Em dùng mplab x ide và mplab xc8
Sẵn cho em hỏi cách đưa code lên diễn đàn, tìm cách post code trong diễn đàn mà chưa thấy.
Cám ơn mọi người nhiều ạ.
PHẦN CHƯƠNG TRÌNH
#include<pic16f887.h>
#include<xc.h>
#include<stdio.h>
#include<stdlib.h>
// CONFIG1
#pragma config FOSC = XT // Oscillator Selection bits (XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = OFF // RE3/MCLR pin function select bit (RE3/MCLR pin function is digital input, MCLR internally tied to VDD)
#pragma config CP = OFF // Code Protection bit (Program memory code protection is disabled)
#pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled)
#pragma config BOREN = OFF // Brown Out Reset Selection bits (BOR disabled)
#pragma config IESO = OFF // Internal External Switchover bit (Internal/External Switchover mode is disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is disabled)
#pragma config LVP = OFF // Low Voltage Programming Enable bit (RB3 pin has digital I/O, HV on MCLR must be used for programming)
// CONFIG2
#pragma config BOR4V = BOR21V // Brown-out Reset Selection bit (Brown-out Reset set to 4.0V)
#pragma= OFF config WRT = OFF // Flash Program Memory Self Write Enable bits (Write protection
#define _XTAL_FREQ 4000000
void main (void)
void port_init();
void adc_init();
void in_init();
while(1){
__delay_ms(10);
GODONE = 1;
void port_init(void){
ANSEL = 0xO8;
ANSELH = 0;
TRISA2 = 1;
TRISE = 0;
PORTE = 0xff;
void adc_init(){
ADCON0bits.ADCS1 = 0;
ADCON0bits.ADCS0 = 1;
VCFG0 = 0;
VCFG1 = 0;
CHS3 = 0;
CHS2 = 0;
CHS1 = 1;
CHS0 = 0;
ADFM = 1;
ADON = 1;
__delay_ms(1);
void in_init(){
GIE = 1;
PEIE = 1;
ADIE = 1;
ADIF = 0;
void interrupt IRS(){
int adc_result;
if(PIE && ADIE && ADFE){
if (adc_result> 818)
PORTE=0b000; //Turn LEDs ON
else if(adc_result> 613)
PORTE=0b101;
else if(adc_result> 409)
PORTE=0b011;
else if(adc_result> 204)
PORTE=0b110;
PHẦN LỖI
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'E:/dien/nhap_project16f/adc_bai1.X'
make -f nbproject/Makefile-default.mk dist/default/production/adc_bai1.X.production.hex
make[2]: Entering directory 'E:/dien/nhap_project16f/adc_bai1.X'
"C:\Program Files (x86)\Microchip\xc8\v1.34\bin\xc8.exe" --pass1 --chip=16F877 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/adc.p1 adc.c
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1157 : warning: (111) redefining preprocessor macro "_ADCON0_GO_nDONE_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1248)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1158 : warning: (111) redefining preprocessor macro "_ADCON0_GO_nDONE_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1249)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1161 : warning: (111) redefining preprocessor macro "_ADCON0_GO_nDONE_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1252)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1162 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1253)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1163 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1254)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1164 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_SIZE" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1255)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1165 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_LENGTH" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1256)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1166 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1257)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1172 : warning: (111) redefining preprocessor macro "_ADCON0_GO_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1263)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1173 : warning: (111) redefining preprocessor macro "_ADCON0_GO_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1264)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1176 : warning: (111) redefining preprocessor macro "_ADCON0_GO_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1267)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1177 : warning: (111) redefining preprocessor macro "_ADCON0_CHS0_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1268)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1178 : warning: (111) redefining preprocessor macro "_ADCON0_CHS0_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1269)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1181 : warning: (111) redefining preprocessor macro "_ADCON0_CHS0_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1272)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1182 : warning: (111) redefining preprocessor macro "_ADCON0_CHS1_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1273)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1183 : warning: (111) redefining preprocessor macro "_ADCON0_CHS1_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1274)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1186 : warning: (111) redefining preprocessor macro "_ADCON0_CHS1_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1277)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1187 : warning: (111) redefining preprocessor macro "_ADCON0_CHS2_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1278)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1188 : warning: (111) redefining preprocessor macro "_ADCON0_CHS2_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1279)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1191 : warning: (111) redefining preprocessor macro "_ADCON0_CHS2_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1282)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1202 : warning: (111) redefining preprocessor macro "_ADCON0_nDONE_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1298)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1203 : warning: (111) redefining preprocessor macro "_ADCON0_nDONE_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1299)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1206 : warning: (111) redefining preprocessor macro "_ADCON0_nDONE_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1302)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1207 : warning: (111) redefining preprocessor macro "_ADCON0_GO_DONE_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1303)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1208 : warning: (111) redefining preprocessor macro "_ADCON0_GO_DONE_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1304)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1211 : warning: (111) redefining preprocessor macro "_ADCON0_GO_DONE_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1307)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2225 : warning: (111) redefining preprocessor macro "CHS0_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3655)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2227 : warning: (111) redefining preprocessor macro "CHS1_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3657)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2229 : warning: (111) redefining preprocessor macro "CHS2_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3659)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2259 : warning: (111) redefining preprocessor macro "GO_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3709)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2261 : warning: (111) redefining preprocessor macro "GO_DONE_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3711)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2263 : warning: (111) redefining preprocessor macro "GO_nDONE_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3713)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2591 : warning: (111) redefining preprocessor macro "nDONE_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 4213)
C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2224 : error: (1098) conflicting declarations for variable "CHS0" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2224 )
(908) exit status = 1
nbproject/Makefile-default.mk:94: recipe for target 'build/default/production/adc.p1' failed
make[2]: Leaving directory 'E:/dien/nhap_project16f/adc_bai1.X'
nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
make[1]: Leaving directory 'E:/dien/nhap_project16f/adc_bai1.X'
make[2]: *** [build/default/production/adc.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
BUILD FAILED (exit value 2, total time: 1s)
PHẦN CHƯƠNG TRÌNH
#include<xc.h>
#include<stdio.h>
#include<stdlib.h>
// CONFIG1
// CONFIG2
void main (void)
void port_init();
void adc_init();
void in_init();
while(1){
__delay_ms(10);
GODONE = 1;
ANSEL = 0xO8;
ANSELH = 0;
TRISA2 = 1;
TRISE = 0;
PORTE = 0xff;
void adc_init(){
VCFG0 = 0;
VCFG1 = 0;
CHS3 = 0;
CHS2 = 0;
CHS1 = 1;
CHS0 = 0;
ADFM = 1;
ADON = 1;
__delay_ms(1);
void in_init(){
GIE = 1;
PEIE = 1;
ADIE = 1;
ADIF = 0;
int adc_result;
PORTE=0b101;
PORTE=0b011;
PORTE=0b110;
PHẦN LỖI
