help không đọc được ADC 10 bit
  • help không đọc được ADC 10 bit
    Các bác cao thủ xem giúp em với. Các bác bắt bệnh giúp em, em không đọc được ADC 10 bít mà nó chỉ trả về có 8 bit thui
    còn đây là code của em ạ
    This program was produced by the
    CodeWizardAVR V2.03.4 Standard
    Automatic Program Generator
    © Copyright 1998-2008 Pavel Haiduc, HP InfoTech s.r.l.
    http://www.hpinfotech.com
    Project :
    Version :
    Date : 8/8/2011
    Author :
    Company :
    Comments:
    Chip type : ATmega16
    Program type : Application
    Clock frequency : 8.000000 MHz
    Memory model : Small
    External RAM size : 0
    Data Stack size : 256
    #include <mega16.h>
    // Alphanumeric LCD Module functions
    #asm
    .equ __lcd_port=0x15 ;PORTC
    #endasm
    #include <lcd.h>
    #include <delay.h>
    #define FIRST_ADC_INPUT 0
    #define LAST_ADC_INPUT 1
    unsigned int adc_data[LAST_ADC_INPUT-FIRST_ADC_INPUT+1];
    #define ADC_VREF_TYPE 0x00
    // ADC interrupt service routine
    // with auto input scanning
    interrupt [ADC_INT] void adc_isr(void)
    static unsigned char input_index=0;
    // Read the AD conversion result
    adc_data[input_index]=ADCW;
    // Select next ADC input
    if (++input_index > (LAST_ADC_INPUT-FIRST_ADC_INPUT))
    input_index=0;
    ADMUX=(FIRST_ADC_INPUT | (ADC_VREF_TYPE & 0xff))+input_index;
    // Delay needed for the stabilization of the ADC input voltage
    delay_us(10);
    // Start the AD conversion
    ADCSRA|=0x40;
    void lcd_putnum(unsigned char so,unsigned char x,unsigned char y)
    unsigned char a,b,c,d;
    a=so/1000;
    // lay fan tram
    b=(so-1000*a)/100;
    // lay fan tram
    c=(so-1000*a-100*b)/10;
    d=(so-1000*a-100*b-c*10);
    // lay hang don vi
    lcd_gotoxy(x,y);
    // ve vi tri x,y
    lcd_putchar(a+48);
    // day ra hang tram, ma ascii
    lcd_putchar(b+48);
    // day ra hang chuc, ma ascii
    lcd_putchar(c+48);
    lcd_putchar(d+48);
    // day ra hang don vi, ma ascii
    // Declare your global variables here
    void main(void)
    // Declare your local variables here
    // Input/Output Ports initialization
    // Port A initialization
    // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
    // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
    PORTA=0x00;
    DDRA=0x00;
    // Port B initialization
    PORTB=0x00;
    DDRB=0x00;
    // Port C initialization
    PORTC=0x00;
    DDRC=0x00;
    // Port D initialization
    PORTD=0x00;
    DDRD=0x00;
    // Timer/Counter 0 initialization
    // Clock source: System Clock
    // Clock value: Timer 0 Stopped
    // Mode: Normal top=FFh
    // OC0 output: Disconnected
    TCCR0=0x00;
    TCNT0=0x00;
    OCR0=0x00;
    // Timer/Counter 1 initialization
    // Clock value: Timer 1 Stopped
    // Mode: Normal top=FFFFh
    // OC1A output: Discon.
    // OC1B output: Discon.
    // Noise Canceler: Off
    // Input Capture on Falling Edge
    // Timer 1 Overflow Interrupt: Off
    // Input Capture Interrupt: Off
    // Compare A Match Interrupt: Off
    // Compare B Match Interrupt: Off
    TCCR1A=0x00;
    TCCR1B=0x00;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x00;
    OCR1BH=0x00;
    OCR1BL=0x00;
    // Timer/Counter 2 initialization
    // Clock value: Timer 2 Stopped
    // OC2 output: Disconnected
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00;
    // External Interrupt(s) initialization
    // INT0: Off
    // INT1: Off
    // INT2: Off
    MCUCR=0x00;
    MCUCSR=0x00;
    // Timer(s)/Counter(s) Interrupt(s) initialization
    TIMSK=0x00;
    // Analog Comparator initialization
    // Analog Comparator: Off
    // Analog Comparator Input Capture by Timer/Counter 1: Off
    ACSR=0x80;
    SFIOR=0x00;
    // ADC initialization
    // ADC Clock frequency: 250.000 kHz
    // ADC Voltage Reference: AREF pin
    // ADC Auto Trigger Source: None
    ADMUX=FIRST_ADC_INPUT | (ADC_VREF_TYPE & 0xff);
    ADCSRA=0xCD;
    // LCD module initialization
    lcd_init(16);
    // Global enable interrupts
    #asm("sei")
    while (1)
    { lcd_putnum(adc_data[0],0,1);
    delay_ms(100);
    // Place your code here
    em cảm ơn nhiều ạ
    Nguyên văn bởi FXR Xem bài viết
    a=so/1000;
    // lay fan tram
    b=(so-1000*a)/100;
    // lay fan tram
    // lay hang don vi
    lcd_gotoxy(x,y);
    // ve vi tri x,y
    lcd_putchar(a+48);
    lcd_putchar(b+48);
    lcd_putchar(c+48);
    lcd_putchar(d+48);
    Chỗ này, bạn đổi "unsigned char so" thành "unsigned int so"
      vâng em cảm ơn bác nhiều nhé
      FXR Tìm hiểu thêm về FXR
        hôm nay, 07:44
