Mọi người giúp mình với.
  • Mọi người giúp mình với.
    Mình đang làm một cái đồng hồ sử dụng atmega8. Nhưng nó không chạy có lẽ do code sai. moi người xem hộ mình với. Đây là code và mô phỏng.
    PHP Code:
    This program was produced by the
    CodeWizardAVR V2.05.0 Professional
    Automatic Program Generator
    © Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l.
    http://www.hpinfotech.com
    Project :
    Version :
    Date    : 26/05/2013
    Author  : NeVaDa
    Company :
    Comments:
    Chip type               : ATmega8L
    Program type            : Application
    AVR Core Clock frequency: 4,000000 MHz
    Memory model            : Small
    External RAM size       : 0
    Data Stack size         : 256
    #include <mega8.h>
    #include <delay.h>
    // I2C Bus functions
    #asm
    .equ __i2c_port=0x15 ;PORTC
    .equ __sda_bit=4
    .equ __scl_bit=5
    #endasm
    #include <i2c.h>
    // DS1307 Real Time Clock functions
    #include <ds1307.h>
    // Timer1 output compare A interrupt service routine
    #define FIRST_ADC_INPUT 0
    #define LAST_ADC_INPUT 1
    unsigned char adc_data[LAST_ADC_INPUT-FIRST_ADC_INPUT+1];
    #define ADC_VREF_TYPE 0x20
    // ADC interrupt service routine
    // with auto input scanning
    interrupt [ADC_INTvoid adc_isr(void)
    static
    unsigned char input_index=0;
    // Read the 8 most significant bits
    // of the AD conversion result
    adc_data[input_index]=ADCH;
    // Select next ADC input
    if (++input_index > (LAST_ADC_INPUT-FIRST_ADC_INPUT))
    input_index=0;
    ADMUX=(FIRST_ADC_INPUT | (ADC_VREF_TYPE 0xff))+input_index;
    // Delay needed for the stabilization of the ADC input voltage
    delay_us(10);
    // Start the AD conversion
    ADCSRA|=0x40;
    // SPI functions
    #include <spi.h>
    // Declare your global variables here
    // khai báo bien, mang toan cuc
    #define latch         PORTB.2
    #define MODE     PINB.0
    #define UP            PINB.6
    #define DOWN     PINB.7
    #define SET          PINB.1
    bit AP;                           // che do 24h (1), che do 12h(0)
    bit sb;                            // sb=1: phim duoc nhan; sb=0; phim khong dc nhan
    unsigned int a,b,c,d=0;
    unsigned char hour,min,sec,temp,i,mode=0,h;
    unsigned char led7seg[13]=
    // MANG CÁC GIA TRI LED 7SEG TU SO 0- SO 9,ki tu "C" ,"N","NULL"
      // Dau cham mac dinh khong sang nên bit 8 de gia tri"1"
    0b11000000// so "0"
    0b11111001// so "1"
    0b10100100// so "2"
    0b10110000// so "3"
    0b10011001// so "4"
    0b10010010// so "5"
    0b10000010// so "6"
    0b11011000// so "7"
    0b10000000// so "8"
    0b10010000// so "9"
    0b11000110// chu "C"
    0b11001000// chu "N"
    0b11111111  // "NULL"
    unsigned char array_led[6];      // mang chua 6 led 7seg can hien thi
    // chuyen doi che do gio 24h <=> 12h
    // AP=1: che do 24h; AP=0: che do 12h
    void check_conveter_hour(void)
    // kiem tra che do gio: 24h or 12h
    if(AP==0)       // che do 12h
      if(
    hour==0)
    h=12;
      else
       if(
    hour>12)
    h=hour-12;
       else
    h=hour;
     else
    // che do 24h
    h=hour;
    void display_temp_lcd(void)
    temp=0.49*adc_data[0];                           // Nhiet do, giá tri 0,49 khi chon ADC 10bit
    a=temp/1000;
    b=(temp-1000*a)/100;
    c=(temp-1000*a-100*b)/10;
    d=(temp-1000*a-100*b-10*c);
    // ctc chot du lieu 74HC595
    void latch_data(void)
    latch=0;
    latch=1;
    // ctc chuyen doi thoi gian  sang ma 7seg
    void bin2_7seg(void)
    display_temp_lcd();
    array_led[0]=led7seg[min%10];        // phan don vi cua phut
    array_led[1]=led7seg[min/10];        // phan chuc cua phut
    array_led[2]=led7seg[h%10];          // phan don vi cua gio
    array_led[3]=led7seg[h/10];          // phan chuc cua gio
    if(a==0&&b==0&&c==0)                 // Nêu nhiet do nho hon 10 thi hien thi 1 chu so
    array_led[4]=led7seg[d];            // phan don vi cua nhiet do
    array_led[5]=led7seg[12];           // phan chuc cua nhiet do
      else
    array_led[5]=led7seg[c];            // phan chuc cua nhiet do
    void display_led7seg(void)         // ctc hien thi len led7seg
    PORTD.3=0;
    bin2_7seg();                     // chuyen doi tu bin sang ma 7seg
    spi(array_led[i]);               // xuat du lieu ra 595 dua den led7seg thu i
    latch_data();                    // chot du lieu ra 595
    PORTD=i;
    PORTD.3=1;                       // enable 74hc138 chon led can hien thi
    if(i==6)
    i=0;
      else
    i++;
    // chuong trinh con kiem tra trang thai cua phim nhan : bit trang thai sb
    void status_button(void)
      if(
    MODE&&UP&&DOWN&&SET)
    sb=0;  //  kiem tra phim da nha hay chua?
    // ctc test phim ( cai dat thoi gian, bao thuc )
    void set_alarm_time(void)
    status_button();            // goi ctc kiem tra trang thai phim nhan
     // doan chuong trinh chuyen doi che do gio: 24h/12h
    if(SET==0&&sb==0)
    AP=~AP;
    sb=1;         // bat trang thai co phim nhan  sb=1;
     // doan chuong trinh chon che do
    if(MODE==0&&sb==0)
       if(
    mode==5)            //  che do nguoi dung
    mode=0;
       else
    mode++;
    sb=1;                 // bao co phim nhan
     // doan chuong trinh cho che do 1(mode=1):
    if(mode==1)                               // chinh gio
    if(UP==0&&sb==0)                // phim "UP" nhan
       if(
    hour==23)
    hour=0;
       else
    hour++;
    rtc_set_time(hour,min,sec);    // dat lai gio
    if(DOWN==0&&sb==0)        // phim "DOWN" nhan
       if(
    hour==0)
    hour=23;
       else
    hour--;
    rtc_set_time(hour,min,sec);    // dat lai time
    sb=1;
     // doan chuong trinh cho che do 2(mode=2):
    if(mode==2)                               // chinh phut
       if(
    min==59)
    min=0;
       else
    min++;
      if(
    min==0)
    min=59;
      else
    min--;
    sb=1;
    interrupt [TIM1_COMPAvoid timer1_compa_isr(void)
    // Place your code here
    display_led7seg();
    void main(void)
    // Declare your local variables here
    // Input/Output Ports initialization
    // Port B initialization
    // Func7=In Func6=In Func5=Out Func4=Out Func3=Out Func2=Out Func1=In Func0=In
    // State7=T State6=T State5=1 State4=1 State3=1 State2=1 State1=T State0=T
    PORTB=0x3C;
    DDRB=0x3C;
    // Port C initialization
    // Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
    // State6=T State5=T State4=T State3=T State2=T State1=T State0=T
    PORTC=0x00;
    DDRC=0x00;
    // Port D initialization
    // Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
    // State7=1 State6=1 State5=1 State4=1 State3=1 State2=1 State1=1 State0=1
    PORTD=0xFF;
    DDRD=0xFF;
    // Timer/Counter 0 initialization
    // Clock source: System Clock
    // Clock value: Timer 0 Stopped
    TCCR0=0x00;
    TCNT0=0x00;
    // Timer/Counter 1 initialization
    // Clock value: 62,500 kHz
    // Mode: CTC top=OCR1A
    // OC1A output: Discon.
    // OC1B output: Discon.
    // Noise Canceler: Off
    // Input Capture on Falling Edge
    // Timer1 Overflow Interrupt: Off
    // Input Capture Interrupt: Off
    // Compare A Match Interrupt: On
    // Compare B Match Interrupt: Off
    TCCR1A=0x00;
    TCCR1B=0x0B;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x00;
    OCR1BH=0x00;
    OCR1BL=0x00;
    // Timer/Counter 2 initialization
    // Clock value: Timer2 Stopped
    // Mode: Normal top=0xFF
    // OC2 output: Disconnected
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00;
    // External Interrupt(s) initialization
    // INT0: Off
    // INT1: Off
    MCUCR=0x00;
    // Timer(s)/Counter(s) Interrupt(s) initialization
    TIMSK=0x10;
    // USART initialization
    // USART disabled
    UCSRB=0x00;
    // Analog Comparator initialization
    // Analog Comparator: Off
    // Analog Comparator Input Capture by Timer/Counter 1: Off
    ACSR=0x80;
    SFIOR=0x00;
    // ADC initialization
    // ADC Clock frequency: 1000,000 kHz
    // ADC Voltage Reference: AREF pin
    // Only the 8 most significant bits of
    // the AD conversion result are used
    ADMUX=FIRST_ADC_INPUT | (ADC_VREF_TYPE 0xff);
    ADCSRA=0xCA;
    // SPI initialization
    // SPI Type: Master
    // SPI Clock Rate: 2*1000,000 kHz
    // SPI Clock Phase: Cycle Half
    // SPI Clock Polarity: Low
    // SPI Data Order: MSB First
    SPCR=0x54;
    SPSR=0x01;
    // TWI initialization
    // TWI disabled
    TWCR=0x00;
    // I2C Bus initialization
    i2c_init();
    // DS1307 Real Time Clock initialization
    // Square wave output on pin SQW/OUT: On
    // Square wave frequency: 1Hz
    rtc_init(0,1,0);
    // Global enable interrupts
    #asm("sei")
    while (1)
    rtc_get_time(&hour,&min,&sec);                   // Doc gio, phut, giay tu ds1307
    check_conveter_hour();
    set_alarm_time();                                            // goi ctc thuc hien cai dat
    if(mode==0)                                                    // O che do hien thi binh thuong
    display_led7seg();                                             // Hien thi thoi gian len lcd
           else
    // chuyen sang che do set
    CUNG CẤP LINH KIỆN ĐIỆN TỬ. DỤNG CỤ LÀM MẠCH.
    CUNG CẤP LED, MẠCH CÔNG SUẤT.
    CUNG CẤP MODULE LED (TRÁI TIM, CUBE)
    ------------TẠI HẠ LONG------------------
    LIÊN HỆ: 0936524718
buitrongthie Tìm hiểu thêm về buitrongthie
