Xin được chỉ giáo
  • Xin được chỉ giáo
    E kiếm được đoạn code sau dùng để xuất tín hiệu AD ra LCD:
    biến trở -> bộ ADC -> AVR -> xuất điện áp ra LCD
    19. Chip type : ATmega16
    20. Program type : Application
    21. Clock frequency : 8.000000 MHz
    22. Memory model : Small
    23. External SRAM size : 0
    24. Data Stack size : 256
    25. ************************************************** ***/
    26.
    27. #include <mega16.h>
    28.
    29. // Alphanumeric LCD Module functions
    30. #asm
    31. .equ __lcd_port=0x15 ;PORTC
    32. #endasm
    33. #include <lcd.h>
    34.
    35. #define FIRST_ADC_INPUT 0
    36. #define LAST_ADC_INPUT 7
    37. unsigned char adc_data[LAST_ADC_INPUT-FIRST_ADC_INPUT+1];
    38. #define ADC_VREF_TYPE 0x20
    39.
    40. // ADC interrupt service routine
    41. // with auto input scanning
    42. interrupt [ADC_INT] void adc_isr(void)
    43. {
    44. register static unsigned char input_index=0;
    45. // Read the 8 most significant bits
    46. // of the AD conversion result
    47. adc_data[input_index]=ADCH;
    48. // Select next ADC input
    49. if (++input_index &gt; (LAST_ADC_INPUT-FIRST_ADC_INPUT))
    50. input_index=0;
    51. ADMUX=(FIRST_ADC_INPUT|ADC_VREF_TYPE)+input_index;
    52. // Start the AD conversion
    53. ADCSRA|=0x40;
    54. }
    55.
    56.
    57. // Declare your global variables here
    58. void lcd_putnum(unsigned int d)
    59. {
    60. unsigned char donvi, chuc, tram;
    61. donvi=d%10;
    62. d=d/10;
    63. chuc=d%10;
    64. d=d/10;
    65. tram=d%10;
    66. d=d/10;
    67. 68. if(tram&gt;0)
    69. {
    70. lcd_putchar(48+tram);
    71. lcd_putchar(48+chuc);
    72. lcd_putchar(48+donvi);
    73.
    74. }
    75. else if(chuc&gt;0)
    76. {
    77. lcd_putchar(48+chuc);
    78. lcd_putchar(48+donvi);
    79. lcd_putsf(" ");
    80.
    81. }
    82. else {
    83. lcd_putchar(48+donvi);
    84. lcd_putsf(" ");
    85. lcd_putsf(" ");
    86.
    87. }
    88. }
    89.
    90. void main(void)
    91. {
    92. // Declare your local variables here
    93.
    94. // Input/Output Ports initialization
    95. // Port A initialization
    96. // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In
    Func0=In
    97. // State7=T State6=T State5=T State4=T State3=T State2=T State1=T
    State0=T
    98. PORTA=0x00;
    99. DDRA=0x00;
    100.
    101. // Port B initialization
    102. // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In
    Func0=In
    103. // State7=T State6=T State5=T State4=T State3=T State2=T State1=T
    State0=T
    104. PORTB=0x00;
    105. DDRB=0x00;
    106.
    107. // Port C initialization
    108. // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In
    Func0=In
    109. // State7=T State6=T State5=T State4=T State3=T State2=T State1=T
    State0=T
    110. PORTC=0x00;
    111. DDRC=0x00;
    112.
    113. // Port D initialization
    114. // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In
    Func0=In
    115. // State7=T State6=T State5=T State4=T State3=T State2=T State1=T
    State0=T
    116. PORTD=0x00;
    117. DDRD=0x00;
    118.
    119. // Timer/Counter 0 initialization 120. // Clock source: System Clock
    121. // Clock value: Timer 0 Stopped
    122. // Mode: Normal top=FFh
    123. // OC0 output: Disconnected
    124. TCCR0=0x00;
    125. TCNT0=0x00;
    126. OCR0=0x00;
    127.
    128. // Timer/Counter 1 initialization
    129. // Clock source: System Clock
    130. // Clock value: Timer 1 Stopped
    131. // Mode: Normal top=FFFFh
    132. // OC1A output: Discon.
    133. // OC1B output: Discon.
    134. // Noise Canceler: Off
    135. // Input Capture on Falling Edge
    136. // Timer 1 Overflow Interrupt: Off
    137. // Input Capture Interrupt: Off
    138. // Compare A Match Interrupt: Off
    139. // Compare B Match Interrupt: Off
    140. TCCR1A=0x00;
    141. TCCR1B=0x00;
    142. TCNT1H=0x00;
    143. TCNT1L=0x00;
    144. ICR1H=0x00;
    145. ICR1L=0x00;
    146. OCR1AH=0x00;
    147. OCR1AL=0x00;
    148. OCR1BH=0x00;
    149. OCR1BL=0x00;
    150.
    151. // Timer/Counter 2 initialization
    152. // Clock source: System Clock
    153. // Clock value: Timer 2 Stopped
    154. // Mode: Normal top=FFh
    155. // OC2 output: Disconnected
    156. ASSR=0x00;
    157. TCCR2=0x00;
    158. TCNT2=0x00;
    159. OCR2=0x00;
    160.
    161. // External Interrupt(s) initialization
    162. // INT0: Off
    163. // INT1: Off
    164. // INT2: Off
    165. MCUCR=0x00;
    166. MCUCSR=0x00;
    167.
    168. // Timer(s)/Counter(s) Interrupt(s) initialization
    169. TIMSK=0x00;
    170.
    171. // Analog Comparator initialization
    172. // Analog Comparator: Off
    173. // Analog Comparator Input Capture by Timer/Counter 1: Off
    174. ACSR=0x80;
    175. SFIOR=0x00;
    176.
    177. // ADC initialization
    178. // ADC Clock frequency: 1000.000 kHz
    179. // ADC Voltage Reference: AREF pin 180. // ADC Auto Trigger Source: None
    181. // Only the 8 most significant bits of
    182. // the AD conversion result are used
    183. ADMUX=FIRST_ADC_INPUT|ADC_VREF_TYPE;
    184. ADCSRA=0xCB;
    185.
    186. // LCD module initialization
    187. lcd_init(16);
    188.
    189. // Global enable interrupts
    190. #asm("sei")
    191. lcd_gotoxy(0,0);
    192. lcd_putsf("ADC");
    193.
    194. while (1)
    195. {
    196. // Place your code here
    197. lcd_gotoxy(4,1);
    198. lcd_putnum(adc_data[0]);
    199. };
    200. }
    Không hiểu giá trị "gt" là gì, mà c/tr cứ đòi phải define, tại sao trong hàm IF tác giả lại dùng dấu ";", mọi người bỉết thì giúp dùm.
    đoạn code này bạn copy sang chắc là bị lỗi nên mới bị sai như vậy.
    ví dụ bạn thay như này:
    #include <delay.h>
    43. {
    49. if (++input_index > (LAST_ADC_INPUT-FIRST_ADC_INPUT))
    50. input_index=0;
    53. ADCSRA|=0x40;
    54. }
    59. {
    61. donvi=d%10;
    62. d=d/10;
    63. chuc=d%10;
    64. tram = d/10;
    88. }
    190. #asm("sei")
    193.
    194. while (1)
    195. {
    delay_ms(300);
    199. };
    như vậy là sẽ hiện thị dc giá trị do được kênh ADC0.trong khi bộ ADC đo lần lần lượt 8 kênh đo.chú ý thêm delay vào để xem giá trị ADC0.
    hãy quý những j hiện tại mình đang có
      mình đã xem xét và sửa lại như sau:
      .... đoạn trên thì sửa như xl09 đã sửa
      57 // Declare your global variables here
      58 void lcd_putnum(unsigned int d)
      59 {
      60 unsigned char donvi, chuc, tram;
      61 donvi=d%10;
      62 d=d/10;
      63 chuc=d%10;
      64 d=d/10;
      65 tram=d%10;
      66 d=d/10;
      } //xuống dòng tới void main lun nha
      90 void main(void)
      while (1)
      lcd_gotoxy(4,1);
      // delay_ms(300); khỏi cần delay lun
      KQ ra cuối cùng khi vặn biến trở min (000) - max(255), đúng như yêu cầu đặt ra ban đầu của tác giả đoạn code: "Dùng PORTA.0 nhận giá trị từ biến trở hiển thị lên LCD theo ADC 8bit (từ 0->5V thành 0 ->255)"
      Nhưng em muốn hiện giá trị điện áp kìa. VD: vặn biến trở min (hiện 0v) - max(hiện 5v). mong mọi người giúp đỡ.
        như thế này nhe:
        điện áp bộ ADC đọc vào phụ thuộc vào Vref của bộ ADC.
        ví dụ Vref =5V(nối với +vcc) và đọc ADC 8 bit như trên thì giá trị nhận tối đa được ở thanh ghi ADCH là 255 sẽ tương ứng với điện áp Vref (5V).
        như vậy giá trị điện áp nhận được bạn tính theo ct: U = ADC*Vref/255.
          bạn có thể them lun doạn này vào:
          unsigned int xulyadc(unsigned char adc)
          //chan Vref nối với Vcc(5.00V)
          unsigned long int temp = adc;
          temp *= 500/255; //như vạy nhận điện áp đo được *100;
          return (unsigned int)(temp)
          59 {
          d = xulyadc(d);
          61 donvi=d%10;
          62 d=d/10;
          63 chuc=d%10;
          64 d=d/10;
          65 tram=d%10;
          66 d=d/10;
          lcd_putchar('.'); //hiẹn thị điện áp từ 0.00V đến 5.00V
          tuy nhiên khi làm thành thạo thì bạn phải tối ưu lại.
            yeunhan777 Tìm hiểu thêm về yeunhan777
            • mansion123
              bởi mansion123
              hôm nay, 16:08
              hôm nay, 07:44
