thanks mình đag cần cái này :d thanks pác rất nhiều
Chương trình tạo PWM bằng 8051
cái này mình viết giống như sao băng thôi ko có j khó.
ở đây mình dùng 89 2051 , 15bit out. ko có p3.6. tham khảo.
Code:;Dung cho 89x2xx ; *********************** ;--------------------Hoang_KH---------------------- ; dt: 0978 086 596 ; *********************** tocdo equ 50h biendem_pwm equ 52h so_bit equ 53h so_hang equ 54h vonglap1 equ 55h vonglap2 equ 56h org 00h jmp main org 001bh ; ngat T1 call ngat1 reti org 0057h main: mov tmod,#00100000b setb ie.7 ;cho phep toan cuc setb ie.3 ; cho phep ngat t1 setb ie.1 mov th1,#-2 mov tl1,#-2 mov biendem_pwm,#51 mov p0,#00h mov p1,#00h mov p2,#00h mov p3,#00h hoang: mov so_bit,#15 ;so bit dieu khien call chuongtrinh jmp hoang ;----------------------------- ngat1: push acc push 03h dec biendem_pwm mov a,biendem_pwm call out_port cjne a,#1,exit_ngat1 mov biendem_pwm,#51 mov p1,#00 mov p3,#00 mov p2,#00 mov p0,#00 exit_ngat1: pop 03h pop acc ret ;------------------------------ out_port: cjne a,30h,tiep0 setb p1.7 tiep0: cjne a,31h,tiep1 setb p1.6 tiep1: cjne a,32h,tiep2 setb p1.5 tiep2: cjne a,33h,tiep3 setb p1.4 tiep3: cjne a,34h,tiep4 setb p1.3 tiep4: cjne a,35h,tiep5 setb p1.2 tiep5: cjne a,36h,tiep6 setb p1.1 tiep6: cjne a,37h,tiep7 setb p1.0 tiep7: cjne a,38h,tiep8 setb p3.7 tiep8: cjne a,39h,tiep9 setb p3.5 tiep9: cjne a,3ah,tiep10 setb p3.4 tiep10: cjne a,3bh,tiep11 setb p3.3 tiep11: cjne a,3ch,tiep12 setb p3.2 tiep12: cjne a,3dh,tiep13 setb p3.1 tiep13: cjne a,3eh,tiep14 setb p3.0 tiep14: ret ;---------------------------------- ma_led: push 01h push 03h mov r1,#30h mov r3,so_bit lay_dr: call dorong_xung djnz r3,tiep_lay_dorong jmp exit_lay_dorong tiep_lay_dorong : inc dptr inc r1 jmp lay_dr exit_lay_dorong: pop 03h pop 01h ret ;----------------------------------- dorong_xung: push acc push 01h push 03h mov a,r0 movc a,@a+dptr mov r3,a push dph push dpl mov dptr,#ma_dorong movc a,@a+dptr add a,r3 mov @r1,a pop dpl pop dph pop 03h pop 01h pop acc ret ;------------------------------------- delay: push acc push 06h push 07h push dph push dpl mov dptr,#ma_thoigian mov a,tocdo movc a,@a+dptr mov r6,a d0: mov r7,#50 djnz r7,$ djnz r6,d0 pop dpl pop dph pop 07h pop 06h pop acc ret ;-------------------------------------- ma_thoigian: db 46,43,40,37,34,31,28,25,22,19,16,13,10,7,04,01 ma_dorong: db 00,00,01,02,03,04,05,06,08,10,13,16,20,24,29,35 ;------------------------------ play: mov r0,#00h mov r4,so_hang hd: call ma_led setb tr1 call delay clr tr1 inc r0 djnz r4,hd clr a ret ;$$$$$$$$$$$$$$$$$$= chuong trinh chinh =$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ chuongtrinh: mov tocdo,#13 ;(low 0, fast 15) mov dptr,#ma1 mov so_hang,#31 call play mov tocdo,#15 mov dptr,#ma2 mov so_hang,#15 call play ret ;------------------------------------------- ma1: db 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00 db 15,00,00,00,00,00,00,00,00,00,00,00,00,00,00 db 14,15,00,00,00,00,00,00,00,00,00,00,00,00,00 db 13,14,15,00,00,00,00,00,00,00,00,00,00,00,00 db 12,13,14,15,00,00,00,00,00,00,00,00,00,00,00 db 11,12,13,14,15,00,00,00,00,00,00,00,00,00,00 db 10,11,12,13,14,15,00,00,00,00,00,00,00,00,00 db 09,10,11,12,13,14,15,00,00,00,00,00,00,00,00 db 08,09,10,11,12,13,14,15,00,00,00,00,00,00,00 db 07,08,09,10,11,12,13,14,15,00,00,00,00,00,00 db 06,07,08,09,10,11,12,13,14,15,00,00,00,00,00 db 05,06,07,08,09,10,11,12,13,14,15,00,00,00,00 db 04,05,06,07,08,09,10,11,12,13,14,15,00,00,00 db 03,04,05,06,07,08,09,10,11,12,13,14,15,00,00 db 02,03,04,05,06,07,08,09,10,11,12,13,14,15,00 db 01,02,03,04,05,06,07,08,09,10,11,12,13,14,15 db 00,01,02,03,04,05,06,07,08,09,10,11,12,13,14 db 00,00,01,02,03,04,05,06,07,08,09,10,11,12,13 db 00,00,00,01,02,03,04,05,06,07,08,09,10,11,12 db 00,00,00,00,01,02,03,04,05,06,07,08,09,10,11 db 00,00,00,00,00,01,02,03,04,05,06,07,08,09,10 db 00,00,00,00,00,00,01,02,03,04,05,06,07,08,09 db 00,00,00,00,00,00,00,01,02,03,04,05,06,07,08 db 00,00,00,00,00,00,00,00,01,02,03,04,05,06,07 db 00,00,00,00,00,00,00,00,00,01,02,03,04,05,06 db 00,00,00,00,00,00,00,00,00,00,01,02,03,04,05 db 00,00,00,00,00,00,00,00,00,00,00,01,02,03,04 db 00,00,00,00,00,00,00,00,00,00,00,00,01,02,03 db 00,00,00,00,00,00,00,00,00,00,00,00,00,01,02 db 00,00,00,00,00,00,00,00,00,00,00,00,00,00,01 db 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00 ma2: db 00,00,00,00,00,00,00,00,00,00,00,00,00,00,15 db 00,00,00,00,00,00,00,00,00,00,00,00,00,15,00 db 00,00,00,00,00,00,00,00,00,00,00,00,15,00,00 db 00,00,00,00,00,00,00,00,00,00,00,15,00,00,00 db 00,00,00,00,00,00,00,00,00,00,15,00,00,00,00 db 00,00,00,00,00,00,00,00,00,15,00,00,00,00,00 db 00,00,00,00,00,00,00,00,15,00,00,00,00,00,00 db 00,00,00,00,00,00,00,15,00,00,00,00,00,00,00 db 00,00,00,00,00,00,15,00,00,00,00,00,00,00,00 db 00,00,00,00,00,15,00,00,00,00,00,00,00,00,00 db 00,00,00,00,15,00,00,00,00,00,00,00,00,00,00 db 00,00,00,15,00,00,00,00,00,00,00,00,00,00,00 db 00,00,15,00,00,00,00,00,00,00,00,00,00,00,00 db 00,15,00,00,00,00,00,00,00,00,00,00,00,00,00 db 15,00,00,00,00,00,00,00,00,00,00,00,00,00,00 end
PCCC
Bạn muốn cả 32 chân out của VDK đều là PWM để điều khiển cái gì thế? nếu bài toán phức tạp thì nên dùng C cho dễ {thực hiện, bảo trì}, nâng cấp. Nếu cả 32 chân out đều dùng để điều chế PWM thì bạn dùng chân nào để bạn lắp cảm biến để thay đổi tần số băm xung? hay nó không thay đổi theo thời gian đối với mỗi chân (PWM cứng)?
Em muốn làm bộ điều khiển nhiệt độ dựa vào xung pwm để thay đổi góc mở triac. Anh nào cho em cái ý tưởng với.
Em sẽ so sánh nhiệt độ nhập từ bàn phím và nhiệt độ đọc được từ cảm biến, nếu nhiệt độ nhỏ hơn nhiệt độ nhập vào thì tăng độ rộng xung ra và ngược lại còn nếu bằng rồi thì thoát.
Có anh nào biết chỉ giùm em với?
Em đang làm đồ án Điều khiển Đc 1 chiều 4 nút bấm ứng với 4 chế độ "thuận, nghịch, tăng, giảm" và hiển thị tên chế độ lên LCD. Em đã làm đc thuận và nghịch hiển thị LCD rồi. Nhưng không biết cách làm tăng giảm tốc độ. Các bác có thể cho em xin code asm được không ạ? Làm bằng phương pháp PWM ạ.
bởi phuongac15Để bảo quản bánh kem trong kho lạnh bánh kem một cách hiệu quả, giữ được hương vị, kết cấu và hình dáng đẹp, bạn cần chú ý đến nhiệt độ, độ ẩm, cách đóng gói và thời gian bảo quản. Dưới đây là hướng dẫn chi tiết:
1. Điều kiện lý tưởng để bảo quản bánh kem trong kho lạnh- Nhiệt độ:
- Bánh kem
Channel: Quảng cáo
Hôm qua, 21:32 - Nhiệt độ:
Hôm qua, 20:04 -
Cầu Thiên...-
03-03-2025, 22:15 -
02-03-2025, 10:57 -
02-03-2025, 08:00 -
02-03-2025, 07:56 -
Trả lời cho Biết gì nói nấy, cãi chửi thoải máibởi tuyennhanMình phải đắc đạo rồi thì mới độ được cho người vậy nên TÂM NHƯ NĂNG TỈNH mới tốt .
Khi xưa tôi nhờ phòng văn thư dùng mail công ty gửi cho hãng hỏi về một chi tiết kỹ thuật và mua linh kiện , hãng nó trả lời xin liên lạc...-
02-03-2025, 07:04 -
Trả lời cho Biết gì nói nấy, cãi chửi thoải máibởi dinhthuong80ĐT em dốt tiếng Anh, nên chỉ cứ tưởng họ hay nói câu cầu khiến dạng:
VERB/VERB.ING + PLEASE
Giờ được bác hiểu rộng và có tâm chỉ bảo em mới biết thêm cấu trúc:
ADJ + PLEASE
Quả là như bác bác...-
02-03-2025, 06:20 -
Trả lời cho Biết gì nói nấy, cãi chửi thoải máibởi mèomướpDạ cháu hông đồng ý với ý kiến của bác vi... ạ, mặc dù cháu biết bác rất thật lòng, rất muốn điều tốt đẹp đến cho chú dinh...nhưng xã hội nó vốn đã vậy rồi, mình giúp đỡ hay rộng hơn là bất cứ 1 tác động gì đến người...
01-03-2025, 20:39 -
Trả lời cho Biết gì nói nấy, cãi chửi thoải máibởi vi van phamGiúp đỡ người ko cần trợ giúp, đôi khi chữ Tâm còn thiếu chưa đủ nghĩa, phải thêm vào chữ Nhẫn phía trước thành chữ Nhẫn Tâm.
Thí dụ bạn làm trong cty chuyên về điện tử, buổi họp hàng tuần diễn ra, bạn góp ý với bạn...-
01-03-2025, 18:02 -
