Cần sự chỉ đạo của các anh có kinh nghiệm
  • Cần sự chỉ đạo của các anh có kinh nghiệm
    machtest.DSN
    Đây là mạch test
    em đang lập trình AVR quét ADC 8 kênh để dò dường sao nó chạy chậm quá
    This program was produced by the
    CodeWizardAVR V2.03.4 Standard
    Automatic Program Generator
    © Copyright 1998-2008 Pavel Haiduc, HP InfoTech s.r.l.
    http://www.hpinfotech.com
    Project :
    Version :
    Date : 1/1/2007
    Author :
    Company :
    Comments:
    Chip type : ATmega16
    Program type : Application
    Clock frequency : 4.000000 MHz
    Memory model : Small
    External RAM size : 0
    Data Stack size : 256
    #include <mega16.h>
    #include <delay.h>
    int TAM[8]={0,0,0,0,0,0,0,0};
    eeprom int luu_ADC[8]={100,100,100,100,100,100,100,100};
    int ADC[8]={100,100,100,100,100,100,100,100};
    int L[8] ={0,0,0,0,0,0,0,0};
    int w[8] ={1,2,4,8,16,32,64,128};
    int sensor = 0B00000000;
    #define FIRST_ADC_INPUT 0
    #define LAST_ADC_INPUT 7
    unsigned char adc_data[LAST_ADC_INPUT-FIRST_ADC_INPUT+1];
    #define ADC_VREF_TYPE 0x20
    // ADC interrupt service routine
    // with auto input scanning
    interrupt [ADC_INT] void adc_isr(void)
    static unsigned char input_index=0;
    adc_data[input_index]=ADCH;
    if (++input_index > (LAST_ADC_INPUT-FIRST_ADC_INPUT))
    input_index=0;
    ADMUX=(FIRST_ADC_INPUT | (ADC_VREF_TYPE & 0xff))+input_index;
    delay_us(10);
    ADCSRA|=0x40;
    void doc_c_bien()
    L[0]=adc_data[0];
    L[1]=adc_data[1];
    L[2]=adc_data[2];
    L[3]=adc_data[3];
    L[4]=adc_data[4];
    L[5]=adc_data[5];
    L[6]=adc_data[6];
    L[7]=adc_data[7];
    void TB_ADC(int so_lan)
    int i=0,j=0,n=0;
    int max_cb[8]={0,0,0,0,0,0,0,0};
    int min_cb[8]={255,255,255,255,255,255,255,255};
    int MAX[8] ={0,0,0,0,0,0,0,0};
    int KQ_MAX[8]={0,0,0,0,0,0,0,0};
    for(n=0;n<so_lan;n++)
    for(j=0;j<100;j++)
    doc_c_bien();
    for(i=0;i<8;i++)
    if(max_cb[0]<L[0])
    {max_cb[0]=L[0];}
    if(min_cb[0]>L[0])
    {min_cb[0]=L[0];}
    if(max_cb[1]<L[1])
    {max_cb[1]=L[1];}
    if(min_cb[1]>L[1])
    {min_cb[1]=L[1];}
    if(max_cb[2]<L[2])
    {max_cb[2]=L[2];}
    if(min_cb[2]>L[2])
    {min_cb[2]=L[2];}
    if(max_cb[3]<L[3])
    {max_cb[3]=L[3];}
    if(min_cb[3]>L[3])
    {min_cb[3]=L[3];}
    if(max_cb[4]<L[4])
    {max_cb[4]=L[4];}
    if(min_cb[4]>L[4])
    {min_cb[4]=L[4];}
    if(max_cb[5]<L[5])
    {max_cb[5]=L[5];}
    if(min_cb[5]>L[5])
    {min_cb[5]=L[5];}
    if(max_cb[6]<L[6])
    {max_cb[6]=L[6];}
    if(min_cb[6]>L[6])
    {min_cb[6]=L[6];}
    if(max_cb[7]<L[7])
    {max_cb[7]=L[7];}
    if(min_cb[7]>L[7])
    {min_cb[7]=L[7];}
    MAX[0] = max_cb[0]+ MAX[0];
    MAX[1] = max_cb[1]+ MAX[1];
    MAX[2] = max_cb[2]+ MAX[2];
    MAX[3] = max_cb[3]+ MAX[3];
    MAX[4] = max_cb[4]+ MAX[4];
    MAX[5] = max_cb[5]+ MAX[5];
    MAX[6] = max_cb[6]+ MAX[6];
    MAX[7] = max_cb[7]+ MAX[7];
    for(i=0;i<8;i++)
    KQ_MAX[i] = MAX[i]/n;
    MAX[i]=0;
    for(i=0;i<8;i++)
    TAM[i]=(KQ_MAX[i] + min_cb[i])/2; //Approximation ADC
    void cam_bien()// Thoi gian de doc duoc ham nay la 276us
    sensor=0B00000000;
    L[0]=adc_data[0];
    L[1]=adc_data[1];
    L[2]=adc_data[2];
    L[3]=adc_data[3];
    L[4]=adc_data[4];
    L[5]=adc_data[5];
    L[6]=adc_data[6];
    L[7]=adc_data[7];
    if(L[0]<=luu_ADC[0])
    PORTC.0 = 1 ;
    else PORTC.0 = 0;
    if(L[1]<=luu_ADC[1])
    PORTC.1 = 1 ;
    else PORTC.1 = 0;
    if(L[2]<=luu_ADC[2])
    PORTC.2 = 1 ;
    else PORTC.2 = 0;
    if(L[3]<=luu_ADC[3])
    PORTC.3 = 1 ;
    else PORTC.3 = 0;
    if(L[4]<=luu_ADC[4])
    PORTC.4 = 1 ;
    else PORTC.4 = 0;
    if(L[5]<=luu_ADC[5])
    PORTC.5 = 1 ;
    else PORTC.5 = 0;
    if(L[7]<=luu_ADC[7])
    PORTC.7 = 1 ;
    else PORTC.7 = 0;
    if(L[6]<=luu_ADC[0])
    PORTC.6 = 1 ;
    else PORTC.6 = 0;
    void luu_CB()
    int i=0;
    for(i=0;i<8;i++)
    luu_ADC[i]=ADC[i];
    void main(void)
    PORTA=0x00;
    DDRA=0x00;
    PORTB=0x00;
    DDRB=0x00;
    PORTC=0xff;
    DDRC=0xFF;
    PORTD=0x00;
    DDRD=0x00;
    TCCR0=0x00;
    TCNT0=0x00;
    OCR0=0x00;
    TCCR1A=0x00;
    TCCR1B=0x00;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x00;
    OCR1BH=0x00;
    OCR1BL=0x00;
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00;
    MCUCR=0x00;
    MCUCSR=0x00;
    TIMSK=0x00;
    ACSR=0x80;
    SFIOR=0x00;
    ADMUX=FIRST_ADC_INPUT | (ADC_VREF_TYPE & 0xff);
    ADCSRA=0xCA;
    luu_CB();
    // Global enable interrupts
    #asm("sei")
    while (1)
    TB_ADC(10);
    doc_c_bien();
    cam_bien();
    em dùng codevisionAVR
    Khói nhựa thông che lấp đời trai trẻ.Dây thiếc hàn quấn chặt tuổi thanh xuân
    Bạn kích kép vào con Atmega 16 và thay đổi tần số thạch anh lên 8Mhz là nó nhanh hơn đó, mình đã thử cái của bạn rồi, mạch của bạn đang dùng thạch anh 1 Mhz thì nó chậm là đúng rồi, mà bạn chú ý khi khai báo tần số hoạt động ở Codevision thì khai báo tần số cao lên 1 chút thì nó sẽ xử lý nhanh hơn.
    Nhận làm mạch, ĐAMH sử dụng vđk Pic & AVR tại tp.HCM
    Liên hệ sđt: 0902.808.371
      thank bạn nhiều mình đã xử lí xong hóa ra không phải tại code mà bằng tại mạch mô phỏng. khổ thân làm mất cả đêm nghiên cứu
        là do thạch anh thấp quá đúng ko?
        conghuu196 Tìm hiểu thêm về conghuu196
