AVR+ LM35+ Led 7 thanh
  • AVR+ LM35+ Led 7 thanh
    Chào các bác. Các bác giúp e với e viết mãi code ko chạy được mô phỏng các bác chỉnh sửa giùm e. Đa tạ các bác
    [ATTACH=CONFIG]28815[/ATTACH]
    Code:
    #define F_CPU 8000000UL
    #include <avr/io.h>
    #include <util/delay.h>
    #include <avr/interrupt.h>
    //*******************************Khai bao hang*************************************//
    #define led   PORTB
    #define led_a 0b0111
    #define led_b 0b1011
    #define led_c 0b1101
    #define led_d 0b1110
    #define data  PORTC
    #define do_C  0
    //*******************************Khai bao bien**************************************//
    unsigned char font[13]={0xC0,0xF9,0xA4,0xB0,
    						0x99,0x92,0x82,0xF8,
    						0x80,0x90,0x9C,0xC6,0x8E};    // font hien thi so cho cac led
    unsigned char led_index=0, temp, nhiet_do, adc_data[2];
    //**************************** Cau hinh chip ***************************
    void init (void)
    	DDRB=0x0F;
    	DDRC=0xFF;
    //***************** KHOI TAO TIMER0 **************************
    	TCCR0|=(1<<CS01)|(1<<CS00); // CS02=0, CS01=1, CS00=0: chon Prescaler = 8
    	TCNT0=0x00;             //gan gia tri khoi tao cho T/C0
    	OCR0=0x00;
    //************** KHOI TAO NGAT TIMER0 **************************
    	MCUCR=0x00;
    	MCUCSR=0x00;
    	TIMSK=0x41;               // enable timer0 interupt
    	//TIMSK=1<<TOIE0;
    //***************** Analog Comparator initialization **********************
    	ACSR=0x80;
    	SFIOR=0x00;
    //****************** Set up ADC *******************************************
       ADMUX=0|(0x20 & 0xff);      // Set up ADC (Analog to Digital Converter)
       //ADCSRA=0xCB;
       ADCSRA|=(1<<ADEN)|(1<<ADSC)|(1<<ADIE)|(1<<ADPS1)|(1<<ADPS0);
       sei();
    //xU LY NGAT
    //******************* Ngat ADC **************************
    ISR (ADC_vect)
    	static unsigned char input_index=0;
         adc_data[input_index]=ADCH; //adc_data[0] = ADCH
         if (++input_index > (1)) input_index=0;
         ADMUX=(0|(0x20 & 0xff))+input_index;
         _delay_us(300);
         ADCSRA|=0x40;
    //***************** NGAT TIMER0 *****************************
    ISR (TIMER0_VOF0_vect)//HIEN THI LED 7 BANG BANG NGAT TIMER0
    	if(led_index==4) led_index=0;
         if(led_index==0)
              led=led_a;
              data=font[(temp/10)%10];
         if(led_index==1)
              led=led_b;
              data=font[temp%10];
         if(led_index==2)
              led=led_c;
              data=font[10];
         if(led_index==3)
              led=led_d;
              if(nhiet_do==do_C) data=font[11]; else data=font[12];
         led_index++;
    void main (void)
    	init();
    	nhiet_do=do_C;
    	_delay_ms(100);
    	while(1)
    			// do nothing
    bạn ơi cho mình hỏi cách viết mã nhị phân như portb=0b1110; tức là tác động vào 4 bit đầu của portB còn 4 bit sau bằng 0 hay ko tác động vào
      Khởi tạo ngắt bạn phải cho vào hàm main chứ. Bạn đặt hoàn toàn ở ngoài thì sao có thể chạy được
      gmail :
        Nguyên văn bởi bienhou Xem bài viết
        Chỉ nhầm mỗi chỗ đó thôi à, bạn xem còn thiếu chỗ nào không?!
          àh sr, bạn đã đặt hàm khởi tạo trong main rồi, mình ko để ý kỹ@@, mình chưa thấy bạn đẩy nhiệt độ vào hàm quét.
          gmail :
          Feri Rocky Tìm hiểu thêm về Feri Rocky
