Giúp em xem code này sai ở đâu với
  • Giúp em xem code này sai ở đâu với
    các cao thủ xem giúp em chương trình này sai ở đâu với. em cám ơn!
    #include <AT89x52.h>
    //#include <Delay.h>
    #include "intrins.h"
    // Chuong trinh chuan tinh den ngay 11/05/2012
    #define dataso P1_2//P1_0
    #define clockso P1_0//P1_1
    #define latchso P1_1//P1_2
    #define phim1 P2_3//tang gia tri cham tien do
    #define phim2 P2_5// giam gia tri LED
    #define phim3 P2_7//tang chi so
    #define phim4 P2_6//tang gia tri LED
    #define phim5 P2_4// giam gia tri cham tien do
    #define phim6 P2_2// loi line reset gia tri ve 0
    #define SDA P0_4//P0_0
    #define SCL P0_3//P0_1
    #define On 1
    #define Off 0
    // DS1307
    #define psec 0x00
    #define pmin 0x01
    #define phour 0x02
    #define pday 0x03
    #define pdate 0x04
    #define pmonth 0x05
    #define pyear 0x06
    #define pcontrol 0x07
    #define stbangso 10
    #define soled 10
    unsigned char idata buffht[soled];
    unsigned char code SegCode[] = //4094
    {0x18,0xBD,0x68,0xA8,0x8D,0x8A,0x0A,0xBC,0x08,0x88 ,0xff,0xef};//, // 0,...,9,tat
    // {0x44, 0xcf, 0x52, 0x4a, 0xc9, 0x68, 0x60, 0xce, 0x40, 0x48, 0xff, 0xfb};//, // 0,...,9,tat
    //0x04, 0x8f, 0x12, 0x0a, 0x89, 0x28, 0x20, 0x8e, 0x00, 0x08, 0xff}; // 0.,...,9.,tat // dau gach duoi: 0xbf
    unsigned char code SegCode_cham[] =
    {0x10,0xB5,0x60,0xA0,0x85,0x82,0x02,0xB4,0x00,0x80 };
    unsigned char code SegCode_test[] = //4094
    {0xfe, 0xfd, 0xfb, 0xf7, 0xef, 0xdf, 0xbf, 0x7f};
    unsigned char tam1=0,tam2=0,tam3=0,tam4=0,tam5=0,tam6=0;
    unsigned char i,adr_so,chiso,dem;
    unsigned char gio,phut,giay,ngay,thang,nam,ngay1,ngay2,bienngay1 ,bienngay2,bienngay3;
    unsigned int num,bienngay;
    unsigned int linerank;
    bit nhapnhay = 0;
    //============= RTC DS1307 ==================
    void start(void)
    SCL=0;
    SDA=1;
    _nop_();_nop_();_nop_();
    SCL=1;
    SCL=1;
    SDA=0;
    SCL=0;
    void stop(void)
    SCL=0;
    SDA=0;
    SCL=1;
    SCL=1;
    SDA=1;
    SCL=0;
    bit write_data(unsigned char chr)
    unsigned char temp,ack;
    for(temp=0;temp<8;temp++)
    SDA = (chr & 0x80);
    SCL=1;
    SCL=0;
    chr=chr<<1;
    SDA=1;
    SCL=1;
    ack=SDA;
    SCL=0;
    return(ack);
    unsigned char convertBCD(unsigned char _data)
    unsigned char temp;
    temp=(_data/10<<4)|(_data%10&0x0F);
    return temp;
    unsigned char read_data(void)
    unsigned char temp1,temp2=0;
    for(temp1=0;temp1<8;temp1++)
    SCL=1;
    temp2=temp2<<1;
    temp2=temp2|((unsigned char)(SDA));
    SCL=0;
    return(temp2);
    void write_RTC(unsigned char address, unsigned char _data)
    bit status;
    start();
    write_data(0xD0);
    write_data(address);
    write_data(_data);
    stop();
    start();
    status=write_data(0xD0);
    while(status) //status = 1 (NACK)
    start();
    status=write_data(0xd0);
    unsigned char read_RTC(unsigned char address)
    unsigned char k;
    start();
    write_data(0xD0);
    start();
    write_data(0xD1);
    k=read_data();
    stop();
    return ((k>>4)*10+(k&0x0F));
    unsigned char read_RTC_chuan(unsigned char address)
    unsigned char k;
    start();
    write_data(0xD0);
    start();
    write_data(0xD1);
    k=read_data();
    stop();
    return k;
    void init_RTC(void)
    // cai dat ngay theo chuan thuc te
    write_RTC(0x07,0x10);
    write_RTC(0x00,0x00); //0s
    write_RTC(0x01,0x39); // phut :23
    write_RTC(0x02,0x20); // h : 20
    write_RTC(0x04,0x19); // ngay : 12
    write_RTC(0x05,0x01); // thang :01
    write_RTC(0x06,0x11); // nam : 2011/
    //write_RTC(stbangso,10);
    //write_RTC(stbangso+1,0);
    //write_RTC(stbangso+2,0);
    //////End DS1307//////////
    void quetled (void)
    unsigned char led1, led2, t;
    // doc lich!
    /*giay =read_RTC(0x00);
    phut =read_RTC(0x01);
    gio =read_RTC(0x02);
    ngay =read_RTC(0x04);
    thang=read_RTC(0x05);
    nam =read_RTC(0x06);
    buffht[0] = ngay/10;
    buffht[1] = ngay%10;
    buffht[2] = thang/10;
    buffht[3] = thang%10;
    buffht[4] = nam/10;
    buffht[5] = nam%10;
    buffht[6] = phut/10;
    buffht[7] = phut%10;
    buffht[8] = giay/10;
    buffht[9] = giay%10;*/
    for(t=0; t<soled; t++)
    if(chiso==t)
    if(nhapnhay) led1 = SegCode[buffht[chiso]];
    else led1 = 0xff; //tat
    else led1 = SegCode[buffht[t]]; // giu nguyen gia tri
    led2 = 0x80;
    loop_time: // dich tung bit dua ra led
    dataso = led1 & led2;
    clockso =1;
    led2 = led2 >> 1;
    clockso =0;
    if(led2) goto loop_time;
    latchso =1;
    _nop_();_nop_();_nop_();_nop_();
    latchso =0;
    void quetled_moi (void)
    unsigned char led1, led2, t,t_moi;
    // doc lich!
    buffht[4] = nam/10;
    buffht[5] = nam%10;
    for(t_moi=0; t_moi<soled; t_moi++)
    if (t_moi==0){t=8;}
    if (t_moi==1){t=4;}
    if (t_moi==2){t=0;}
    if (t_moi==3){t=5;}
    if (t_moi==4){t=3;}
    if (t_moi==5){t=7;}
    if (t_moi==6){t=9;}
    if (t_moi==7){t=2;}
    if (t_moi==8){t=1;}
    if (t_moi==9){t=6;}
    if(chiso==t)
    led2 = 0x80;
    if (t==1){led1=SegCode_cham[buffht[t]];}
    clockso =1;
    led2 = led2 >> 1;
    clockso =0;
    latchso =1;
    latchso =0;
    void delay_ms(int i)
    int j;
    for(j=1;j<=i;j++){}
    void main (void)
    P0=0xff; // P0 la dau vao
    P1=0x00; // P1,P2,P3 la dau ra
    P2=0xff; //P2 la dau vao bam so
    P3=0x00;
    init_RTC();while(1){} // cai dat ngay chuan theo ngay thuc te
    // cai 1 lan cho moi con DS1307
    // Chay test
    /*linerank=read_RTC(0x00);
    while (1)
    buffht[2]=linerank%10;
    buffht[1]=linerank/10;
    quetled_moi();
    //nap DS
    /*write_RTC(stbangso,10);
    write_RTC(stbangso+3,0);
    write_RTC(stbangso+4,0);
    write_RTC(stbangso+5,0);
    write_RTC(stbangso+6,0);
    write_RTC(stbangso+7,0);
    write_RTC(stbangso+8,0);
    write_RTC(stbangso+9,0);
    init_RTC();while(1){}*/
    // load du lieu tu ROM ra
    adr_so=stbangso;
    for(i=0;i<soled;i++)
    buffht[i]=read_RTC_chuan(adr_so);
    adr_so++;
    chiso = soled;
    dem = 0; //dem thoi gian nhap nhay
    while(1)
    dem++;
    if(dem==100) nhapnhay = ~nhapnhay;
    if(dem>200) {nhapnhay = ~nhapnhay; dem=0;}
    phut =read_RTC(0x04);////////doc trang thai chuyen doi tang
    /////0x04 ngay; 0x00 giay;0x01 phut;0x02 gio
    ngay1=read_RTC_chuan(stbangso+12);
    ngay2=read_RTC_chuan(stbangso+13);
    if (phut != ((ngay1*10)+ngay2))
    write_RTC(stbangso+12,phut/10);
    write_RTC(stbangso+13,phut%10);
    bienngay1=read_RTC_chuan(stbangso+5);
    bienngay2=read_RTC_chuan(stbangso+6);
    bienngay3=read_RTC_chuan(stbangso+7);
    bienngay = bienngay1*100 + bienngay2*10 + bienngay3;
    bienngay++;
    write_RTC(stbangso+5,(bienngay/100));
    write_RTC(stbangso+6,(bienngay%100)/10);
    write_RTC(stbangso+7,(bienngay%10));
    buffht[5] = bienngay/100;
    buffht[6] = (bienngay%100)/10;
    buffht[7] = bienngay%10;
    //quetled();
    quetled_moi();
    // co phim an
    if ((phim1==0) | (phim2==0) | (phim3==0) | (phim4==0) | (phim5==0) | (phim6==0))
    delay_ms(100);
    if (phim3 == 0) //tang chiso
    if (chiso == soled) chiso = 3;
    else chiso++;
    else if (phim4 == 0)//tang gia tri cuar LED
    if (chiso != soled)
    if (buffht[chiso] >= 9) buffht[chiso] = 0;
    else buffht[chiso] = buffht[chiso] + 1;
    adr_so = stbangso + chiso;
    write_RTC(adr_so,buffht[chiso]);
    else if (phim2 == 0)//giam gia tri cua LED
    if (chiso != soled)
    if (buffht[chiso] == 0) buffht[chiso] = 9;
    else buffht[chiso] = buffht[chiso] - 1;
    else if (phim6 == 0)//co loi line reset so ngay ve 0
    buffht[5] = 0;
    buffht[6] = 0;
    buffht[7] = 0;
    num = buffht[8]*10 + buffht[9];
    if (num == 99) num = 0;
    else num++;
    buffht[8] = (num%100)/10;
    write_RTC(stbangso+8,buffht[8]);
    buffht[9] = num%10;
    write_RTC(stbangso+9,buffht[9]);
    else if (phim1 == 0)//tang gia tri cham tien do
    if (buffht[0] == 10)
    num = buffht[1]*10 + buffht[2];
    else num++;
    else if (buffht[0] == 11)
    if (num == 1)
    num = 0;
    buffht[0] = 10;
    else num--;
    write_RTC(stbangso,buffht[0]);
    buffht[1] = num/10;
    write_RTC(stbangso+1,buffht[1]);
    buffht[2] = num%10;
    write_RTC(stbangso+2,buffht[2]);
    else if (phim5 == 0)// giam gia tri cham tien do
    if (num == 0)
    num = 1;
    buffht[0] = 11;
    else num--;
    if (num == 99)
    num = 0;
    buffht[0] = 10;
    else num++;
    buffht[1] = num/10;
    buffht[2] = num%10;
    //quetled_moi();
    while((phim1==0) | (phim2==0) | (phim3==0) | (phim4==0) | (phim5==0) | (phim6==0)); // doi thoat phim
    delay_ms(500);
    delay_ms(500);
    }// while (1)
    } // of main
    Bùm!..................
      Nguyên văn bởi ngochanpt89 Xem bài viết
      Không có lỗi, chỉ có cảnh báo:
      Build target 'Target 1'
      compiling help.c...
      linking...
      *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
      SEGMENT: ?PR?_CONVERTBCD?HELP
      SEGMENT: ?PR?_READ_RTC_CHUAN?HELP
      SEGMENT: ?PR?QUETLED?HELP
      SEGMENT: ?PR?QUETLED_MOI?HELP
      SEGMENT: ?PR?_DELAY_MS?HELP
      Program Size: data=46.2 xdata=0 code=910
      creating hex file from "help"...
      "help" - 0 Error(s), 5 Warning(s).
      WS:
      Blog:
        đúng là không có lỗi chỉ có cảnh báo thôi ! mà bạn đưa nguyên cái source nhìn muốn đi ngủ quá
        Email :
        Phone : 0902 5777 39
        Branch: LẬP TRÌNH CÁC DÒNG CHIP NXP, ST, ATMEL
        ngochanpt89 Tìm hiểu thêm về ngochanpt89
          hôm nay, 07:44
