Giúp em sữa chữ ĐT0A trong đoạn code C này với
  • Giúp em sữa chữ ĐT0A trong đoạn code C này với
    Em đang làm đồ án môn học Vi Xữ Lý sử dụng PUC 16F877a...Tình hình la giáo viên dạy ASM mà em lai tìm được đoạn code C này...Trong này no viết chữ VIETNAM giờ em mún sữa lại chữ ĐT0A mong các anh giúp đỡ....sẵn tiện cho e hỏi khi làm mạch Quang Báo 4 led matrix thì khi sử dụng IC 595 thì có cần sữ dụng IC đệm 2803....cảm ơn các a trước
    #include <16f877a.h>
    #include <def_877a.h>
    #FUSES NOWDT, HS, NOPUT, NOPROTECT, NODEBUG,NOBROWNOUT, NOLVP, NOCPD, NOWRT
    #use fast_io(b)
    #use fast_io(d)
    #use delay(clock=20000000)
    int32 send_reg;
    int16 m,l,x,lap,s;
    int32 const chay[]={0x80000000,0x40000000,0x20000000,0x10000000,
    0x08000000,0x04000000,0x02000000,0x01000000,0x0080 0000,0x00400000,0x00200000,0x00100000,0x00080000,0 x00040000,0x00020000,0x00010000,
    0x00008000,0x00004000,0x00002000,0x00001000,0x0000 0800,0x00000400,0x00000200 ,0x00000100,
    0x00000080,0x00000040,0x00000020,0x00000010,0x0000 0008,0x00000004,0x00000002,0x00000001,0x00000000};
    const unsigned char data[]={
    // Bitmap Data Created by RTB (c) 2009 Bui Viet Hoang
    // 136 x 8 pixels - Monochrome
    // Vertical Scan Lines - Left to Right, Top to Bottom
    0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,
    0xFF,0xFF,0xFF,0x7E,0x00,0x7E,0xFF,0xFF,0xFF,0xFF, 0x00,0xFE,0xFE,0xFE,0xFF,
    0xC3,0xBD,0x7E,0x7E,0x7E,0xBD,0xC3,0xFF,0x1F,0xE3, 0xFC,0xE3,0x1F,0xFF,0x00,
    0x6E,0x6E,0x6E,0x7E,0xFF,0xFF,0xFF,0xFF,0x00,0x77, 0x77,0x77,0x8F,0xFF,0x7E,
    0x00,0x7E,0xFF,0xC3,0xBD,0x7E,0x7E,0x7E,0x7E,0xFF, 0xFF,0xFF,0xFF,0x1F,0xE3,
    0xFC,0xE3,0x1F,0xFF,0x7E,0x00,0x7E,0xFF,0x00,0x6E, 0x6E,0x6E,0x7E,0xFF,0x7F,
    0x7F,0x00,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0x00,0x3F, 0xCF,0xF3,0xFC,0x00,0xFF,
    0xF8,0xC3,0x3B,0x3B,0xC3,0xF8,0xFF,0x00,0x3F,0xCF, 0xF3,0xCF,0x3F,0x00,0xFF,
    0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
    #bit d7=send_reg.31
    void serout(){
    int8 n;
    for(n=0;n<=32;n++)
    output_low(pin_b0);
    if(d7!=0) output_high(pin_b0);
    output_low(pin_b1);
    output_high(pin_b1);
    send_reg=send_reg<<1;
    void display(){
    output_high(pin_b2);
    serout();
    output_low(pin_b3);
    output_high(pin_b3);
    void hc595(){
    m=32;
    x=0;
    for(x=0;x<=32;x++){
    output_d(data[l+m]);
    send_reg=chay[x];
    display();
    m--;
    void main(){
    set_tris_d(0);
    output_d(255);
    set_tris_b(0x00);
    while(1){
    l=0;
    for(l=0;l<=136;l++){
    for(s=0;s<=1;s++)
    for(lap=0;lap<=3;lap++){
    hc595();
icefrog Tìm hiểu thêm về icefrog
    20-02-2025, 11:52
