Code:
#include <16F877A.h> #include <DEFINE_16F877A.h> #include <DEFINE_16F87x.h> #fuses NOWDT,XT,NOPROTECT,NOLVP,PUT #use delay(clock=4000000) #use standard_io (B) #use standard_io (A) #define E PIN_D0 #define RS PIN_D1 #define RW PIN_D2 #define LCD_D4 PIN_D4 #define LCD_D5 PIN_D5 #define LCD_D6 PIN_D6 #define LCD_D7 PIN_D7 #bit CANCEL =0x05.1 // CANCEL = RA1 #bit OK =0x05.0 // OK = RA0 unsigned int8 key[] ; // mang luu cac so da nhap tu ban phim const unsigned int8 num[11] = {'0','1','2','3','4','5','6','7','8','9'} ; unsigned int8 num_ss[] ; // mang so sanh unsigned int8 a = 0 ; // bien dem cac so nhap tu ban phim unsigned int8 b = 1 ; // bien dem so lan sai ma unsigned int8 d ; // bien ghi pass vao FLASH unsigned int8 g = 1 ; // bien thong bao ghi pass vao FLASH trong lan dau tien unsigned int8 h ; // bien luu lai tong cac so da ghi vao FLASH void LCD_Init ( void ); // ham khoi tao LCD void LCD_SetPosition ( unsigned int data );//Thiet lap vi tri con tro void LCD_PutChar ( unsigned int data ); // Ham viet1kitu/1chuoi len LCD void LCD_PutCmd ( unsigned int data ) ; // Ham gui lenh len LCD void tao_xung_E(); // Xung kich hoat void send_to_LCD( unsigned int data); // Dat du lieu len chan Data void delay_ms_INT(unsigned long i) { unsigned long k , j ; for(k=0;k<=i;k++) { for(j=0;j<=i;j++){;} } } void LCD_Init ( void ) { delay_ms(200); // thoi gian de LCD khoi dong output_low(RW); // RW = 0 output_low(RS); // che do gui lenh send_to_LCD( 0x00 ); output_high ( E ); output_low ( E ); delay_ms ( 10 ); send_to_LCD( 0x03 ); /* init with specific nibbles to start 4-bit mode */ output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E output_high ( E ); output_low ( E ); delay_ms ( 3 ); output_high ( E ); output_low ( E ); delay_ms ( 3 ); send_to_LCD( 0x02 ); /* set 4-bit interface */ output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E LCD_PutCmd ( 0x2C ); /* function set (all lines, 5x7 characters) */ LCD_PutCmd ( 0x0C); /* display ON, cursor off, no blink */ LCD_PutCmd ( 0x06 ); /* entry mode set, increment & scroll left */ LCD_PutCmd ( 0x01 ); /* clear display */ } void LCD_SetPosition ( unsigned int data ) { send_to_LCD( swap ( data ) | 0x08 ); output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E send_to_LCD( swap ( data ) ); output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E } void LCD_PutChar ( unsigned int data ) { output_high( RS ); //RS = 1 output_low ( RW ); //RW = 0 send_to_LCD( swap ( data ) ); // gui 4 bit cao output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E send_to_LCD( swap ( data ) ); //gui 4 bit thap output_high ( E ); output_low ( E ); delay_ms ( 3 ); // tao xung tren chan E } void LCD_PutCmd ( unsigned int data ) { output_low(RS); // RS = 0 output_low(RW); // RW = 0 send_to_LCD( swap(data) ); // gui 4 bit cao output_high (E); output_low (E); delay_ms (3); send_to_LCD( swap(data) ); // gui 4 bit thap output_high (E); output_low (E); delay_ms ( 3 ); } void send_to_LCD( unsigned int data ) { output_bit ( LCD_D4, data & 0x01 ); output_bit ( LCD_D5, data & 0x02 ); output_bit ( LCD_D6, data & 0x04 ); output_bit ( LCD_D7, data & 0x08 ); } void quetphim_hienthi() { PORTB = 0b111111110 ; if (RB4==0) { delay_ms_INT(50); while(RB4==0) continue ; delay_ms_INT(20); LCD_PutChar('0') ; key[a++] = num[0]; } ; if (RB5==0) { delay_ms_INT(50); while(RB5==0) continue ; delay_ms_INT(20); LCD_PutChar('3') ; key[a++] = num[3]; } ; if (RB6==0) { delay_ms_INT(50); while(RB6==0) continue ; delay_ms_INT(20); LCD_PutChar('6') ; key[a++] = num[6]; } ; if (RB7==0) { delay_ms_INT(50); while(RB7==0) continue ; delay_ms_INT(20); LCD_PutChar('9') ; key[a++] = num[9]; } ; PORTB = 0b111111101 ; if (RB4==0) { delay_ms_INT(50); while(RB4==0) continue ; delay_ms_INT(20); LCD_PutChar('1') ; key[a++] = num[1]; } ; if (RB5==0) { delay_ms_INT(50); while(RB5==0) continue ; delay_ms_INT(20); LCD_PutChar('4') ; key[a++] = num[4]; } ; if (RB6==0) { delay_ms_INT(50); while(RB6==0) continue ; delay_ms_INT(20); LCD_PutChar('7') ; key[a++] = num[7]; } ; PORTB = 0b111111011 ; if (RB4==0) { delay_ms_INT(50); while(RB4==0) continue ; delay_ms_INT(20); LCD_PutChar('2') ; key[a++] = num[2]; } ; if (RB5==0) { delay_ms_INT(50); while(RB5==0) continue ; delay_ms_INT(20); LCD_PutChar('5') ; key[a++] = num[5]; } ; if (RB6==0) { delay_ms_INT(50); while(RB6==0) continue ; delay_ms_INT(20); LCD_PutChar('8') ; key[a++] = num[8]; } ; } #int_RB void ngat_RB(void) { LCD_PutCmd(0x83); while (OK && CANCEL) quetphim_hienthi(); if(!CANCEL) goto THOAT ; if(!OK) {delay_ms_INT(50); while(!OK) continue ; delay_ms_INT(20); if(g == 1) { LCD_PutCmd(0x01); LCD_PutCmd(0xC0); LCD_PutChar('W') ; LCD_PutChar('r') ; LCD_PutChar('i') ; LCD_PutChar('t') ; LCD_PutChar('t') ; LCD_PutChar('i') ; LCD_PutChar('n') ; LCD_PutChar('g') ; LCD_PutChar(' ') ; LCD_PutChar('F') ; LCD_PutChar('L') ; LCD_PutChar('A') ; LCD_PutChar('S') ; LCD_PutChar('H') ; for (d=1;d<=a;d++) { write_eeprom(d,key[d]); PORTC = 0x08 ;delay_ms(250);PORTC = 0x00 ; }; g ++ ; h = a ; goto THOAT ; // luu lai tong cac so da nhan & THOAT }; if (a == h ) { LCD_PutCmd(0x01); LCD_PutCmd(0xC0); LCD_PutChar('R') ; LCD_PutChar('e') ; LCD_PutChar('a') ; LCD_PutChar('d') ; LCD_PutChar('i') ; LCD_PutChar('n') ; LCD_PutChar('g') ; LCD_PutChar(' ') ; LCD_PutChar('F') ; LCD_PutChar('L') ; LCD_PutChar('A') ; LCD_PutChar('S') ; LCD_PutChar('H') ; for (d=1;d<=a;d++) { num_ss[d]= read_eeprom(d);delay_ms(250); if(key[d]!=num_ss[d]) goto HERE ;}; LCD_PutCmd(0x01); LCD_PutCmd(0x84); LCD_PutChar('D') ; LCD_PutChar('U') ; LCD_PutChar('N') ; LCD_PutChar('G') ; LCD_PutChar(' ') ; LCD_PutChar('M') ; LCD_PutChar('A') ; PORTC = 0x08 ; delay_ms(2000) ; PORTC = 0x00 ; b = 1 ; goto THOAT ; HERE : LCD_PutCmd(0x01); LCD_PutCmd(0x84); LCD_PutChar('W') ; LCD_PutChar('R') ; LCD_PutChar('O') ; LCD_PutChar('N') ; LCD_PutChar('G') ; LCD_PutChar('!') ; delay_ms(1000) ; } ; if (a!=h ){ LCD_PutCmd(0x01); LCD_PutCmd(0x84); LCD_PutChar('S') ; LCD_PutChar('A') ; LCD_PutChar('I') ; LCD_PutChar(' ') ; LCD_PutChar('M') ; LCD_PutChar('A') ; delay_ms(1000) ; } ; } ; b ++ ; THOAT : a = 0 ; LCD_PutCmd(0x01); LCD_PutCmd(0xC5); LCD_PutChar('R') ; LCD_PutChar('e') ; LCD_PutChar('a') ; LCD_PutChar('d') ; LCD_PutChar('y') ; LCD_PutChar('!') ; if((b%4)==0) { PORTC = 0x04 ; delay_ms(1); PORTC = 0x00 ; b = 1 ; } ; } void main() { set_tris_A(0xFF); PORTA = 0xFF ; set_tris_B(0xF0); set_tris_C(0x00); PORTC = 0; set_tris_D(0x00); LCD_Init(); enable_interrupts(global); enable_interrupts(int_RB); ext_int_edge(H_to_L); LCD_PutCmd(0xC5); LCD_PutChar('R') ; LCD_PutChar('e') ; LCD_PutChar('a') ; LCD_PutChar('d') ; LCD_PutChar('y') ; LCD_PutChar('!') ; while(1){PORTB = 0xF0 ;} ; }
