e vừa tìm đc code này.... mấy pro xem giùm e có ổn không nha
volatile byte rpmcount;
unsigned int rpm;
unsigned long timeold;
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
void rpm_fun()
//Each rotation, this interrupt function is run twice, so take that into consideration for
//calculating RPM
//Update count
rpmcount++;
void setup()
lcd.begin(16, 2); // intialise the LCD
//Interrupt 0 is digital pin 2, so that is where the IR detector is connected
//Triggers on FALLING (change from HIGH to LOW)
attachInterrupt(0, rpm_fun, FALLING);
rpmcount = 0;
rpm = 0;
timeold = 0;
void loop()
//Update RPM every second
delay(1000);
//Don't process interrupts during calculations
detachInterrupt(0);
//Note that this would be 60*1000/(millis() - timeold)*rpmcount if the interrupt
//happened once per revolution instead of twice. Other multiples could be used
//for multi-bladed propellers or fans
rpm = 30*1000/(millis() - timeold)*rpmcount;
timeold = millis();
rpmcount = 0;
//Print out result to lcd
lcd.clear();
lcd.print("RPM=");
lcd.print(rpm);
//Restart the interrupt processing
unsigned int rpm;
void rpm_fun()
//calculating RPM
//Update count
rpmcount++;
void setup()
rpmcount = 0;
rpm = 0;
timeold = 0;
void loop()
delay(1000);
detachInterrupt(0);
timeold = millis();
rpmcount = 0;
lcd.clear();
lcd.print("RPM=");
lcd.print(rpm);
