Mình dùng atmega 8 và ir sensor hàn theo hình sau
IR sensor mình đọc = arduino vẫn bình thường, nhưng đọc bằng atmega8 qua lcd thì chỉ hiện ra giá trị 1023. (Code này mình đọc giá trị biến trở qua Proteus thì vẫn ok)
This program was produced by the
CodeWizardAVR V2.05.0 Professional
Automatic Program Generator
© Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l.
HP InfoTech - CodeVisionAVR C Compiler
Project :
Version :
Date : 8/15/2014
Author : NeVaDa
Company :
Comments:
Chip type : ATmega8
Program type : Application
AVR Core Clock frequency: 8.000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega8.h>
#include <delay.h>
// Alphanumeric LCD Module functions
#include <alcd.h>
#define ADC_VREF_TYPE 0x00
// Read the AD conversion result
unsigned int read_adc(unsigned char adc_input)
ADMUX=adc_input | (ADC_VREF_TYPE & 0xff);
// Delay needed for the stabilization of the ADC input voltage
delay_us(10);
// Start the AD conversion
ADCSRA|=0x40;
// Wait for the AD conversion to complete
while ((ADCSRA & 0x10)==0);
ADCSRA|=0x10;
return ADCW;
// Declare your global variables here
int adc = 0;
void lcd_putnum(unsigned int z)
unsigned int nghin, tram, chuc, dv;
nghin = z/1000;
tram = (z%1000)/100;
chuc = (z%100)/10;
dv = z%10;
lcd_putchar(nghin+48);
lcd_putchar(tram+48);
lcd_putchar(chuc+48);
lcd_putchar(dv+48);
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC Clock frequency: 125.000 kHz
// ADC Voltage Reference: AREF pin
ADMUX=ADC_VREF_TYPE & 0xff;
ADCSRA=0x86;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// Alphanumeric LCD initialization
// Connections specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTB Bit 1
// RD - PORTC Bit 2
// EN - PORTC Bit 3
// D4 - PORTD Bit 4
// D5 - PORTD Bit 5
// D6 - PORTD Bit 6
// D7 - PORTD Bit 7
// Characters/line: 16
lcd_init(16);
while (1)
adc = read_adc(0);
lcd_gotoxy(0,0);
lcd_putnum(adc);
delay_ms(100);
Project :
Version :
Date : 8/15/2014
Author : NeVaDa
Company :
Comments:
Chip type : ATmega8
#include <mega8.h>
#include <delay.h>
#include <alcd.h>
delay_us(10);
ADCSRA|=0x40;
ADCSRA|=0x10;
return ADCW;
int adc = 0;
nghin = z/1000;
chuc = (z%100)/10;
dv = z%10;
lcd_putchar(dv+48);
void main(void)
PORTB=0x00;
DDRB=0x00;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x00;
// USART disabled
UCSRB=0x00;
ACSR=0x80;
SFIOR=0x00;
ADCSRA=0x86;
// SPI disabled
SPCR=0x00;
// TWI disabled
TWCR=0x00;
// RS - PORTB Bit 1
// RD - PORTC Bit 2
// EN - PORTC Bit 3
// D4 - PORTD Bit 4
// D5 - PORTD Bit 5
// D6 - PORTD Bit 6
// D7 - PORTD Bit 7
lcd_init(16);
while (1)
adc = read_adc(0);
lcd_gotoxy(0,0);
lcd_putnum(adc);
delay_ms(100);
