can giup do~ 8515
  • can giup do~ 8515
    các bác ơi,em đang làm mạch mô phỏng dây chuyền đếm sản phẩm...em viết code cho sơ đồ trên,nhưng mà bí quá.em cứ đếm lên được đến 19 thì cái led hàng chục ko lên được nữa...bác nào pro chỉ em chỗ sai trong code với
    .INCLUDE "8515def.inc"
    .CSEG
    .ORG 0x0000
    RJMP BATDAU
    .ORG 0x0020
    BATDAU:
    ;KHOI DONG STACK POINTER
    LDI R17,HIGH(RAMEND)
    LDI R16,LOW(RAMEND)
    OUT SPL,R16
    OUT SPH,R17
    ;KHOI DONG CAC PORT
    CLR R16 ; XOA R16,R16=0
    OUT DDRB,R16; DDRB=0,PORTB LA NGO NHAP
    LDI R16,0xFF ;SET TAT CA CAC BIT CUA R16 LEN 1
    OUT PORTB,R16 ; DDRB=0,PORTB=0xFF,KEO LEN CAC CHAN PORTB
    OUT DDRA,R16 ; DDRA=0xFF,PORTA LA NGO XUAT HANG CHUC
    CLR R24 ; XOA R24,R24 LA THANH GHI DUNG CHUA SO DEM
    OUT DDRC,R16 ; DDRC=0xFF,PORTC LA NGO XUAT HANG DON VI
    CLR R25 ; XOA R25,R25 LA THANH GHI DUNG CHUA SO DEM
    SER R20 ; R20 LA THANH GHI TAM CHUA GIA TRI TRUOC DO CUA PINB
    MAIN:
    IN R21,PINB; DOC GIA TRI TU PINB,TUC TU CAC BUTTON
    RCALL SOSANH; GOI CHUONG TRINH CON SO SANH
    OUT PORTC,R25; XUAT GIA TRI DEM RA PORTC
    OUT PORTA,R24; XUAT GIA TRI DEM RA PORTA
    SBRS R21,0; NEU BIT 0 CUA R21(TUC CHAN PB0)=1 THI BO QUA DONG TIEP THEO
    RCALL TANG ; NHAY DEN CHUONG TRINH CON TANG GIA TRI DEM
    SBRS R21,1; NEU BIT 1 CUA R21 (TUC CHAN PB1)=1 THI BO QUA DONG TIEP THEO
    RCALL GIAM ; NHAY DEN CHUONG TRINH CON GIAM GIA TRI DEM
    MOV R20,R21; LUU LAI TRANG THAI PINB
    RJMP MAIN
    ;******************CHUONG TRINH CON****************
    ;******************KIEM TRA GIOI HAN ( TU 0 DEN 9) CUA SO DEM**************
    SOSANH:
    CPI R25,10
    BREQ RESET0; NEU GIA TRI DEM=10 THI TRA VE 0
    CPI R25,255
    BREQ RESET9; NEU GIA TRI DEM =255 THI TRA VE 9
    RJMP QUAYVE;NHAY DEN NHAN QUAY VE
    RESET0:
    LDI R25,$0;TRA GIA TRI DEM VE 0
    LDI R24, $1;TRA GIA TRI DEM VE 1
    RJMP QUAYVE
    RESET9:
    LDI R25,$9;GAN 9 CHO GIA TRI DEM
    LDI R24,$9
    QUAYVE:
    RET
    ;****************TANG SO DEM 1 DON VI************************
    TANG:
    SBRS R20,0
    RET
    INC R25
    RET
    CPI R25,$0
    INC R24
    RET
    ;***************GIAM SO DEM 1 DON VI***************************
    GIAM:
    SBRS R20,1
    RET
    DEC R25
    RET
    LDI R25,$0
    DEC R24
    RET
    Cậu dùng CodeVison ý nó viết code dễ hơn. Còn mạch cậu làm hình như cậu chưa nối hết các chân của led 7 đoạn. Led 7 đoạn có 8 chân khi nối vào chip thì mỗi PORT của IC điều khiển 1 Led
      trui po' chiếu lun với ông bạn này quá.mình demo = proteus mà.nhìn sơ đồ thế kia mà bảo là mình chưa nối hết chân led thi đến chju, chưa nối hết chân nó sáng lên = niềm tin ahf
        Ban xem lai đoạn chương trình nay:
        SOSANH:
        CPI R25,10
        CPI R25,255
        RESET0:
        LDI R24, $1;TRA GIA TRI DEM VE 1 <--- xem lai chổ này, ko phai tra vế 1 mà la increase 1 ??????
        RJMP QUAYVE
        RESET9:
        LDI R24,$9
        QUAYVE:
        RET
        Lâu quá rồi mình ko xài Assembler nên ko thể giúp bạn nhiều hơn được
        thamtutaihoa Tìm hiểu thêm về thamtutaihoa
        • mèomướp
          bởi mèomướp
          hôm nay, 13:11
        • tuyennhan
          bởi tuyennhan
          hôm nay, 09:25
        • tuyennhan
          bởi tuyennhan
          hôm nay, 09:10
        • Ng.Phuong.5
          bởi Ng.Phuong.5
          Mấy con...
          Hôm qua, 19:44
        • viettinh
          bởi viettinh
          Hôm qua, 18:12
          Cách đơn giản...
          Hôm qua, 00:04
        • mèomướp
          bởi mèomướp
          08-01-2025, 19:02
        • tuyennhan
          bởi tuyennhan
          08-01-2025, 15:43
        • tuyennhan
          bởi tuyennhan
          08-01-2025, 15:28
        • mèomướp
          bởi mèomướp
          08-01-2025, 11:44
