máy PC em đang bị lỗi nên ko biên dịch được anh nào có phần mềm này biên dịch giúp em với, nếu biên dịch được phai .hex thì gửi cho em dùm, em cám ơn nhiều.......rất mong được sự giúp đỡ. bacuongpl@gmai.com
#include <REGX51.H>
#define SEC 0x00
#define MIN 0x01
#define HOUR 0x02
#define DAY 0x03
#define DATE 0x04
#define MONTH 0x05
#define YEAR 0x06
#define A_MIN 0x08
#define A_HOUR 0x09
char sec,hour,min,day,date,month,year,year_20,a_min,a_h our;
sbit SDA = P1^0;
sbit SCL = P1^1;
sbit Mode = P1^2;
sbit Up = P1^3;
sbit Down = P1^4;
sbit Ok = P1^5;
sbit Alarm = P1^6;
sbit Loa = P1^7;
sbit L01 = P2^0;
sbit L02 = P2^1;
sbit L03 = P2^2;
sbit L04 = P2^3;
sbit L05 = P2^4;
sbit L06 = P2^5;
sbit L07 = P2^6;
sbit L08 = P2^7;
sbit L09 = P3^0;
sbit L10 = P3^1;
sbit L11 = P3^2;
sbit L12 = P3^3;
sbit L13 = P3^4;
sbit L14 = P3^5;
sbit L15 = P3^6;
sbit PM = P3^7;
// KHAI BAO BIEN, MANG...
unsigned char led7_data[10] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90 }; //Decimal to Led7seg
unsigned char Data,Display,time,index,mode,bat_nhay,read_time,al arm,kt,on_off;
// KHAI BAO HAM, CHUONG TRINH CON
void set_main(void); // Chuong trinh khoi tao main
void setup_timer(void); // Chuong trinh cai dat timer 1 va 0
void delay(unsigned int time); // Delay
void Fix_time(void); // Kiem tra va hieu chinh gia tri cua gio,phut,giay
void Keypad(void); // Kiem tra xu ly phim nhan.
void T1_ISR(void); //ngat timer 1 phuc vu nhay led
void T0_ISR(void); // Dung ngat timer 0 de quet led
void bip(void)
unsigned char n;
for(n=0;n<100;n++)
Loa=1; delay(50);
Loa=0; delay(50);
// CAC CHUONG TRINH CON CHO I2C
void I2C_start(void)
SCL = 1; SCL = 0;
SDA = 1; SCL = 1;
delay(2);
SDA = 0; delay(2);
SCL = 0; delay(2);
void I2C_stop(void)
SCL = 1; SCL = 0;
SDA = 0; delay(2);
SCL = 1; delay(2);
SDA = 1;
bit I2C_write(unsigned char dat)
unsigned char i;
for (i=0;i<8;i++)
SDA = (dat & 0x80) ? 1:0;
SCL=1;SCL=0;
dat<<=1;
SCL = 1; delay(2);
SCL = 0;
return dat;
unsigned char I2C_read(void)
bit rd_bit;
unsigned char i, dat;
dat = 0x00;
for(i=0;i<8;i++) /* For loop read data 1 byte */
delay(2);
SCL = 1; delay(2); /* Set SCL */
rd_bit = SDA; /* Keep for check acknowledge */
dat = dat<<1;
dat = dat | rd_bit; /* Keep bit data in dat */
SCL = 0; /* Clear SCL */
return dat;
// CAC CHUONG TRINH CON CHO DS1307
unsigned char DS1307_read(unsigned char addr)
unsigned int temp,ret;
I2C_start(); /* Start i2c bus */
I2C_write(0xD0); /* Connect to DS1307 */
I2C_write(addr); /* Request RAM address on DS1307 */
I2C_write(0XD1); /* Connect to DS1307 for Read */
ret = I2C_read(); /* Receive data */
I2C_stop();
temp = ret; /*BCD to HEX*/
ret = (((ret/16)*10)+ (temp & 0x0f)); /*for Led 7seg*/
return ret;
void DS1307_Write(unsigned char addr,unsigned char dat)
unsigned int temp;
temp = dat ; /*HEX to BCD*/
dat = (((dat/10)*16)|(temp %10)); /*for Led 7seg*/
I2C_write(0XD0); /* Connect to DS1307 */
I2C_write(dat); /* Connect to DS1307 for Read */
I2C_stop();
void Out_1Hz()
I2C_write(0x07); //vi tri con tro RTC
I2C_write(0x10);
I2C_stop();
void Read_DS1307()
sec = DS1307_read(SEC);
min = DS1307_read(MIN);
hour = DS1307_read(HOUR);
day = DS1307_read(DAY);
date = DS1307_read(DATE);
month = DS1307_read(MONTH);
year = DS1307_read(YEAR);
void Write_DS1307()
DS1307_Write(SEC,sec);
DS1307_Write(MIN,min);
DS1307_Write(HOUR,hour);
DS1307_Write(DAY,day);
DS1307_Write(DATE,date);
DS1307_Write(MONTH,month);
DS1307_Write(YEAR,year);
void Write_Alarm()
DS1307_Write(A_MIN,a_min);
DS1307_Write(A_HOUR,a_hour);
while(time--);
void set_main(void) // Chuong trinh khoi tao main
P1=0xFF;
P0=P2=P3=0x00;
void setup_timer(void) // Setup timer 0 va timer 1
TMOD=0x11; // timer0 & timer1 set che do 1
ET1=1; ET0=1; EA=1;
TF0=0; TF1=0;
TR0=1; TR1=1;
void Set_Clock(void) // Kiem tra va hieu chinh gia tri cua gio,phut,giay
unsigned char y;
y=(year%4)*100;
//Tang
if(min>59) { min=0; }
if(hour>23){ hour=0; }
if(day>8) day=2;
if((month==2)&&(date>29)&&(y==0)) { date=1; }
else if((month==2)&&(date>28)&&(y!=0)) { date=1; }
else if(((month==4)||(month==6)||(month==9)||(month==11 ))&&(date>30)&&(y!=0)){ date=1; }
else if(date>31) { date=1; }
if(month>12) { month=1; }
if(year>99) { year_20++; year=0; if(year_20>99){year_20=0;} }
//Giam
if(min<0) { min=59; }
if(hour<0) { hour=23; }
if(day<2) day=8;
if((month==2)&&(date<1)&&(y==0)) { date=29; }
else if((month==2)&&(date<1)&&(y!=0)) { date=28; }
else if(((month==4)||(month==6)||(month==9)||(month==11 ))&&(date<1)&&(y!=0)){ date=30; }
else if(date<1) { date=31; }
if(month<1) { month=12; }
if(year<0) { year_20--; year=99; if(year_20<0){year_20=99;} }
void Keypad(void) // Kiem tra phim nhan.
if(!Ok)
bip();
if(on_off==1)
Display=mode=alarm=0;
Write_Alarm();
else
Display=alarm=mode=0;
Write_DS1307();
if(Display==0)
if(!Mode)
bip(); mode++; sec=0;
if(mode==7)
mode=1;
if(mode==1)
if(!Up)
min=min+1; delay(50000);
if(!Down)
min=min-1; delay(50000);
if(mode==2)
if(!Up)
hour=hour+1; delay(50000);
if(!Down)
hour=hour-1; delay(50000);
if(mode==3)
if(!Up)
day=day+1; delay(50000);
if(!Down)
day=day-1; delay(50000);
if(mode==4)
if(!Up)
date=date+1; delay(50000);
if(!Down)
date=date-1; delay(50000);
if(mode==5)
if(!Up)
month=month+1; delay(50000);
if(!Down)
month=month-1; delay(50000);
if(mode==6)
if(!Up)
year=year+1; delay(50000);
if(!Down)
year=year-1; delay(50000);
if(!Alarm)
bip(); Display=1;
if(Display==1)
if(!Mode)
bip(); alarm++;
if(alarm==4)
alarm=1;
if(alarm==1)
if(!Up) //min++;
a_min=a_min+1; delay(50000);
if(!Down) //min--;
a_min=a_min-1; delay(50000);
if(alarm==2)
if(!Up) //hour++;
a_hour=a_hour+1; delay(50000);
if(!Down) //hour--;
a_hour=a_hour-1; delay(50000);
if(alarm==3)
if(!Up) //hour++;
on_off=1; delay(50000);
if(!Down) //hour--;
on_off=0; delay(50000);
Set_Clock();
delay(1000);
void T0_ISR(void) interrupt 1 // Dung ngat Timer0 de doc DS1307
TR0=0;
TF0=0;
TH0=0x3C; // Gia tri cho Timer0: 50000(us)x10=0.5(s)
TL0=0xAF;
time++;
if(time==10)
time=0; bat_nhay++; read_time=1;
if(bat_nhay==2) bat_nhay=0;
TR0=1;
void T1_ISR(void) interrupt 3 // Dung ngat Timer1 de hien thi 15 Led_7D
TR1=0;
TF1=0;
TH1=0xFC; // Gia tri cho Timer1: 1000(us) x 15 = 15(ms)
TL1=0x18;
if(Display==0)
index++;
if(index==1)
Data=sec;
P2=0x00; L09=L10=L11=L12=L13=L14=L15=0;
P0=0xff;
L01=0;
P0=led7_data[Data%10];//xuat gia tri hang don vi
if(index==2)
P0=0xff;
L02=0;
P0=led7_data[Data/10]; //xuat gia tri hang truc
if(index==3)
if(mode==1 && bat_nhay==1){ index++; index++; }
else
Data=min;
P0=0xff;
L03=0;
if(index==4)
P0=0xff;
L04=0;
if(index==5)
if(mode==2 && bat_nhay==1){ index++; index++; }
else
Data=hour;
P0=0xff;
L05=0;
if(index==6)
P0=0xff;
L06=0;
if(index==7)
if(mode==3 && bat_nhay==1){ index++; }
else
Data=day;
P0=0xff;
L15=0;
if(index==8)
if(mode==4 && bat_nhay==1){ index++; index++; }
else
Data=date;
P0=0xff;
L07=0;
P0=led7_data[Data/10];// xuat gia tri hang truc
if(index==9)
P0=0xff;
L08=0;
if(index==10)
if(mode==5 && bat_nhay==1){ index++; index++; }
else
Data=month;
P0=0xff;
L09=0;
if(index==11)
P0=0xff;
L10=0;
if(index==12)
if(mode==6 && bat_nhay==1){ index++; index++; }
else
Data=year;
P0=0xff;
L13=0;
if(index==13)
P0=0xff;
L14=0;
if(index==14)
Data=year_20;
P0=0xff;
L11=0;
if(index==15)
P0=0xff;
L12=0;
index=0;
if(Display==1)
index++;
if(index==1)
if(alarm==1 && bat_nhay==1){ index++; index++; }
else
Data=a_min;
P0=0xff;
L03=0;
if(index==2)
P0=0xff;
L04=0;
if(index==3)
if(alarm==2 && bat_nhay==1){ index++; index++; }
else
Data=a_hour;
P0=0xff;
L05=0;
if(index==4)
P0=0xff;
L06=0;
if(index==5)
if(alarm==3 && bat_nhay==1){ index++; index++; }
else
P0=0xff;
if(on_off==1)
L13=0;
P0=0xC8;
else
L13=0;
P0=0x8E;
if(index==6)
P0=0xff;
if(on_off==1)
L14=0;
P0=0xFF;
else
L14=0;
P0=0x8E;
if(index==7)
P0=0xff;
L12=0;
P0=led7_data[0];
index=0;
TR1=1;
//************ CHUONG TRINH CHINH *************
void main()
bip(); delay(10);
Out_1Hz();
set_main();
year_20=20;
time=index=mode=read_time=0;
setup_timer();
while(1)
Keypad();
if(hour>=12) PM=0;
else PM=1;
if((mode==0)&&(read_time==1))
read_time = 0;
Read_DS1307();
if(((a_min==min)&&(a_hour==hour)))
if(sec<59) { bip(); delay(10000);}
? M? Ngu?n Chương Tr?nh đ?ng h? s? Keil C
#include<regx52.h>
#include<math.h>
unsigned char a,b,nd;
unsigned char M[10]={0x40,0x79,0x24,0x30,0x19,0x12,0x03,0x78,0x00,0x1 8};
void delay(unsigned char time)
unsigned char i,j;
for(i=1;i<10;i++)
for(j=1;j<time;j++)
void hienthi(void)
a=nd/10;
b=nd%10;
P3=M[a];
P0_0=1;
P0_0=0;
delay(2);
P3=M[b];
P0_1=1; //mo
P0_1=0; //chot
delay(2);
void chuyendoi(void)
P1_0=1; //RD=1
P1_1=0; //WR=0
delay(2);
P1_1=1; //WR=1 bat dau chuyen doi
while(P1_2);//cho cho chuyen doi xong
P1_0=0; //dua du lieu ra cac chan D0 - D7
nd=P2;
void main()
P2=0xff; //dat P2 lam cong vao
P1_2=1; //dat P1_2 lam cong vao INTR
while(1)
chuyendoi();
hienthi();
#include <REGX51.H>
#define SEC 0x00
#define MIN 0x01
#define HOUR 0x02
#define DAY 0x03
#define DATE 0x04
#define MONTH 0x05
#define YEAR 0x06
#define A_MIN 0x08
#define A_HOUR 0x09
sbit SDA = P1^0;
sbit SCL = P1^1;
sbit Mode = P1^2;
sbit Up = P1^3;
sbit Down = P1^4;
sbit Ok = P1^5;
sbit Alarm = P1^6;
sbit Loa = P1^7;
sbit L01 = P2^0;
sbit L02 = P2^1;
sbit L03 = P2^2;
sbit L04 = P2^3;
sbit L05 = P2^4;
sbit L06 = P2^5;
sbit L07 = P2^6;
sbit L08 = P2^7;
sbit L09 = P3^0;
sbit L10 = P3^1;
sbit L11 = P3^2;
sbit L12 = P3^3;
sbit L13 = P3^4;
sbit L14 = P3^5;
sbit L15 = P3^6;
sbit PM = P3^7;
void bip(void)
unsigned char n;
for(n=0;n<100;n++)
Loa=1; delay(50);
Loa=0; delay(50);
SCL = 1; SCL = 0;
SDA = 1; SCL = 1;
delay(2);
SDA = 0; delay(2);
SCL = 0; delay(2);
void I2C_stop(void)
SCL = 1; SCL = 0;
SDA = 0; delay(2);
SCL = 1; delay(2);
SDA = 1;
unsigned char i;
for (i=0;i<8;i++)
SCL=1;SCL=0;
dat<<=1;
SCL = 1; delay(2);
SCL = 0;
return dat;
bit rd_bit;
dat = 0x00;
delay(2);
dat = dat<<1;
return dat;
I2C_stop();
return ret;
unsigned int temp;
I2C_stop();
void Out_1Hz()
I2C_write(0x10);
I2C_stop();
void Read_DS1307()
void Write_DS1307()
void Write_Alarm()
while(time--);
P1=0xFF;
P0=P2=P3=0x00;
ET1=1; ET0=1; EA=1;
TF0=0; TF1=0;
TR0=1; TR1=1;
unsigned char y;
y=(year%4)*100;
//Tang
if(day>8) day=2;
//Giam
if(day<2) day=8;
if(!Ok)
bip();
if(on_off==1)
Write_Alarm();
else
Write_DS1307();
if(Display==0)
if(!Mode)
if(mode==7)
mode=1;
if(mode==1)
if(!Up)
if(!Down)
if(mode==2)
if(!Up)
if(!Down)
if(mode==3)
if(!Up)
if(!Down)
if(mode==4)
if(!Up)
if(!Down)
if(mode==5)
if(!Up)
if(!Down)
if(mode==6)
if(!Up)
if(!Down)
if(!Alarm)
bip(); Display=1;
if(Display==1)
if(!Mode)
bip(); alarm++;
if(alarm==4)
alarm=1;
if(alarm==1)
if(!Up) //min++;
if(!Down) //min--;
if(alarm==2)
if(!Up) //hour++;
if(!Down) //hour--;
if(alarm==3)
if(!Up) //hour++;
if(!Down) //hour--;
Set_Clock();
delay(1000);
TR0=0;
TF0=0;
TL0=0xAF;
time++;
if(time==10)
TR0=1;
TR1=0;
TF1=0;
TL1=0x18;
if(Display==0)
index++;
if(index==1)
Data=sec;
P0=0xff;
L01=0;
if(index==2)
P0=0xff;
L02=0;
if(index==3)
else
Data=min;
P0=0xff;
L03=0;
if(index==4)
P0=0xff;
L04=0;
if(index==5)
else
Data=hour;
P0=0xff;
L05=0;
if(index==6)
P0=0xff;
L06=0;
if(index==7)
else
Data=day;
P0=0xff;
L15=0;
if(index==8)
else
Data=date;
P0=0xff;
L07=0;
if(index==9)
P0=0xff;
L08=0;
if(index==10)
else
Data=month;
P0=0xff;
L09=0;
if(index==11)
P0=0xff;
L10=0;
if(index==12)
else
Data=year;
P0=0xff;
L13=0;
if(index==13)
P0=0xff;
L14=0;
if(index==14)
Data=year_20;
P0=0xff;
L11=0;
if(index==15)
P0=0xff;
L12=0;
index=0;
if(Display==1)
index++;
if(index==1)
else
Data=a_min;
P0=0xff;
L03=0;
if(index==2)
P0=0xff;
L04=0;
if(index==3)
else
Data=a_hour;
P0=0xff;
L05=0;
if(index==4)
P0=0xff;
L06=0;
if(index==5)
else
P0=0xff;
if(on_off==1)
L13=0;
P0=0xC8;
else
L13=0;
P0=0x8E;
if(index==6)
P0=0xff;
if(on_off==1)
L14=0;
P0=0xFF;
else
L14=0;
P0=0x8E;
if(index==7)
P0=0xff;
L12=0;
P0=led7_data[0];
index=0;
TR1=1;
void main()
bip(); delay(10);
Out_1Hz();
set_main();
year_20=20;
setup_timer();
while(1)
Keypad();
if(hour>=12) PM=0;
else PM=1;
read_time = 0;
Read_DS1307();
#include<regx52.h>
#include<math.h>
unsigned char i,j;
for(i=1;i<10;i++)
for(j=1;j<time;j++)
void hienthi(void)
a=nd/10;
b=nd%10;
P3=M[a];
P0_0=1;
P0_0=0;
delay(2);
P3=M[b];
P0_1=1; //mo
P0_1=0; //chot
delay(2);
P1_0=1; //RD=1
P1_1=0; //WR=0
delay(2);
nd=P2;
void main()
while(1)
chuyendoi();
hienthi();
