7, cX & 0x08 ); }
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx //TestLCD.c #include <16f628a.h> #use delay(clock=4000000) #fuses NOWDT,PUT,HS,NOPROTECT #include <lcd_lib.c> void main ( void ) { char cX; cX = 1; // set number LCD_Init(); // set up LCD for 4-wire bus, etc. LCD_PutCmd ( CLEAR_DISP ); // clear screen LCD_SetPosition ( LINE_1 + 0 ); // set line and offset on line printf ( LCD_PutChar, "Test #1", cX ); // display message LCD_SetPosition ( LINE_2 + 5 ); // set line and offset on line printf ( LCD_PutChar, "2nd test" ); // display message while ( 1 ); // stop }
//khoi tao LCD**********************************************
delay_ms(200); /* wait enough time after Vdd rise >> 15ms */
output_low ( LCD_RS );// che do gui lenh
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
