Help code asemblly
  • Help code asemblly
    ai thạo về asemblly có thể xem giúp e cái code natf dc ko
    ko có lỗi nhưng dịch file hex ko dc
    Code:
    ;              Digital Clock with alarm using DS1307
    ;                   For Keil/ A51 Macro Assembler
    ;              Designed By: Ajay Bhargav
    ;              E-mail:      ajay_bhargav@hotmail.com
    ;              WWW:         www.rickeyworld.info
    ;   PS: Use only A51 Macro assembler for linking this file
    ;       else you can directly use the hex file provided.
    ;       And if in anycase you want to edit the code then
    ;       you have to use an alternative to write the macros
    ;       defined in the file. In my opinion you dont need to
    ;       edit it.
    hold macro
    	nop
    	nop
    	nop
    	nop
    	endm
    disp_str macro string				;Macro for sending string to LCD
    	irpc char, <string>
    		if nul 'char'
    			exitm
    		endif
    		mov a,#'char'
    		lcall data_in
    	endm
    	endm
    build_char macro P1,P2,P3,P4,P5,P6,P7,P8	;Macro for building a custom character
    	irp arg, <P1,P2,P3,P4,P5,P6,P7,P8>
    		mov a,#arg
    		acall data_in
    	endm
    	endm
    	sec equ 30h				;second register
    	min equ 31h				;minutes register
    	hour equ 32h				;hour register
    	days equ 33h				;days register
    	date equ 34h				;date register
    	month equ 35h				;month register
    	year equ 36h				;year register
    	alarm equ 37h				;alarm register
    	sig equ 38h				;signature for data checking in RTC RAM
    	ahour equ 39h				;alarm hour register
    	amin equ 3Ah				;alarm minute register
    	sda equ P1.1				;Serial data pin
    	scl equ P1.0				;Serial clock pin
    	rw equ p3.6				;read write pin of LCD
    	en equ p3.5				;enable pin of LCD
    	rs equ p3.7				;register select pin of LCD
    	alarm_key equ p3.3			;Alarm set key
    	time_key equ p3.2			;Time ser key
    	increment equ p1.3			;Increment value
    	decrement equ p1.2			;Decrement Value
    	alarm_port equ p1.4			;Alarm Buzzer port
    	alarm_flag equ 20h			;flag for alarm
    	time_flag equ 21h			;flag for time
    	ampm_flag equ 22h			;am/pm flag
    	alarm_on equ 23h			;Alarm on flag
    	alarm_off equ 24h			;alarm off flag
    	alarm_ring equ 25h			;alarm ring flag
    	alarm_hrs equ 58h			;Alarm hour register
    	alarm_min equ 59h			;Alarm Minutes register
    	alarm_chk_hour equ 5Ah			;Alarm hour check register
    	alarm_chk_min equ 5Bh			;Alarm min check register
    	ampm equ 61h				;AM/PM register
    	BELL equ 7h				;Bell icon
    	SPEAKER_OFF equ 1h			;speaker off icon
    	SPEAKER_ON equ 2h			;speaker on icon
    	CLOCK equ 3h				;clock icon
    	OK equ 4h				;ok icon
    	HEART equ 5h				;heart icon
    	MUSIC equ 6h				;music icon
    	org 0000h				;Starting of main program
    	ljmp start
    	org 03h					;interrupt for set time
    	setb time_flag
    	reti
    	org 13h					;Interrupt for set alarm
    	setb alarm_flag				;and switch off the alarm if on
    	jnb alarm_off,hmmm
    	setb alarm_port
    	mov a,#1h
    	lcall command
    	mov a,#81h
    	lcall command
    	mov a,#OK
    	acall data_in
    	mov r7,#35
    	disp_str < Alarm Off!>
    	setb tr0
    loooop:	jnb tf0,$
    	clr tf0
    	djnz r7,loooop
    	clr tr0
    	mov a,#1h
    	acall command
    	acall disp_const
    	setb alarm_off
    	setb alarm_on
    	clr alarm_flag
    	clr alarm_flag
    	clr alarm_on
    	setb alarm_port
    	clr alarm_off
    	clr alarm_flag
    	clr alarm_ring
    hmmm:	reti
    start:
    	;clear RAM
    	mov R0,#7FH
    	clr A
    clr_ram:
    	mov @R0,A
    	djnz R0, clr_ram
    	;Init I2C Port
    	lcall i2cinit
    	mov tmod,#1h				;start routine
    	mov sp,#10h
    	acall initial
    	acall build
    	mov a,#80h
    	acall command
    	mov a,#CLOCK
    	acall data_in
    	disp_str < Nguyen Ngoc Ha >		;Name display
    	mov r7,#50
    	setb tr0
    wloop:
    	jnb tf0,$
    	clr tf0
    	djnz r7,wloop
    	clr time_flag
    	clr alarm_flag
    	clr alarm_on
    	clr ampm_flag
    	setb alarm_port
    	lcall startc				;Reading invalid hour entry
    	mov a,#0d0h					;initialize the RTC if necessary
    	lcall send
    	lcall ack
    	mov a,#02h
    	lcall send
    	lcall ack
    	lcall rstart
    	mov a,#0d1h
    	acall send
    	acall ack
    	acall read
    	acall nak
    	acall stop
    	anl a,#1fh
    	cjne a,#12h,step
    step:
    	jnc done
    	acall startc				;Reading signature byte if same then no need
    	mov a,#0d0h					;of initialization else initialize the RTC
    	acall send
    	acall ack
    	mov a,#08h
    	acall send
    	acall ack
    	acall rstart
    	mov a,#0d1h
    	acall send
    	acall ack
    	acall read
    	acall nak
    	acall stop
    	cjne a,#'~',done
    	sjmp run
    done:
    	;acall initial
    	;acall disp_const
    	mov sec,#00h				;For more information about the RTC DS1307
    	mov min,#0h				;Please refer to the datasheet
    	mov hour,#52h				;21h for 24 hour format
    	mov days,#01h
    	mov date,#1h
    	mov month,#1h
    	mov year,#06h
    	mov alarm,#0
    	mov sig,#'~'
    	mov ahour,#0
    	mov amin,#0
    	mov r6,#0bh
    	mov r0,#sec
    	mov r1,#00h
    	acall rtc_ini				;initializing RTC if required
    run:
    	mov ie,#85h
    	acall initial
    	acall disp_const
    run1:
    	acall startc				;Actual Starting
    	mov a,#0d0h
    	acall send
    	acall ack
    	mov a,#00h
    	acall send
    	acall ack
    	mov r6,#0fh
    	acall rstart				;Reading the RCT content
    	mov a,#0d1h
    	acall send
    	acall ack
    	mov r0,#40h
    here:
    	lcall read
    	mov @r0,a
    	inc r0
    	cjne r6,#1,sendack
    	acall nak
    	sjmp naksent
    sendack:
    	acall ack
    naksent:
    	djnz r6,here
    	acall stop
    	acall display				;Display RTC
    	jnb time_flag,noset			;check for time flag if set the set the clock
    	clr time_flag
    	clr ea
    	acall time_set
    	clr time_flag
    	mov r6,#09h
    	mov r0,#30h
    	mov r1,#00h
    	acall rtc_ini
    	clr time_flag
    	mov a,#1h
    	acall command
    	mov a,#81h
    	acall command
    	mov a,#OK
    	acall data_in
    	clr time_flag
    	disp_str < Time Set!>
    	mov r7,#35
    	setb tr0
    looooop:jnb tf0,$
    	clr tf0
    	djnz r7,looooop
    	clr tr0
    	mov a,#1h
    	acall command
    	acall disp_const
    	setb ea
    noset:
    	jnb alarm_flag,noset1			;check for alarm flag if set then set alarm
    	clr alarm_flag
    	clr ea
    	lcall alarm_set
    	setb ea
    	setb alarm_on
    	clr alarm_flag
    	setb alarm_on
    noset1:
    	jnb alarm_ring,noset2			;check if alarm ring flag is set
    	lcall alarm_alarm			;if set then ring the alarm
    noset2:	ljmp run1				;Do everything again
    ;Initializing I2C Bus Communication
    i2cinit:
            setb sda
            setb scl
            ret
    ;ReStart Condition for I2C Communication
    rstart:
            clr scl
            setb sda
            setb scl
            clr sda
            ret
    ;Start Condition for I2C Communication
    startc:
            setb scl
            clr sda
            clr scl
            ret
    ;Stop Condition For I2C Bus
    stop:
            clr scl
            clr sda
            setb scl
            setb sda
            ret
    ;Sending Data to slave on I2C bus
    send:
            mov r7,#08
    back:
            clr scl
            rlc a
            mov sda,c
            setb scl
            djnz r7,back
            clr scl
            setb sda
            ret
    ;ACK and NAK for I2C Bus
    ack:
            clr sda
            setb scl
            clr scl
            setb sda
            ret
    nak:
            setb sda
            setb scl
            clr scl
            setb scl
            ret
    ;Receiving Data from slave on I2C bus
    read:
            mov r7,#08
    back2:
            clr scl
            setb scl
            mov c,sda
            rlc a
            djnz r7,back2
            clr scl
            setb sda
            ret
    recv:						;Recieving data from I2C bus
    	lcall read
    	lcall ack
    	mov @r0,a
    	inc r0
    	ret
    rtc_ini:acall startc				;RTC initialization subroutine
    	mov a,#0d0h
    	acall send
    	acall ack
    	mov a,r1
    	acall send
    	acall ack
    rtc_ini_loop:
    	mov a,@r0
    	acall send
    	acall ack
    	inc r0
    	inc r1
    	;acall stop
    	djnz r6,rtc_ini_loop
    	acall stop
    	ret
    initial:mov a,#38h				;LCD initialization subroutine
    	acall command
    	mov a,#0ch
    	acall command
    	mov a,#01h
    	acall command
    	mov a,#06h
    	acall command
    	ret
    build:	mov a,#40h				;Building custom character routine
    	acall command
    	build_char 0h,0h,0h,0h,0h,0h,0h,0h	 ;BELL
    	build_char 1h,3h,0fh,0fh,0fh,3h,1h,0h	 ;SPEAKER OFF
    	build_char 8h,10h,0h,18h,0h,10h,8h,0h	 ;SPEAKER ON
    	build_char 0h,0eh,15h,17h,11h,0eh,0h,0h	 ;CLOCK
    	build_char 0h,1h,3h,16h,1ch,8h,0h,0h	 ;OK
    	build_char 0ah,1fh,1fh,1fh,0eh,4h,0h,0h	 ;HEART
    	build_char 2h,3h,2h,0eh,1eh,0ch,0h,0h	 ;MUSIC
    	build_char 4h,0eh,0eh,0eh,1fh,0h,4h,0h	 ;BELL
    	ret
    display:mov r1,#40h				;Displaying RTC content
    	mov a,#0Cah
    	acall command
    	mov a,@r1
    	mov 50h,@r1
    	acall disp_val
    PASS:	inc r1
    	mov a,#0C7h
    	acall command
    	mov a,@r1
    	mov 51h,@r1
    	mov alarm_chk_min,@r1
    	acall disp_val
    PASS1:	inc r1
    	mov a,#0c4h
    	acall command
    	mov a,@r1
    	mov 52h,@r1
    	mov alarm_chk_hour,@r1
    	mov r4,a
    	anl a,#1fh
    	acall disp_val
    	mov a,r4
    	anl a,#20h
    	cjne a,#00h,pm
    	mov a,#0cdh
    	acall command
    	disp_str <am>
    	sjmp pass2
    pm:	mov a,#0cdh
    	acall command
    	disp_str <pm>
    PASS2:	inc r1
    	mov a,#80h
    	acall command
    	mov a,@r1
    	mov 53h,@r1
    	acall day
    PASS3:	inc r1
    	mov a,#88h
    	acall command
    	mov a,@r1
    	mov 54h,@r1
    	acall disp_val
    PASS4:	inc r1
    	mov a,#8bh
    	acall command
    	mov a,@r1
    	mov 55h,@r1
    	acall disp_val
    PASS5:	inc r1
    	mov a,#8eh
    	acall command
    	mov a,@r1
    	mov 56h,@r1
    	acall disp_val
    	jnb alarm_on,PASS6
    	inc r1
    	inc r1
    	inc r1
    	mov a,@r1
    	cjne a,52h,PASS6
    	inc r1
    	mov a,@r1
    	cjne a,51h,PASS6
    	setb alarm_ring
    	setb alarm_ring
    PASS6:	ret
    disp_val:					;Display 8-bit Decimal Value
    	push acc
    	mov r5,a
    	anl a,#0f0h
    	swap a
    	mov dptr,#ascii
    	movc a,@a+dptr
    	acall data_in
    	mov a,r5
    	anl a,#0fh
    	movc a,@a+dptr
    	acall data_in
    	pop acc
    	ret
    disp_const:					;Display constant characters
    	mov a,#8ah
    	acall command
    	mov a,#'/'
    	acall data_in
    	mov a,#8dh
    	acall command
    	mov a,#'/'
    	acall data_in
    	mov a,#0c6h
    	acall command
    	mov a,#':'
    	acall data_in
    	mov a,#0c9h
    	acall command
    	mov a,#':'
    	acall data_in
    	mov a,#0c0h
    	acall command
    	mov a,#BELL
    	acall data_in
    	mov a,#SPEAKER_OFF
    	acall data_in
    	ret
    command:acall busy				;Sending command to LCD
    	MOV P2,A
    	CLR rs
    	CLR rw
    	SETB en
    	CLR en
    	RET
    data_in:acall busy				;Sending data to LCD
    	SETB rs
    	MOV P2,A
    	CLR rw
    	SETB en
    	CLR en
    	RET
    busy:	;SETB P2.7				;Checking Busy flag
    	mov P2, #0FFH
    	CLR rs
    	SETB rw
    wait:	CLR en
    	SETB en
    	JB P2.7,wait
    	RET
    day:	push acc				;Displaying day subroutine for RTC
    	cjne a,#01,skip
    	disp_str < *Sun*>
    	ljmp exit
    skip:	cjne a,#02,skip2
    	disp_str < *Mon*>
    	ljmp exit
    skip2:	cjne a,#03,skip3
    	disp_str < *Tue*>
    	ljmp exit
    skip3:	cjne a,#04,skip4
    	disp_str < *Wed*>
    	sjmp exit
    skip4:	cjne a,#05,skip5
    	disp_str< *Thu*>
    	sjmp exit
    skip5:	cjne a,#06,skip6
    	disp_str < *Fri*>
    	sjmp exit
    skip6:	disp_str < *Sat*>
    exit:	pop acc
    	ret
    time_set:					;Setting time subroutine
    	jnb time_key,$
    	mov a,#1
    	acall command
    	mov a,#80h
    	acall command
    	mov a,#CLOCK
    	acall data_in
    	disp_str < set minutes:>
    	mov a,#0c5h
    	acall command
    	mov a,51h
    	acall disp_val
    	lcall hexdec
    key:	push acc
    	mov a,#0c5h
    	acall command
    	pop acc
    	jb increment,chk1
    	inc a
    	cjne a,#60,ok1
    	mov a,#0
    ok1:	jnb increment,$
    	lcall dechex
    	acall disp_val
    	lcall hexdec
    	sjmp key
    chk1:	jb decrement,chk2
    	dec a
    	cjne a,#0ffh,ok2
    	mov a,#59
    ok2:	jnb decrement,$
    	lcall dechex
    	acall disp_val
    	lcall hexdec
    	sjmp key
    chk2:	jb time_key,key
    	lcall dechex
    	mov min,a
    	jnb time_key,$
    	mov a,#1
    	acall command
    	mov a,#80h
    	acall command
    	mov a,#CLOCK
    	acall data_in
    	disp_str < set hours:>
    	mov a,#0c5h
    	acall command
    	mov a,52h
    	anl a,#1fh
    	acall disp_val
    	lcall hexdec
    key1:	push acc
    	mov a,#0c5h
    	acall command
    	pop acc
    	jb increment,chk3
    	inc a
    	cjne a,#13,ok3
    	mov a,#1
    ok3:	jnb increment,$
    	lcall dechex
    	acall disp_val
    	lcall hexdec
    	sjmp key1
    chk3:	jb decrement,chk4
    	dec a
    	cjne a,#0,ok4
    	mov a,#12
    ok4:	jnb decrement,$
    	lcall dechex
    	acall disp_val
    	lcall hexdec
    	sjmp key1
    chk4:	jb time_key,key1
    	lcall dechex
    	mov hour,a
    	jnb time_key,$
    	mov a,#1
    	acall command
    	mov a,#80h
    	acall command
    	mov a,#CLOCK
    	acall data_in
    	disp_str < set am/pm:>
    	mov a,52h
    	anl a,#20h
    	cjne a,#00h,pm1
    	mov a,#0c5h
    	acall command
    	disp_str <am>
    	setb ampm_flag
    	sjmp key2
    pm1:	mov a,#0c5h
    	acall command
    	disp_str <pm>
    	clr ampm_flag
    key2:	mov a,#0c5h
    	acall command
    	jb increment,chk5
    	jb ampm_flag,ok5
    	setb ampm_flag
    	disp_str <am>
    	hold
    	jnb increment,$
    	sjmp key2
    ok5:	clr ampm_flag
    	disp_str <pm>
    	hold
    	jnb increment,$
    	sjmp key2
    chk5:	jb decrement,chk6
    	jb ampm_flag,ok6
    	setb ampm_flag
    	disp_str <am>
    	hold
    	jnb decrement,$
    	sjmp key2
    ok6:	clr ampm_flag
    	disp_str <pm>
    	hold
    	jnb decrement,$
    	sjmp key2
    chk6:	jb time_key,key2
    	jnb ampm_flag,noam
    	mov a,hour
    	add a,#40h
    	sjmp nopm
    noam:	mov a,hour
    	add a,#60h
    nopm:	mov hour,a
    	jnb time_key,$
    	mov a,#1
    	acall command
    	mov a,#80h
    	acall command
    	mov a,#CLOCK
    	acall data_in
    	disp_str < set days:>
    	mov a,#0c5h
    	lcall command
    	mov a,53h
    	push acc
    	lcall day
    	pop acc
    key3:	push acc
    	mov a,#0c5h
    	lcall command
    	pop acc
    	jb increment,chk7
    	inc a
    	cjne a,#8,ok7
    	mov a,#1
    ok7:	jnb increment,$
    	push acc
    	lcall day
    	pop acc
    	sjmp key3
    chk7:	jb decrement,chk8
    	dec a
    	cjne a,#0,ok8
    	mov a,#7
    ok8:	jnb decrement,$
    	push acc
    	lcall day
    	pop acc
    	sjmp key3
    chk8:	jb time_key,key3
    	mov days,a
    	jnb time_key,$
    	mov a,#1
    	lcall command
    	mov a,#80h
    	lcall command
    	mov a,#CLOCK
    	lcall data_in
    	disp_str < set date:>
    	mov a,#0c5h
    	lcall command
    	mov a,54h
    	lcall disp_val
    	lcall hexdec
    key4:	push acc
    	mov a,#0c5h
    	lcall command
    	pop acc
    	jb increment,chk9
    	inc a
    	cjne a,#32,ok9
    	mov a,#1
    ok9:	jnb increment,$
    	lcall dechex
    	lcall disp_val
    	lcall hexdec
    	sjmp key4
    chk9:	jb decrement,chk10
    	dec a
    	cjne a,#0,ok10
    	mov a,#31
    ok10:	jnb decrement,$
    	lcall dechex
    	lcall disp_val
    	lcall hexdec
    	sjmp key4
    chk10:	jb time_key,key4
    	lcall dechex
    	mov date,a
    	jnb time_key,$
    	mov a,#1
    	lcall command
    	mov a,#80h
    	lcall command
    	mov a,#CLOCK
    	lcall data_in
    	disp_str < set month:>
    	mov a,#0c5h
    	lcall command
    	mov a,55h
    	lcall disp_val
    	lcall hexdec
    key5:	push acc
    	mov a,#0c5h
    	lcall command
    	pop acc
    	jb increment,chk11
    	inc a
    	cjne a,#13,ok11
    	mov a,#1
    ok11:	jnb increment,$
    	lcall dechex
    	lcall disp_val
    	lcall hexdec
    	sjmp key5
    chk11:	jb decrement,chk12
    	dec a
    	cjne a,#0,ok12
    	mov a,#12
    ok12:	jnb decrement,$
    	lcall dechex
    	lcall disp_val
    	lcall hexdec
    	sjmp key5
    chk12:	jb time_key,key5
    	lcall dechex
    	mov month,a
    	jnb time_key,$
    	mov a,#1
    	lcall command
    	mov a,#80h
    	lcall command
    	mov a,#CLOCK
    	lcall data_in
    	disp_str < set year:>
    	mov a,#0c5h
    	lcall command
    	mov a,56h
    	lcall disp_val
    	lcall hexdec
    key6:	push acc
    	mov a,#0c5h
    	lcall command
    	pop acc
    	jb increment,chk13
    	inc a
    	cjne a,#100,ok13
    	mov a,#0
    ok13:	jnb increment,$
    	lcall dechex
    	lcall disp_val
    	lcall hexdec
    	sjmp key6
    chk13:	jb decrement,chk14
    	dec a
    	cjne a,#0ffh,ok14
    	mov a,#99
    ok14:	jnb decrement,$
    	lcall dechex
    	lcall disp_val
    	lcall hexdec
    	sjmp key6
    chk14:	jb time_key,key6
    	jnb time_key,$
    	lcall dechex
    	mov year,a
    	mov alarm,#00
    	mov sig,#'~'
    	clr time_flag
    	ret
    alarm_set:					;Setting Alarm Subroutine
    	jnb alarm_key,$
    	mov a,#1
    	lcall command
    	mov a,#80h
    	lcall command
    	mov a,#BELL
    	lcall data_in
    	mov a,#0c5h
    	lcall command
    	mov a,#30h
    	lcall disp_val
    	lcall hexdec
    akey:	push acc
    	mov a,#0c5h
    	lcall command
    	pop acc
    	jb increment,achk1
    	inc a
    	cjne a,#60,aok1
    	mov a,#0
    aok1:	jnb increment,$
    	lcall dechex
    	lcall disp_val
    	lcall hexdec
    	sjmp akey
    achk1:	jb decrement,achk2
    	dec a
    	cjne a,#0ffh,aok2
    	mov a,#59
    aok2:	jnb decrement,$
    	lcall dechex
    	lcall disp_val
    	lcall hexdec
    	sjmp akey
    achk2:	jb alarm_key,akey
    	lcall dechex
    	mov alarm_min,a
    	jnb alarm_key,$
    	mov a,#1
    	lcall command
    	mov a,#80h
    	lcall command
    	mov a,#BELL
    	lcall data_in
    	mov a,#0c5h
    	lcall command
    	mov a,#44h
    	anl a,#1fh
    	lcall disp_val
    	lcall hexdec
    akey1:	push acc
    	mov a,#0c5h
    	lcall command
    	pop acc
    	jb increment,achk3
    	inc a
    	cjne a,#13,aok3
    	mov a,#1
    aok3:	jnb increment,$
    	lcall dechex
    	lcall disp_val
    	lcall hexdec
    	sjmp akey1
    achk3:	jb decrement,achk4
    	dec a
    	cjne a,#0,aok4
    	mov a,#12
    aok4:	jnb decrement,$
    	lcall dechex
    	lcall disp_val
    	lcall hexdec
    	sjmp akey1
    achk4:	jb alarm_key,akey1
    	lcall dechex
    	mov alarm_hrs,a
    	jnb alarm_key,$
    	mov a,#1
    	lcall command
    	mov a,#80h
    	lcall command
    	mov a,#BELL
    	lcall data_in
    	mov a,#0c5h
    	lcall command
    	mov a,alarm_hrs
    	anl a,#20h
    	cjne a,#20h,its_pm
    	disp_str <am>
    	setb ampm_flag
    	sjmp akey2
    its_pm:	disp_str <pm>
    	clr ampm_flag
    akey2:	mov a,#0c5h
    	lcall command
    	jb increment,achk5
    	jb ampm_flag,aok5
    	setb ampm_flag
    	disp_str <am>
    	hold
    	jnb increment,$
    	sjmp akey2
    aok5:	clr ampm_flag
    	disp_str <pm>
    	hold
    	jnb increment,$
    	sjmp akey2
    achk5:	jb decrement,achk6
    	jb ampm_flag,aok6
    	setb ampm_flag
    	disp_str <am>
    	hold
    	jnb decrement,$
    	sjmp akey2
    aok6:	clr ampm_flag
    	disp_str <pm>
    	hold
    	jnb decrement,$
    	sjmp akey2
    achk6:	jb alarm_key,akey2
    	jnb alarm_key,$
    	mov a,alarm_hrs
    	jb ampm_flag,anoam
    	add a,#60h
    	sjmp anopm
    anoam:	mov a,alarm_hrs
    	add a,#40h
    anopm:	mov alarm_hrs,a
    	mov ahour,alarm_hrs
    	mov amin,alarm_min
    	mov r6,#02h
    	mov r0,#39h
    	mov r1,#09h
    	lcall rtc_ini
    	mov a,#1h
    	lcall command
    	mov a,#81h
    	lcall command
    	mov a,#OK
    	lcall data_in
    	disp_str < Alarm On!>
    	mov a,#0c4h
    	lcall command
    	mov a,alarm_hrs
    	anl a,#1fh
    	lcall disp_val
    	mov a,#':'
    	lcall data_in
    	mov a,alarm_min
    	lcall disp_val
    	mov a,alarm_hrs
    	anl a,#20h
    	cjne a,#00h,ppm
    	disp_str < am>
    	sjmp ppass2
    ppm:	disp_str < pm>
    ppass2:	mov r7,#35
    	setb tr0
    looop:	jnb tf0,$
    	clr tf0
    	djnz r7,looop
    	clr tr0
    	mov a,#1h
    	lcall command
    	lcall disp_const
    	mov a,#SPEAKER_ON
    	lcall data_in
    	setb alarm_off
    	setb alarm_on
    	clr alarm_flag
    	clr alarm_flag
    	ret
    alarm_alarm:					;Alarm Ring subroutine
    	clr alarm_port
    	mov r3,#0ffh
    a_loop:	mov r4,#0ffh
    	djnz r4,$
    	djnz r3,a_loop
    	setb alarm_port
    	mov r3,#0ffh
    a_loop1:mov r4,#0ffh
    	djnz r4,$
    	djnz r3,a_loop1
    	clr alarm_port
    	mov r3,#0ffh
    a_loop2:mov r4,#0ffh
    	djnz r4,$
    	djnz r3,a_loop2
    	setb alarm_port
    	mov r3,#0ffh
    a_loop3:mov r4,#0ffh
    	djnz r4,$
    	djnz r3,a_loop3
    	clr alarm_port
    	mov r3,#0ffh
    a_loop4:mov r4,#0ffh
    	djnz r4,$
    	djnz r3,a_loop4
    	setb alarm_port
    	mov r3,#0ffh
    a_loop5:mov r4,#0ffh
    	djnz r4,$
    	djnz r3,a_loop5
    	clr alarm_port
    	mov r3,#0ffh
    a_loop6:mov r4,#0ffh
    	djnz r4,$
    	djnz r3,a_loop6
    	setb alarm_port
    	ret
    dechex:	mov b,#0ah				;Decimal to Hexadecimal conversion
    	div ab
    	mov 60h,b
    	mov b,#10h
    	mul ab
    	add a,60h
    	ret
    hexdec:	mov b,#10h				;Hexadecimal to deciaml conversion
    	div ab
    	mov 60h,b
    	mov b,#0ah
    	mul ab
    	add a,60h
    	ret
    ascii:						;ASCII lookup table
    db	30h,31h,32h,33h,34h,35h,36h,37h,38h,39h
    	end
    Mail:
ah25.ah25 Tìm hiểu thêm về ah25.ah25
