các bác ơi em tăng delay lên gấp đôi rồi nhưng hok chạy các bác xem lại code giúp em
giúp em với
Nguyên văn bởi ozonedark2 Xem bài viếtcode nay em lap trình cho thạch anh 12mhz thì chay tốt nhưng gắn con thạch anh 24mhz thì hok chạy ai giúp em sửa lại với
Code:;*************************************************** ;CHUONG TRINH DIEU KHIEN LCD HIEN THI DONG CHU 1 DICH CHUYEN, DONG CHU 2 DUNG YEN ;*************************************************** ;RS -> P0.0, RW -> P0.1, E -> P0.2 ;DATA BUS -> PORT 1 ;*************************************************** EN BIT P0.2 RW BIT P0.1 RS BIT P0.0 DATABUS EQU P1 ;*************************************************** ORG 0000H call ktao_lcd tudau: call hthi_dong1 call delay1s call hthi_dong2 call delay1s jmp tudau ktra_co: setb databus.7 clr rs setb rw cho: clr en nop nop setb en nop nop jb databus.7,cho ret ktao_lcd: mov a,#38h call ghi_lenh mov a,#0eh call ghi_lenh mov a,#01h call ghi_lenh mov a,#06h call ghi_lenh ret ghi_lenh: call ktra_co mov databus,a clr rs clr rw setb en nop nop nop nop clr en ret ghi_dulieu: call ktra_co mov databus,a setb rs clr rw setb en nop nop nop nop clr en ret delay100ms: mov 51h,#200 doi: mov 52h,#250 djnz 52h,$ djnz 51h,doi ret delay1s: mov r7,#5 nhay: call delay100ms djnz r7,nhay ret hthi_dong1: mov a,#80h call ghi_lenh mov dptr,#dong1 call hienthi ret hthi_dong2: mov a,#0c0h call ghi_lenh mov dptr,#dong2 call hienthi ret hienthi: mov a,#0 movc a,@a+dptr cjne a,#99h,h ret h: mov databus,a call ghi_dulieu inc dptr jmp hienthi dong1: db 'lop hoc vdk ' db 99h dong2: db ' truong dh cntp ' db 99h end
16-11-2024, 15:34 -
16-11-2024, 10:39 -
15-11-2024, 08:27 -
10-11-2024, 08:52 -
10-11-2024, 08:47 -
09-11-2024, 13:36 -
09-11-2024, 12:55 -
