giúp em giải đoạn code này với
  • giúp em giải đoạn code này với
    #include <16F877A.h>
    #include <def_877a.h>
    #FUSES NOWDT, HS, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
    #use delay(clock=4000000)
    #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bi ts=8)
    #include <font_ascii.c>
    //===================Dinh nghia cac chan cho ket noi 74595================
    #bit data = 0x05.1
    #bit clk = 0x05.2
    #bit latch = 0x05.0
    #bit tt = 0x05.3
    //=====================khai bao bien toan cuc==============================
    int8 buff_disp[33];
    int8 max_char;
    int8 time=5;
    int8 count=0;
    int is = 0;
    char dt[65];
    //======================KHAI BAO CAC CHUONH TRINH CON======================
    void send_2_595(int8 temp);
    void display();
    void copy_2_ram1(int8 index_char);
    void copy_2_ram2(int8 index_char);
    void luudata();
    #INT_RDA
    Receive_isr()
    char c;
    c = getc();
    putc(c);
    if(c==2) { count =0; is =1; };
    else
    if(c==3)
    is = 0; max_char = count+5; luudata();
    else
    if(is==1 && count<60) { dt[count] = c; count++;
    void luudata()
    int i;
    for(i=0;i<max_char-5;++i)
    write_eeprom(i,dt[i]);
    write_eeprom(i,32); write_eeprom(i+1,32); write_eeprom(i+2,32); write_eeprom(i+3,32); write_eeprom(i+4,32); write_eeprom(i+5,32); write_eeprom(i+6,32);
    write_eeprom(0xff,max_char);
    //===========Chuong trinh chinh============================================= ====
    void main() {
    int8 i,j;
    enable_interrupts(int_rda); //thiet lap ngat noi tiep
    enable_interrupts(GLOBAL); // thiet lap ngat toan cuc
    TRISA=0x00; // Thiet lap chan vao ra
    TRISB=0x00;
    delay_ms(10);
    max_char = read_eeprom(0xff);
    //==============Bat dau hoat dong chuong trinh chinh===========================
    while(1)
    for (i=0;i<=32;i++)
    buff_disp[i]=0xff;
    for (i=0;i<=max_char;i++)
    j=read_eeprom(i)-32;
    if (j<=51)
    copy_2_ram1(j);
    else
    j=j-51;
    copy_2_ram2(j);
    //==========================END MAIN =========================================
    // ====================== CAC CHUONG TRINH CON ===============================
    //=======Gui du lieu theo duong noi tiep toi 595==============================
    void send_2_595(int8 temp) {
    int8 i;
    clk=0;
    for(i=0;i<32;i++)
    if(i==temp)
    data=0;
    else data=1;
    clk=1;
    clk=0;
    //=====================Chuong trinh con hien thi===============================
    void display() {
    int8 count;
    int8 i;
    for (i=0;i<=time;i++) //Toc do chu chay thay doi boi bien time
    for(count=32;count>0;count--)
    send_2_595(count-1);
    PORTB = 0x00;
    latch=1;
    latch=0;
    PORTB = buff_disp[count];
    delay_us(20);
    //========================Copy to Ram1=======================================
    int8 i,j;
    for (j=0;j<=5;j++)
    for (i=32;i>0;i--)
    buff_disp[i]= buff_disp[i-1];
    buff_disp[0]=font[index_char].b[j];
    display();
    buff_disp[0]=0xff;
    //==========================Copy to Ram 2=====================================
    void copy_2_ram2(int8 index_char) {
    int8 i,j;
    for (j=0;j<=5;j++)
    for (i=32;i>0;i--)
    buff_disp[0]=font2[index_char].b[j];
    display();
    buff_disp[0]=0xff;
    Hi,
    Đoạn code này có gì đâu mà giải.
      thiệt là làm khó - gữi một đoạn code đã có chú thích mà kêu giải thích -> ko biết giải thích cái gì , tốt nhất bạn nên hỏi người nào ghi ra những dòng giải thích trong code - đó là người hiểu rõ đoạn code này nhất
      Đang thất nghiệp 0988-010-486
        cho mình hỏi ham nay dc gọi khi nào void send_2_595(int8 temp) { do mình thấy trong chương trình chình không gọi nên không biết được gọi ra và làm việc khi nào. mong đượ sự giúp đỡ của các bạn
          nó gọi trong hàm dislay() đó bạn:
          void display() {
          int8 count;
          int8 i;
          PORTB = 0x00;
          latch=1;
          latch=0;
          delay_us(20);
          Hàm này là hàm gửi dữ liệu ra ic dịch 74hc595
          phapdp Tìm hiểu thêm về phapdp
