Em muốn tạo xung pwm trong avr để điều khiển động cơ dc. Em có đoạn code sau nhưng em chưa hiểu được công dụng của các lệnh. Mong các bác giúp em với:
This program was produced by the
CodeWizardAVR V2.04.1 Evaluation
Automatic Program Generator
© Copyright 1998-2009 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 6/12/2009
Author : Freeware, for evaluation and non-commercial use only
Company :
Comments:
Chip type : ATmega32
Program type : Application
AVR Core Clock frequency: 8.000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 512
#include <mega32.h>
// Timer 0 overflow interrupt service routine
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
// Place your code here
// Timer 0 output compare interrupt service routine
interrupt [TIM0_COMP] void timer0_comp_isr(void)
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=Out Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=0 State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x08;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
// Func7=Out Func6=In Func5=Out Func4=Out Func3=In Func2=In Func1=In Func0=In
// State7=0 State6=T State5=0 State4=0 State3=T State2=T State1=T State0=T
PORTD=0x00;
DDRD=0xB0;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: 125.000 kHz
// Mode: Phase correct PWM top=FFh
// OC0 output: Inverted PWM
TCCR0=0x73;
TCNT0=0x00;
OCR0=0x7f;
// Timer/Counter 1 initialization
// Clock value: 31.250 kHz
// Mode: Fast PWM top=03FFh
// OC1A output: Inverted
// OC1B output: Non-Inv.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0xE3;
TCCR1B=0x0C;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x08;
OCR1AL=0xe2;
OCR1BH=0x0f;
OCR1BL=0x0f;
// Timer/Counter 2 initialization
// Clock value: 7.813 kHz
// Mode: Fast PWM top=FFh
// OC2 output: Non-Inverted PWM
ASSR=0x00;
TCCR2=0x6F;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x03;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// Global enable interrupts
#asm("sei")
while (1)
Các bác có thể hướng dẫn cho em thêm cách khởi tạo pwm trong timer0, tại nó có nhiều lựa chọn mà em lại quá gà để có thể hiểu được. Em cảm ơn các bác nhiều.
Project :
Version :
Date : 6/12/2009
Company :
Comments:
#include <mega32.h>
void main(void)
PORTA=0x00;
DDRA=0x00;
PORTB=0x00;
DDRB=0x08;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0xB0;
TCCR0=0x73;
TCNT0=0x00;
OCR0=0x7f;
TCCR1A=0xE3;
TCCR1B=0x0C;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x08;
OCR1AL=0xe2;
OCR1BH=0x0f;
OCR1BL=0x0f;
ASSR=0x00;
TCCR2=0x6F;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x03;
ACSR=0x80;
SFIOR=0x00;
#asm("sei")
while (1)
