có ai ko ạ...............
Hỏi về giao tiếp AVR và module SIMCOM
Nguyên văn bởi demon52 Xem bài viếtLuồng lập từ 7/2012 mà vẫn chưa làm xong à @@
Tập lệnh hay dùng nhất!
1. Test Commands:
AT Command Description
AT Check communication between the module and PC/Microcontroller.
ATD<Caller Phone Number>; Call to phone number. Ex: ATD0988434887;
ATDL Reial last telephone number.
ATI Display Product Identification Information. Ex: Return:SIM900 R11.0
AT&V Display Current Configuration.
AT+GSV Display Product Identification Information. Ex: SIMCOM_Ltd - SIMCOM_SIM908 - Revision:1137B02SIM908M64_ST
AT+CSQ Signal Quality Report.Ex: +CSQ: 28,0 (<99 Signal is good)
AT+CPIN? Check Sim status. Ex: +CPIN: READY
AT+IPR? Check(Test/Set/Read) Baud rate. Ex: +IPR: 0(Auto_bauding)
AT+CSCA? SMS Service Center Address. Ex: +CSCA: "+84980200030",145
AT+CMTE? Read the temperature when the module is running. Ex: +CMTE: 0,38
AT+CGREG? Network Registration Status. Return: +CREG: 1,1 - Enable Network and Registed.
AT+CGMI Get manufacturer information. Ex: SIMCOM_Ltd
AT+CGMR Get software version. Ex: Revision:1137B02SIM908M64_ST
AT+CGSN Get device IMEI. 861001000034104
AT+COPS? Display the current network operation: +COPS: 0,0,"VNM and VIETTEL"
Trên dây là 1 s? l?nh d? các b?n Test vi?c giao ti?p gi?a PC/Microcontroller v?i SIM908.
2. Configuration Command:
* These AT Command will be used in the first times to configuration for SIM908.
1. ATZ Reset default configuration.
2 Echo:
- ATE0 Echo Off. //N?u mu?n t?t Echo
- ATE1 Echo ON.//N?u mu?n m? Echo
3. AT+CLIP=1 Enable display phone number of calling.
4. AT&W Save Active(ATE0 and AT+CLIP=1) Profile.
5. AT+CMGF=1 SMS Text Mode.
6. New message indication:
- AT+CNMI=1,1,0,0,0 New message indication enable and select SIM memory storage.
Return only: +CMTI: "SM",<index>(+CMTI: "SM",1)
Or:
- AT+CNMI=2,0,0,0,0 New message indication enable and select SIM memory storage.
Return:+CMT: "+84988434887","","12/04/21,17:00:26+28"[Noi dung tin nhan]
7.AT+CSAS Save SMS Setting.Web:
->Nhận thiết kế, hoàn thiện dự án, sản phẩm điện tử<-
-->Giải pháp GSM/GPRS/GPS - Công nghệ RFID<--
không hiểu sao mình gửi lệnh
UART_init();
UART_tx_rx_on();
UART_putchar('A');
delay_ms(1000);
UART_putchar('T');
delay_ms(1000);
UART_putchar('D');
delay_ms(1000);
UART_putchar('0');
delay_ms(1000);
UART_putchar('9');
delay_ms(1000);
UART_putchar('8');
delay_ms(1000);
UART_putchar('8');
delay_ms(1000);
UART_putchar('6');
delay_ms(1000);
UART_putchar('0');
delay_ms(1000);
UART_putchar('0');
delay_ms(1000);
UART_putchar('5');
delay_ms(1000);
UART_putchar('2');
delay_ms(1000);
UART_putchar('4');
delay_ms(1000);
UART_putchar(';');
delay_ms(1000);
UART_putchar('\n');
delay_ms(1000);
UART_putsf(CR);
delay_ms(10000);
mà sao lại hiển thị như thế bạn mấy bạn
Ko cần phải delay sau mỗi lần gửi kí tự đâu. Trong IDE đọc phần fprintf(Uart_Stream,"AT/r"); vầy là xong nè... ko nhớ viết đúng ko nữa nhưng na ná thế.Web:
Bạn có thể download phần mềm giao tiếp với Module SIM ở đây, soft do mình viết chạy ổn định trên module SIM900/908
Link software: Phần mềm test giao tiếp UART, GSM, USB | VnTech24hWeb:
Nguyên văn bởi hitechvn Xem bài viếtĐúng rồi bên Hoàng Phát ở gần Thủ Lệ có bán module này. Giao tiếp rs232 giá 850K.
. Em đang làm cái này , mua đồ làm mạch hết ùi, ngồi nghiên cứu cả tháng trời mà chẵng đâu vào đâu + ngâm cứu bài viết này từ đầu tới giờ mà vẩn không hiểu, ai giúp em với...
Nguyên văn bởi congphap245 Xem bài viếtMax thế. ở chổ banlinhkien.vn bán co 650k mà mạch làm đầy đủ và rất tốt nữa
. Em đang làm cái này , mua đồ làm mạch hết ùi, ngồi nghiên cứu cả tháng trời mà chẵng đâu vào đâu + ngâm cứu bài viết này từ đầu tới giờ mà vẩn không hiểu, ai giúp em với...(^_^) hoangnv.3i@gmail.com
hôm nay, 14:39 -
hôm nay, 14:28 -
Hôm qua, 20:26 -
Hôm qua, 12:32 -
20-02-2025, 21:31 -
20-02-2025, 11:52 -
19-02-2025, 21:27 -
19-02-2025, 21:24 -
