đồng hồ ma trận cơ bản
Nguyên văn bởi rierie Xem bài viếtđồng hồ ma trận cơ bảncaoson.vnatr@gmail.com
Thiết kế mạch điện tử
0914024690
Nguyên văn bởi caoson_vnatr Xem bài viếtsao phần hiển thị không rõ vậy anh. anh có thể xử lý lại được không ạ
Gmail:
Nguyên văn bởi tuankep6 Xem bài viếtđổi led mầu khác là nhìn rõ ngay thôi màcaoson.vnatr@gmail.com
0914024690
mã nguồn cơ bản bằng cách sử dụng Keil uVision3
#include "reg52.h"
#define uchar unsigned char
#define uint unsigned int
sbit S_DIO = P3^0;
sbit S_CLK = P3^1;
sbit R_CLK = P3^2;
sbit KEY_1 = P1^1;
sbit KEY_2 = P1^2;
sbit KEY_3 = P1^0;
sbit BEEP = P2^7;
sbit T_CLK = P3^5;
sbit T_IO = P3^6;
sbit T_RST = P3^7;
sbit ACC0 = ACC^0;
sbit ACC1 = ACC^1;
sbit ACC2 = ACC^2;
sbit ACC3 = ACC^3;
sbit ACC4 = ACC^4;
sbit ACC5 = ACC^5;
sbit ACC6 = ACC^6;
sbit ACC7 = ACC^7;
unsigned char code font[][7]={
0x38,0x44,0x64,0x54,0x4C,0x44,0x38,//0xF8,0x88,0x88,0x88,0x88,0x88,0xF8, //-----------'0'
0x10,0x18,0x10,0x10,0x10,0x10,0x38,//0x20,0x30,0x28,0x20,0x20,0x20,0xF8, //-----------'1'
0x38,0x44,0x40,0x20,0x10,0x08,0x7C,//0xF8,0x80,0x80,0xF8,0x08,0x08,0xF8, //-----------'2'
0x7C,0x20,0x10,0x20,0x40,0x44,0x38,//0xF8,0x80,0x80,0xF8,0x80,0x80,0xF8, //-----------'3'
0x20,0x30,0x28,0x24,0x7C,0x20,0x20,//0x48,0x48,0x48,0x48,0xF8,0x40,0x40, //-----------'4'
0x7C,0x04,0x3C,0x40,0x40,0x44,0x38,//0xF8,0x08,0x08,0xF8,0x80,0x80,0xF8, //-----------'5'
0x70,0x08,0x04,0x3C,0x44,0x44,0x38,//0xF8,0x08,0x08,0xF8,0x88,0x88,0xF8, //-----------'6'
0x7C,0x40,0x20,0x10,0x08,0x08,0x08,//0xF8,0x80,0x80,0x80,0x80,0x80,0x80, //-----------'7'
0x38,0x44,0x44,0x38,0x44,0x44,0x38,//0xF8,0x88,0x88,0xF8,0x88,0x88,0xF8, //-----------'8'
0x38,0x44,0x44,0x78,0x40,0x20,0x1C,//0xF8,0x88,0x88,0xF8,0x80,0x80,0x80, //-----------'9'
0x00,0x30,0x30,0x00,0x30,0x30,0x00, //-----10----':'
0x00,0x00,0x00,0x00,0x00,0x00,0x00, //-----11----' '
unsigned char idata DisTemp[5][7];
unsigned char idata Dis[5]={1,2,10,0,0};
unsigned char idata Time[7];
unsigned char idata CSRow[7]={0x01,0x02,0x04,0x08,0x10,0x20,0x40};
unsigned char idata second,minute,hour,day,month,week,year;
unsigned long int idata Disbuf[5];
unsigned long int idata Disbuftemp[7];
void Delay(unsigned int i)
unsigned int j;
for(j=0;j<i;j++);
void OutData(unsigned char Data)
SBUF=~Data;
while(TI==0);
TI=0;
unsigned char BCD2HEX(unsigned char BCDChar)
unsigned char temp;
temp=(BCDChar/16*10+BCDChar%16);
return temp;
unsigned char HEX2BCD(unsigned char HEXChar)
unsigned char temp;
temp=(HEXChar/10*16+HEXChar%10);
return temp;
void WriteByteDS1302(unsigned char Data)
unsigned char i;
ACC = Data;
for(i=8; i>0; i--)
T_IO = ACC0;
T_CLK = 1;
T_CLK = 0;
ACC = ACC >> 1;
unsigned char ReadByteDS1302(void)
unsigned char i;
for(i=8; i>0; i--)
ACC = ACC >>1;
ACC7 = T_IO;
T_CLK = 1;
T_CLK = 0;
return(ACC);
void WriteDS1302(unsigned char Addr,unsigned char Data)
T_RST = 0;
T_CLK = 0;
T_RST = 1;
WriteByteDS1302(Addr);
WriteByteDS1302(Data);
T_CLK = 1;
T_RST = 0;
unsigned char ReadDS1302(unsigned char Addr)
unsigned char Data;
T_RST = 0;
T_CLK = 0;
T_RST = 1;
Data = ReadByteDS1302();
T_CLK = 1;
T_RST = 0;
return(Data);
void Set(unsigned char sel,unsigned char selby)
unsigned char address,item;
unsigned char max,min;
if(sel==0) {address=0x80; max=59;min=0;} //
if(sel==1) {address=0x82; max=59;min=0;} //
if(sel==2) {address=0x84; max=23;min=0;} //
if(sel==3) {address=0x86; max=31;min=1;} //
if(sel==4) {address=0x88; max=12;min=1;} //
if(sel==5) {address=0x8a; max=7; min=1;} //
if(sel==6) {address=0x8c; max=99;min=0;} //
if(sel==7) {address=0xc0; max=59;min=0;} //
if(sel==8) {address=0xc2; max=23;min=0;} //
item=ReadDS1302(address+1)/16*10+ReadDS1302(address+1)%16;
if (selby==0) item++; else item--;
if(item>max) item=min;
if(item<min) item=max;
WriteDS1302(0x8e,0x00);
WriteDS1302(address,item/10*16+item%10);
WriteDS1302(0x90,0xa5);
WriteDS1302(0x8e,0x80);
void SetTime(unsigned char *pClock)
unsigned char h;
unsigned char Addr=0x80;
for(h=7; h>0; h--)
WriteDS1302(Addr,*pClock);
pClock++;
Addr+=2;
void ReadTime()
second = BCD2HEX(Time[0]=ReadDS1302(0x81));
minute = BCD2HEX(Time[1]=ReadDS1302(0x83));
hour = BCD2HEX(Time[2]=ReadDS1302(0x85));
day = BCD2HEX(Time[3]=ReadDS1302(0x87));
month = BCD2HEX(Time[4]=ReadDS1302(0x89));
year = BCD2HEX(Time[5]=ReadDS1302(0x8d));
week = BCD2HEX(Time[6]=ReadDS1302(0x8b));
void WriteTime()
WriteDS1302(0x80,HEX2BCD(second));
WriteDS1302(0x82,HEX2BCD(minute));
WriteDS1302(0x84,HEX2BCD(hour));
WriteDS1302(0x86,HEX2BCD(day));
WriteDS1302(0x88,HEX2BCD(month));
WriteDS1302(0x8A,HEX2BCD(week));
WriteDS1302(0x8C,HEX2BCD(year));
void DisProcess()
unsigned char i,j;
for(i=0;i<5;i++)
for(j=0;j<7;j++)
DisTemp[i][j]=font[Dis[i]][j];
for(i=0;i<7;i++)
Disbuf[0]=DisTemp[4][i];
Disbuf[1]=DisTemp[3][i];
Disbuf[2]=DisTemp[2][i];
Disbuf[3]=DisTemp[1][i];
Disbuf[4]=DisTemp[0][i];
Disbuftemp[i]=Disbuf[0]<<24|Disbuf[1]<<18|Disbuf[2]<<12|Disbuf[3]<<6|Disbuf[4];
void DisPlay()
unsigned char i,j;
for(i=0;i<7;i++)
P2=~0x00;
BEEP=1;
for(j=0;j<4;j++)
OutData(0x00);
R_CLK=1;R_CLK=0;
P2=~CSRow[i];
BEEP=1;
for(j=0;j<4;j++)
OutData(((unsigned char *)&Disbuftemp[i])[3-j]);
R_CLK=1;R_CLK=0;
Delay(350);
P2=~0x00;
BEEP=1;
for(j=0;j<4;j++)
OutData(0x00);
R_CLK=1;R_CLK=0;
void init(void)
EA=1;
SCON=0;//
ReadTime();//
DisPlay();
Dis[0]=hour/10;
Dis[1]=hour%10;
Dis[3]=minute/10;
Dis[4]=minute%10;
Dis[2]=10;
DisProcess();
void main()
init();
while(1)
ReadTime();
DisPlay();
if((hour/10)==0)
Dis[0]=11;
else
Dis[0]=hour/10;
Dis[1]=hour%10;
Dis[3]=minute/10;
Dis[4]=minute%10;
if((second%10)%2)
Dis[2]=11;
else
Dis[2]=10;
DisProcess();
if(KEY_1==0)
DisPlay();
if(KEY_1==0)
Set(2,0);
while(KEY_1==0)DisPlay();
if(KEY_2==0)
DisPlay();
if(KEY_2==0)
Set(1,0);
while(KEY_2==0)DisPlay();
if(KEY_3==0)
DisPlay();
if(KEY_3==0)
WriteDS1302(0x8e,0x00);//
WriteDS1302(0x80,0x00);//
WriteDS1302(0x90,0xa5);//
WriteDS1302(0x8e,0x80);//
while(KEY_3==0)DisPlay();
Hôm qua, 21:31 -
Hôm qua, 11:52 -
19-02-2025, 21:27 -
19-02-2025, 21:24 -
- Tôi cũng có vợ như thế....
19-02-2025, 21:04 -
17-02-2025, 06:08 -
17-02-2025, 01:38 -
