Làm sao lấy thứ của DS1307.
    không hiểu sao em không đưa đươc ảnh lên.nhưng em mô phỏng thì khi em gán thứ 7 sau khi hết ngày đó thì nó lại chuyển sang thứ o.rồi tăng dần lên 1,2,3...7,0,1,2,3....
    code của em.
    #include <mega16.h>
    #include <delay.h>
    // I2C Bus functions
    #include <i2c.h>
    // DS1307 Real Time Clock functions
    #include <ds1307.h>
    // Alphanumeric LCD functions
    #include <alcd.h>
    #define FIRST_ADC_INPUT 0
    #define LAST_ADC_INPUT 1
    unsigned char adc_data[LAST_ADC_INPUT-FIRST_ADC_INPUT+1];
    #define ADC_VREF_TYPE 0xE0
    unsigned char h,m,s,day,date,month,year;
    // ADC interrupt service routine
    // with auto input scanning
    interrupt [ADC_INT] void adc_isr(void)
    static unsigned char input_index=0;
    // Read the 8 most significant bits
    // of the AD conversion result
    adc_data[input_index]=ADCH;
    // Select next ADC input
    if (++input_index > (LAST_ADC_INPUT-FIRST_ADC_INPUT))
    input_index=0;
    ADMUX=(FIRST_ADC_INPUT | (ADC_VREF_TYPE & 0xff))+input_index;
    // Delay needed for the stabilization of the ADC input voltage
    delay_us(10);
    // Start the AD conversion
    ADCSRA|=0x40;
    // Declare your global variables here
    void putnum(unsigned char so)
    unsigned char chuc,dv;
    chuc=so/10;
    dv=(so-10*chuc);
    lcd_putchar(chuc+48);
    lcd_putchar(dv+48);
    void putnum1(unsigned char so1)
    unsigned char tram,chuc,dv;
    tram=so1/100;
    chuc=(so1-100*tram)/10;
    dv=(so1-10*chuc-100*tram);
    lcd_putchar(tram+48);
    lcd_putchar(dv+48);
    void main(void)
    PORTA=0x00;
    DDRA=0x00;
    PORTB=0x00;
    DDRB=0xff;
    PORTC=0x00;
    DDRC=0xff;
    PORTD=0x00;
    DDRD=0xff;
    ADMUX=(FIRST_ADC_INPUT | (ADC_VREF_TYPE & 0xff);
    ADCSRA=0xCB;
    // I2C Bus initialization
    // I2C Port: PORTC
    // I2C SDA bit: 1
    // I2C SCL bit: 0
    // Bit Rate: 100 kHz
    // Note: I2C settings are specified in the
    // Project|Configure|C Compiler|Libraries|I2C menu.
    i2c_init();
    // DS1307 Real Time Clock initialization
    // Square wave output on pin SQW/OUT: On
    // Square wave frequency: 1Hz
    rtc_init(0,0,0);
    // Alphanumeric LCD initialization
    // Connections are specified in the
    // Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
    // RS - PORTB Bit 0
    // RD - PORTB Bit 1
    // EN - PORTB Bit 2
    // D4 - PORTB Bit 4
    // D5 - PORTB Bit 5
    // D6 - PORTB Bit 6
    // D7 - PORTB Bit 7
    // Characters/line: 16
    lcd_init(16);
    lcd_clear();
    rtc_set_time(23,59,57);
    rtc_set_date(7,3,5,13);
    // Global enable interrupts
    #asm("sei")
    while (1)
    // Place your code here
    rtc_get_time(&h,&m,&s);
    rtc_get_date(&day,&date,&month,&year);
    lcd_gotoxy(0,0);
    putnum(h);
    lcd_putsf(":");
    putnum(m);
    lcd_putsf(":");
    putnum(s);
    lcd_putsf(" Thu ");
    putnum(day);
    lcd_gotoxy(0,1);
    putnum(date);
    lcd_putsf("-");
    putnum(month);
    lcd_putsf("-");
    lcd_putsf("20");
    putnum(year);
    lcd_putsf(" NT:");
    putnum1(adc_data[0]);
    delay_ms(100);
    hohoanganhfu Trường ĐH khoa Hoc Tự Nhiên Tìm hiểu thêm về hohoanganhfu
