Code:
#include <16F877A.h> #include <DEFINE_16F877A.h> #include <DEFINE_16F87x.h> #fuses NOWDT,XT,NOPROTECT,NOLVP,PUT #use delay(clock=4000000) #use standard_io (B) #use standard_io (A) #define E PIN_D0 #define RS PIN_D1 #define RW PIN_D2 #define LCD_D4 PIN_D4 #define LCD_D5 PIN_D5 #define LCD_D6 PIN_D6 #define LCD_D7 PIN_D7 #bit CANCEL =0x05.1 // CANCEL = RA1 #bit OK =0x05.0 // OK = RA0 unsigned int8 key[] ; // mang luu cac so da nhap tu ban phim const unsigned int8 num[11] = {'0','1','2','3','4','5','6','7','8','9'} ; const unsigned int8 num_ss[11] = {' ','3','9','5','2','6','1','0'} ; // cac so dung de so sanh unsigned int8 a = 0 ; // bien dem cac so nhap tu ban phim unsigned int8 b = 0 ; // bien dem so lan sai ma void LCD_Init ( void ); // ham khoi tao LCD void LCD_SetPosition ( unsigned int data );//Thiet lap vi tri con tro void LCD_PutChar ( unsigned int data ); // Ham viet1kitu/1chuoi len LCD void LCD_PutCmd ( unsigned int data ) ; // Ham gui lenh len LCD void tao_xung_E(); // Xung kich hoat void send_to_LCD( unsigned int data); // Dat du lieu len chan Data void delay_ms_INT(unsigned long i) { unsigned long k , j ; for(k=0;k<=i;k++) { for(j=0;j<=i;j++){;} } } void LCD_Init ( void ) { delay_ms(200); // thoi gian de LCD khoi dong output_low(RW); // RW = 0 output_low(RS); // che do gui lenh send_to_LCD( 0x00 ); output_high ( E ); output_low ( E ); delay_ms ( 10 ); send_to_LCD( 0x03 ); /* init with specific nibbles to start 4-bit mode */ output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E output_high ( E ); output_low ( E ); delay_ms ( 3 ); output_high ( E ); output_low ( E ); delay_ms ( 3 ); send_to_LCD( 0x02 ); /* set 4-bit interface */ output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E LCD_PutCmd ( 0x2C ); /* function set (all lines, 5x7 characters) */ LCD_PutCmd ( 0x0C); /* display ON, cursor off, no blink */ LCD_PutCmd ( 0x06 ); /* entry mode set, increment & scroll left */ LCD_PutCmd ( 0x01 ); /* clear display */ } void LCD_SetPosition ( unsigned int data ) { send_to_LCD( swap ( data ) | 0x08 ); output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E send_to_LCD( swap ( data ) ); output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E } void LCD_PutChar ( unsigned int data ) { output_high( RS ); //RS = 1 output_low ( RW ); //RW = 0 send_to_LCD( swap ( data ) ); // gui 4 bit cao output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E send_to_LCD( swap ( data ) ); //gui 4 bit thap output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E } void LCD_PutCmd ( unsigned int data ) { output_low(RS); // RS = 0 output_low(RW); // RW = 0 send_to_LCD( swap(data) ); // gui 4 bit cao output_high (E); output_low (E); delay_ms (3); send_to_LCD( swap(data) ); // gui 4 bit thap output_high (E); output_low (E); delay_ms ( 3 ); } void send_to_LCD( unsigned int data ) { output_bit ( LCD_D4, data & 0x01 ); output_bit ( LCD_D5, data & 0x02 ); output_bit ( LCD_D6, data & 0x04 ); output_bit ( LCD_D7, data & 0x08 ); } void quetphim_hienthi() { PORTB = 0b111111110 ; if (RB4==0) { delay_ms_INT(50); while(RB4==0) continue ; delay_ms_INT(20); LCD_PutChar('0') ; key[a++] = num[0]; } ; if (RB5==0) { delay_ms_INT(50); while(RB5==0) continue ; delay_ms_INT(20); LCD_PutChar('3') ; key[a++] = num[3]; } ; if (RB6==0) { delay_ms_INT(50); while(RB6==0) continue ; delay_ms_INT(20); LCD_PutChar('6') ; key[a++] = num[6]; } ; if (RB7==0) { delay_ms_INT(50); while(RB7==0) continue ; delay_ms_INT(20); LCD_PutChar('9') ; key[a++] = num[9]; } ; PORTB = 0b111111101 ; if (RB4==0) { delay_ms_INT(50); while(RB4==0) continue ; delay_ms_INT(20); LCD_PutChar('1') ; key[a++] = num[1]; } ; if (RB5==0) { delay_ms_INT(50); while(RB5==0) continue ; delay_ms_INT(20); LCD_PutChar('4') ; key[a++] = num[4]; } ; if (RB6==0) { delay_ms_INT(50); while(RB6==0) continue ; delay_ms_INT(20); LCD_PutChar('7') ; key[a++] = num[7]; } ; PORTB = 0b111111011 ; if (RB4==0) { delay_ms_INT(50); while(RB4==0) continue ; delay_ms_INT(20); LCD_PutChar('2') ; key[a++] = num[2]; } ; if (RB5==0) { delay_ms_INT(50); while(RB5==0) continue ; delay_ms_INT(20); LCD_PutChar('5') ; key[a++] = num[5]; } ; if (RB6==0) { delay_ms_INT(50); while(RB6==0) continue ; delay_ms_INT(20); LCD_PutChar('8') ; key[a++] = num[8]; } ; } #int_RB void ngat_RB(void) { LCD_PutCmd(0x83); // dong1 cot 5 while (OK && CANCEL) quetphim_hienthi(); // nut OK chua dc nhan if(CANCEL==0) {delay_ms_INT(20); // nhan OK while(CANCEL==0) continue ; delay_ms_INT(20); goto THOAT ; }; if(OK==0 ) {delay_ms_INT(20); // nhan OK while(OK==0) continue ; delay_ms_INT(20); if (a==7) { if(key[1]!=num_ss[1]) {goto HERE ;}; if(key[2]!=num_ss[2]) {goto HERE ;}; if(key[3]!=num_ss[3]) {goto HERE ;}; if(key[4]!=num_ss[4]) {goto HERE ;}; if(key[5]!=num_ss[5]) {goto HERE ;}; if(key[6]!=num_ss[6]) {goto HERE ;}; if(key[7]!=num_ss[7]) {goto HERE ;}; LCD_PutCmd(0x01); LCD_PutCmd(0x84); LCD_PutChar('Y') ; LCD_PutChar('E') ; LCD_PutChar('S') ; delay_ms(2000) ; HERE : LCD_PutCmd(0x01); LCD_PutCmd(0x84); LCD_PutChar('W') ; LCD_PutChar('r') ; LCD_PutChar('o') ; LCD_PutChar('n') ; LCD_PutChar('g') ; LCD_PutChar('!') ; b++; // dem so lan sai ma } ; if (a!=7){ LCD_PutCmd(0x01); LCD_PutCmd(0x84); LCD_PutChar('W') ; LCD_PutChar('r') ; LCD_PutChar('o') ; LCD_PutChar('n') ; LCD_PutChar('g') ; LCD_PutChar('!') ; b++; // dem so lan sai ma delay_ms(2000) ; } ; } ; THOAT : LCD_PutCmd(0x01); LCD_PutCmd(0xC4); LCD_PutChar('R') ; LCD_PutChar('e') ; LCD_PutChar('a') ; LCD_PutChar('d') ; LCD_PutChar('y') ; LCD_PutChar('!') ; RBIF = 0 ; } void main() { set_tris_A(0xFF); PORTA = 0xFF ; set_tris_B(0xF0); PORTB = 0xF0 ; set_tris_C(0x00); PORTC = 0; set_tris_D(0x00); LCD_Init(); // khoi tao LCD enable_interrupts(global); enable_interrupts(int_RB); ext_int_edge(H_to_L); LCD_PutCmd(0xC4); LCD_PutChar('R') ; LCD_PutChar('e') ; LCD_PutChar('a') ; LCD_PutChar('d') ; LCD_PutChar('y') ; LCD_PutChar('!') ; while(1) ; }
- em khai báo biến đếm a toàn cục , như trên code
- ý định của em : mỗi lần nhấn phím thì mảng key[] sẽ tự nạp số vào & nạp theo thứ tự , vì vậy , sau mỗi lần nhấn phím , em cho key[a++]
- nhưng ko hiểu sao , cứ mỗi lần nhấn đúng mã số "3952610", thì ct cứ nhảy tới label HERE .. em nghi ngờ ngay chỗ so sánh mảng key[] và num_ss[]
- chắc chắn key[] có giá trị ko đúng như các số mình đã nhấn !
các anh thấy em phân tích vậy có đúng ko ?
- thứ nữa : sau mỗi lần chạy hết ct ngắt thì ko bit ct có thoát khỏi ngắt hay ko ? nhưng em nhấn phím trở lại thì LCD ko chịu hiện số nữa , chỉ khi nhấn từ 3 lần trở lên thì số mới hiện trở lại . LCD lúc ấy đang bận ? nhưng nó có làm gì đâu . Đến nhãn THOAT , chỉ việc hiện " Ready!" lên thui mà . Có lẽ tới chỗ này ct bị treo !?
