các pro giúp em với em đang phai làm đề tài ic thời gian thực dùng 98c51 với DS1307 hiển thị trên LCD code viết bằng ASM sắp phải báo cáo rồi các bác GIÚP EM VỚI
SELC bit p3.2 ;button (set time)
UP bit p3.3 ;select
RS bit P3.7
RW bit P3.6
E bit P3.5
BF bit P2.7
DBx equ P2 ;DB7-DB0
SDA BIT P1.1 ; BIT DATA
SCL BIT P1.0 ; XUNG CLOCK
byte_r DATA 30H ;
SALVE_ADD DATA 31H ; DIA CHI BYTE
BYTE_W DATA 32H ; du lieu ghi
SEC DATA 33H ;GIAY
MINU DATA 34H ;PHUT
HOUR DATA 35H ;GIO
DAY DATA 36H ;THU
DATE DATA 37H ;NGAY
MONTH DATA 38H ;THANG
YEAR DATA 39H ;NAM
MENU DATA 3AH ;TRANG THAI CHON SETUP
COUNT9 DATA 3BH ;DEM MOD9
MOD6 DATA 3CH
MOD3 DATA 3DH
MOD9 DATA 3EH
mod2 data 3fh
MOD1 DATA 40H
ADDREG DATA 41H ;DIA CHI THANH GHI TIME
setup_flag bit 09h ;co bao ban setup
FLAG BIT 08H ;ENABLE TIMEDATA
MOV BYTE_W,#10H ;SET nam
LCALL SEND_BYTE
LCALL RECV_ACK
LCALL STOP_BIT
RET
EXISR0: ;( VECTOR NGAT 0)
MOV R3,#100
MOV R4,#10
MOV R5,#10
LCALL DELAY
SETB SETUP_FLAG ;BAT CO BAO DANG SETUP
MOV A,MENU
CJNE A,#9,NOT9
MOV A,#0
JMP EQUA0
NOT9: INC A ;TANG MENU LEN 1
EQUA0:MOV MENU,A
MOV R6,A ;CAT MENU VAO R6
CJNE A,#0,SET_HOUR10
CLR SETUP_FLAG ;NEU MENU BANG 0 THI THOAT SETUP
JMP END_SET
SET_HOUR10:
CJNE A,#1,SET_HOUR
MOV A,#08H ;SET HOUR10
JMP NHAYPOINT
SET_HOUR:
CJNE A,#2,SET_MINU10
MOV A,#09H ;SET HOUR DON VI
JMP NHAYPOINT
SET_MINU10:
CJNE A,#3,SET_MINU ;NHAY DEN SET MINU DON VI
MOV A,#0BH ;SET MINU10
JMP NHAYPOINT
SET_MINU:
CJNE A,#4,SET_DATE10 ;NHAY DEN SET DATE10
MOV A,#0CH ;SET MINU DON VI
JMP NHAYPOINT
SET_DATE10:
CJNE A,#5,SET_DATE
MOV A,#48H ;SET DATE10
JMP NHAYPOINT
SET_DATE:
CJNE A,#6,SET_MONTH10
MOV A,#49H ;SET DATE DON VI
JMP NHAYPOINT
SET_MONTH10:
CJNE A,#7,SET_MONTH
MOV A,#4BH ;SET MONTH10
JMP NHAYPOINT
SET_MONTH:
CJNE A,#8,SET_YEAR
MOV A,#4CH ;SET MONTH DON VI
JMP NHAYPOINT
SET_YEAR:
CJNE A,#9,MENURESET
MOV A,#4FH ;SET YEAR DON VI
JMP NHAYPOINT
MENURESET:
MOV MENU,#0
NHAYPOINT: ;NHAY CON TRO TAI VI TRI SETUP
LCALL TOADO
LCALL NHAPNHAY
JMP END_SETUP
END_SET:
LCALL NOT_NHAPNHAY
END_SETUP:
RETI
MOV A,MOD6
CJNE A,#6,INC_MOD6 ;TAO BO DEM TU 0-6
MOV MOD6,#0
JMP END_MOD6
INC_MOD6:
INC MOD6
END_MOD6:
MOV A,MOD3
CJNE A,#3,INC_MOD3 ;TAO BO DEM TU 0-3
MOV MOD3,#0
JMP END_MOD3
INC_MOD3:
INC MOD3
END_MOD3:
MOV A,MOD2
CJNE A,#2,INC_MOD2 ;TAO BO DEM TU 0-2
MOV MOD2,#0
JMP END_MOD2
INC_MOD2:
INC MOD2
END_MOD2:
MOV A,MOD1
CJNE A,#1,INC_MOD1 ;TAO BO DEM TU 0-2
MOV MOD1,#0
JMP END_MOD1
INC_MOD1:
INC MOD1
END_MOD1:
MOV A,R6
CJNE A,#0,UP_HOUR10
;NEU BANG 0
JMP END_ISR1
UP_HOUR10:
CJNE A,#1,UP_HOUR
MOV A,MOD2
ADD A,#30H
LCALL W_CHAR ;;GHI KI TU MOI RA LCD
MOV ADDREG,#2 ;DIA CHI THANH GHI HOUR
MOV A,MOD2
LCALL ROTARE
ANL HOUR,#11001111B ;GIU NGUYEN PHAN DON VI
ORL A,HOUR
MOV R1,A
LCALL SET_TIME ;UP HOUR10
MOV A,#08H
LCALL TOADO
JMP END_ISR1
UP_HOUR:
CJNE A,#2,UP_MINU10
MOV A,MOD9
ADD A,#30H
MOV A,MOD9
ANL HOUR,#11110000B ;GIU NGUYEN HANG CHUC
ORL A,HOUR
MOV R1,A
LCALL SET_TIME ;UP HOUR DON VI
MOV A,#09H
LCALL TOADO
JMP END_ISR1
UP_MINU10:
CJNE A,#3,UP_MINU ;NHAY DEN SET MINU DON VI
MOV A,MOD6
ADD A,#30H
MOV ADDREG,#1 ;DIA CHI THANH GHI MINU
MOV A,MOD6
LCALL ROTARE
ANL MINU,#10001111B ;GIU NGUYEN PHAN DON VI
ORL A,MINU
MOV R1,A
LCALL SET_TIME ;UP MINU10
MOV A,#0BH
LCALL TOADO
JMP END_ISR1
UP_MINU:
CJNE A,#4,UP_DATE10 ;NHAY DEN UP DATE10
MOV A,MOD9
ADD A,#30H
MOV A,MOD9
ANL MINU,#11110000B ;GIU NGUYEN PHAN DON VI
ORL A,MINU
MOV R1,A
LCALL SET_TIME ;UP MINU DON VI
MOV A,#0CH
LCALL TOADO
JMP END_ISR1
UP_DATE10:
CJNE A,#5,UP_DATE
MOV A,MOD3
ADD A,#30H
MOV ADDREG,#4 ;DIA CHI THANH GHI MINU
MOV A,MOD3
LCALL ROTARE
ANL DATE,#11001111B ;GIU NGUYEN PHAN DON VI
ORL A,DATE
MOV R1,A
LCALL SET_TIME ;UP DATE10
MOV A,#48H
LCALL TOADO
JMP END_ISR1
UP_DATE:
CJNE A,#6,UP_MONTH10
MOV A,MOD9
ADD A,#30H
MOV ADDREG,#4 ;DIA CHI THANH GHI HOUR
MOV A,MOD9
ANL DATE,#11110000B ;GIU NGUYEN HANG CHUC
ORL A,DATE
MOV R1,A
LCALL SET_TIME ;UP DATE DON VI
MOV A,#49H
LCALL TOADO
JMP END_ISR1
UP_MONTH10:
CJNE A,#7,UP_MONTH
MOV A,MOD1
ADD A,#30H
MOV ADDREG,#5 ;DIA CHI THANH GHI MINU
MOV A,MOD1
LCALL ROTARE
ANL MONTH,#11101111B ;GIU NGUYEN PHAN DON VI
ORL A,MONTH
MOV R1,A
LCALL SET_TIME ;UP MONTH10
MOV A,#4BH
LCALL TOADO
JMP END_ISR1
UP_MONTH:
CJNE A,#8,UP_YEAR
MOV A,MOD9
ADD A,#30H
MOV ADDREG,#5 ;DIA CHI THANH GHI HOUR
MOV A,MOD9
ANL MONTH,#11110000B ;GIU NGUYEN HANG CHUC
ORL A,MONTH
MOV R1,A
LCALL SET_TIME ;UP MONTH DON VI
MOV A,#4CH
LCALL TOADO
JMP END_ISR1
UP_YEAR:
CJNE A,#9,END_ISR1
MOV A,MOD9
ADD A,#30H
MOV ADDREG,#6 ;DIA CHI THANH GHI HOUR
MOV A,MOD9
ANL YEAR,#11110000B ;GIU NGUYEN HANG CHUC
ORL A,YEAR
MOV R1,A
MOV A,#4FH
LCALL TOADO
JMP END_ISR1
END_ISR1:
RETI
;----DOC TIME TU SLAVE ----------------------------
MOV A,HOUR ;HIEN 10HOUR
ANL A,#00110000B
RR A
RR A
RR A
RR A ;QUAY PHAI 4BIT
ADD A,#30H
LCALL W_CHAR
MOV A,HOUR ;HIEN DON VI HOUR
ANL A,#00001111B
ADD A,#30H
LCALL W_CHAR
MOV A,#':'
LCALL W_CHAR
MOV A,MINU ;hien thi chuc minute
ANL A,#01110000B
RR A
RR A
RR A
ADD A,#30H
LCALL W_CHAR
MOV A,MINU ;hien don vi minute
ANL A,#00001111B
ADD A,#30H
LCALL W_CHAR
MOV A,#':'
LCALL W_CHAR
MOV A,SEC ;hien thi chuc minute
ANL A,#01110000B
RR A
RR A
RR A
ADD A,#30H
LCALL W_CHAR
MOV A,SEC ;hien don vi minute
ANL A,#00001111B
ADD A,#30H
LCALL W_CHAR
MOV A,#48H ;
LCALL TOADO
;--------------HIEN THI DATE
MOV A,DATE ;HIEN 10DATE
ANL A,#00110000B
RR A
RR A
RR A
ADD A,#30H
LCALL W_CHAR
MOV A,DATE ;HIEN DON VI DATE
ANL A,#00001111B
ADD A,#30H
LCALL W_CHAR
MOV A,#'/'
LCALL W_CHAR
MOV A,MONTH ;HIEN 10MONTH
ANL A,#00010000B
RR A
RR A
RR A
ADD A,#30H
LCALL W_CHAR
MOV A,MONTH ;HIEN DON VI MONTH
ANL A,#00001111B
ADD A,#30H
LCALL W_CHAR
MOV A,#'/'
LCALL W_CHAR
MOV A,YEAR ;HIEN 10YEAR
ANL A,#11110000B
RR A
RR A
RR A
ADD A,#30H
LCALL W_CHAR
MOV A,YEAR ;HIEN DON VI YEAR
ANL A,#00001111B
ADD A,#30H
LCALL W_CHAR
RET
;------------ LOAD TIME END--------------
;----------------FUNTION LCD----------------
W_CHAR: ;(KI TU CHUA TRONG A)
lcall test_bf
SETB RS ;THANH GHI DATA
CLR RW ;CHE DO GHI DR
MOV DBX,A
SETB E
CLR E
RET
WRITE_STR:
SETB RS
CLR RW
INC DPTR
CLR A
MOVC A,@A+DPTR
MOV DBX,A
SETB E
CLR E
CALL TEST_BF
DJNZ R0,WRITE_STR
RET
TOADO: ;( toa do can ghi, A)
CALL test_BF
CLR RS
CLR RW
ORL A,#10000000B
MOV DBX,A ;GHI TU O THU a
SETB E
nop
CLR E
RET
NHAPNHAY: ;(NHAP NHAY KI TU O VI TRI POINTER)
CALL test_BF
CLR RS
CLR RW
MOV DBX,#00001111B ;NHAY CON TRO
SETB E
nop
CLR E
RET
NOT_NHAPNHAY:
CALL test_BF
CLR RS
CLR RW
MOV DBX,#00001100B ;NHAY CON TRO
SETB E
nop
CLR E
RET
TEST_BF:
setb bf
CLR RS ;RS=0
SETB RW ;RW=1
MOV DBX,#0FFH
CHECK:CLR E
SETB E
JB BF,CHECK
SETB RS
CLR RW
ret
ROTARE:
; QUAY PHAI THANH GHI A 4 BIT
RR A
RR A
RR A
RR A
RET
DELAY: ; DELAY= (R3XR4XR5) US
LAPR3: DJNZ R3,LAPR3
LAPR4: DJNZ R4,LAPR3
LAPR5: DJNZ R5,LAPR4
RET
loop:
nop
nop
nop
nop
ret
END
