đồ chơi khủng cho AVR đây!!!
  • đồ chơi khủng cho AVR đây!!!
    rtx_3.1.rar : PR_RTX
    PR_RTX is a task switcher for the Atmel AVR processor that is easily implemented by inserting a header file and a task control block into the code produced by the CodeVisionAVR wizard or written by a programmer. The header file contains all of the control structure and initializations to get the RTX running.
    A rich variety of RTX services are provided to control task switching, timing and task control. Tasks may be put into a wait state based on time or receipt of a semaphore from another task or both. Tasks may be started or stopped either from within the task itself or from another task. Tasks may switch in a round-robin mode or in a priority mode where one task requires critical timing control.
    This is a source code product and is packaged in the form of both CodeVisionAVR and Imagecraft projects.
    Features
    -Complete task switching control in either round-robin or priority mode
    -Automatic time base set-up
    -Allocation of internal and/or external SRAM based on project configuration
    -Includes ability to pass inter-task semaphores with limited messaging
    -Tasks may switch on other periodic signals such as the ADC or even from an external interrupt
    -Complete CodeVisionAVR and Imagecraft project packages with an example programs
    -Designed specifically for CodeVisionAVR, Imagecraft and the Atmel AVR
    -Simple setup configuration through #define macros
    -PR_RT_eXaminer tool allows users to examine stack sizes and usage
    avr_cf.rar and avr_sd.rar : FlashFile SD/CF FAT12/16 File Systems for AVR.
    FlashFile - SD/MMC FAT12/16 File Systems for AVR
    FlashFile are source code packages designed to give MSDOS compatibility to your embedded application using SD/MMC, Mini-SD, TransFlash or CompactFlash memory modules! Standard C library functions such as fopen, fclose, fcreate, fread, frwrite, fgetc, fputc, and others allow easy access to data stored on an SD/MMC card by a PC as well as an easy method of creating and maintaining data from your embedded application that can be easily accessed by a PC. Both FAT12, and FAT16 formats are supported including subdirectories.
    Quá là cảm ơn bạn, thấy có thư viện này bán trên mạng (cả Tây, cả ta), vội vã đi tìm crk, ai dè ngay bên cạnh mình, hê, cứ đi tìm đâu đâu ấy...
      Cám ơn bạn nha,
      Thư viện này hay qua'
      Vui
      hoanf
        các bác oi, cho e hỏi 1 câu ngớ ngẩn là cái mà bác longimi pot len là cai gi vậy, e có down về roi nhung ko bit xai, các bác vui lòng chỉ e cách xài với,e thấy những người cảm ơn bác longimi toàn là cao thủ ko hà, chác là bác longimi đã tặng bảo kiếm cho các anh hùng, hi vọng mọi người chỉ e vài chiêu để e sử dụng bảo kiếm với,pls.
          Các anh ơi cho em biết mấy file vừa uplen có tác dụng gì vậy ạ.
          longimi Tìm hiểu thêm về longimi
            Trả lời cho Tự tìm công thức tính lưu lượng gió quạt điện dân dụng
            Dinhthuong ơi! cơ hội làm giàu của cháu đến rồi.
            Trên thế giới toàn bộ : "Chân Vịt" cho tàu bè đều là cánh to, nó hao nhiên liệu, ma sát làm hư hao. Nay cháu sx chân vịt cánh nhò cho thế giới sử dụng, chân vịt của cháu...
            Hôm qua, 21:25
            Trả lời cho nguồn switching
            Thông tin cá nhân bqv xin phép tránh nêu ở diễn đàn. Nghề nghiệp thì bao năm nay vẫn thế thôi : điện - điện tử - tự động hóa - IT. Làm ơn đừng hâm mộ, nhỡ có dịp gặp thật thì lại thất vọng vì thực tế không như mình nghĩ. Bqv xét...
            Hôm qua, 21:16
            Dạ chú dinh... cứ xét hệ tại 1 thời điểm thì sẽ dễ hiểu hơn ạ, với cánh to thì mặt tiếp xúc lớn hơn, lực tác động vào đồng thời nhiều không khí hơn, nhìu không khí cùng chuyển động thì sẽ tạo lưu lượng gió lớn hơn ạ...
            Hôm qua, 18:49
            Dạ cháu hỏi lại chị hàng xóm nhà cháu rồi ạ, chị ấy bảo anh thợ sửa điều hòa tâm sự với chị ấy nên hông nhầm đâu ạ. Chú bq... hông tin thì có thể xem video này ạ
            https://youtu.be/dvU8ZcvgYH4?si=15Sd_j3uxuWah9PR
            Hôm qua, 17:30
            Cảm ơn bác ạ, nhờ chủ đề này, nhờ bác nhiệt tình chia sẻ mà mọi người biết thêm nhiều kiến thức về quạt điên, thiết bị điện tưởng chừng rất đơn giản chỉ chuyển điện thành cơ.
            Tuy nhiên, chỗ in đậm cháu không đồng...
            Hôm qua, 17:00
            Hình như bạn mèomướp lộn chút. Mạch nguồn xung vốn chạy 220V, muốn chuyển sang chạy 110V thì có thể dùng mạch nhân áp; hoặc thậm chí chẳng phải làm gì nếu đó là nguồn xung flyback đầu vào dải rộng. Chứ mạch nguồn vốn chạy 110V hoặc 100V nay muốn chuyển sang chạy 220 thì phải thay một mớ đấy....
            Hôm qua, 16:16
          • milan
            bởi milan
            Đại ca bqviet năm nay bao nhiêu tuổi rồi, làm nghề gì nhỉ.
            Ngày xưa em hâm mộ anh nhất diễn đàn mà chưa có dịp gặp....
            Hôm qua, 11:51
            Dạ ai lại làm như chú bq... ạ. một số dòng điều hòa của nhật bên trong nó có mạch nhân áp thì bỏ qua mạch ấy là chạy 220v được ạ. Còn máy hàn thì cháu hông biết nó có thể làm vậy ko, chú tháo ra xem mạch mới biết được ạ...
            Hôm qua, 07:09
            Senko này là sử dụng cánh nhỏ đầu tiên , hình dáng đẹp giá vừa phải nhưng lại thiết kế sai ở chổ thêm nối tiếp cầu chì nhiệt vào đàu dây chung mô tơ , sử dụng lâu quạt tăng nhiệt cầu chì đứt thế là hết xài dù những linh kiện...
            Hôm qua, 07:07
            Tất ca kiến thức về quạt của tôi do thầy hiệu trưởng Nguyễn Hồng Lam tốt nghiệpp kỹ sư bên Mỹ giảng dạy. Cánh quạt cong cũng là thầy dạy , nó tạo khí động học.
            Tôi đã dùng ngôn ngữ bình dân để thuyết minh cho mọi người...
            Hôm qua, 01:36
