Cảm ơn bác zemen rất nhiều. Hy vọng được các bác thỉnh giáo nhiều. Mình chạy được rồi
HƯỚNG DẪN LẬP TRÌNH KEIL C CHO 8051-[Chỉ dành post bài hướng dẫn]
Lại cần sự giúp đỡ...
Thế này các bác ạ.Code:ORG 0000H PORT2: LCALL DELAY MOV P2,# 00000000B LCALL DELAY MOV P2,# 00000001B LCALL DELAY MOV P2,# 00000011B LCALL DELAY MOV P2,# 00000111B LCALL DELAY MOV P2,# 00001111B LCALL DELAY MOV P2,# 00011111B LCALL DELAY MOV P2,# 00111111B LCALL DELAY MOV P2,# 01111111B LCALL DELAY; MOV P2,# 11111111B LCALL DELAY MOV P2,# 00000000B LCALL DELAY2S MOV P2,# 11111111B LCALL DELAY MOV P2,# 01111111B LCALL DELAY MOV P2,# 00111111B LCALL DELAY MOV P2,# 00011111B LCALL DELAY MOV P2,# 00001111B LCALL DELAY MOV P2,# 00000111B LCALL DELAY MOV P2,# 00000011B LCALL DELAY MOV P2,# 00000001B LCALL DELAY MOV P2,# 00000000B LCALL DELAY05S MOV P2,# 11111111B MOV P2,# 01111111B MOV P2,# 00111111B MOV P2,# 00011111B MOV P2,# 00001111B MOV P2,# 00000111B MOV P2,# 00000011B MOV P2,# 00000001B LCALL DELAY SJMP PORT2 ;------CHUONG TRINH CON DELAY 1S--------- DELAY1S: CLR TF1 MOV TMOD,# 10H MOV R3,# 25 AGAIN1: MOV TL1, #0FEH MOV TH1,# 6FH SETB TR1 BACK1: JNB TF1, BACK1 CLR TR1 CLR TF1 DJNZ R3, AGAIN1 RET ;------CHUONG TRINH CON DELAY 0.5S-------- DELAY05S: CLR TF1 MOV TMOD,# 10H MOV R3,# 13 AGAIN2: MOV TL1, #0FEH MOV TH1,# 6FH SETB TR1 BACK2: JNB TF1, BACK2 CLR TR1 CLR TF1 DJNZ R3, AGAIN2 RET ;------CHUONG TRINH CON DELAY 2S------ DELAY2S: CLR TF1 MOV TMOD,# 10H MOV R3,# 50 AGAIN3: MOV TL1, #0FEH MOV TH1,# 6FH SETB TR1 BACK3: JNB TF1, BACK3 CLR TR1 CLR TF1 DJNZ R3, AGAIN3 RET ;------CHUONG TRINH CON DELAY------ DELAY: MOV R6,#0FFH HERE2: MOV R7,#0FFH HERE1: DJNZ R7,HERE1 DJNZ R6,HERE2 RET END
Code:Build target 'Simulator' Build target 'Simulator' D:\BaiTapLapTrinhVDK\Led3.asm(50): error A51: TARGET OUT OF RANGE Target not created
Nguyễn Văn Toàn
em cocai1 code như thế này
;**************/////--- 8 LED SANG LAN LUOT- CACH DON GIAN ---\\\\\\**************
;**////////////////___ led sang lan luot tu led 1 den led 8___________\\\\\\\\\\\\\\\\\\\\\\\\\\\
;**///////////////___ sang o muc 1 va tat o muc 0__________________\\\\\\\\\\\\\\\\\\\\\\\\\
;**//////////////____ lap di lap lai khong gioi han____________________\\\\\\\\\\\\\\\\\\\\\
;** \\\\\\\\\\\\------- nap gia tr? cho tung trang thai ------------------------------////////////////
ORG 000H ; khai bao dia chi de bat dau chuong trinh tren Rom
Mov P0,#0 ;===>>>> |||
Mov P1,#0 ;===>>>> ||| cac led deu tat
Mov P2,#0 ;===>>>> |||
Mov P3,#0 ;===>>>> |||
LCall Delay ;===>>>>goi chuong trinh con Delay
Xuat: ;**>>>>>>>>>>>>>>>>>>> lam led P0 sang <<<<<<<<<<<<<<<<<<<<<<<<<<
Mov P0,#00000001B ;===>>>> lam led 1 sang
Mov P0,#00000010B ;===>>>> lam led 2 sang
LCall Delay
Mov P0,#00000100B ;===>>>> lam led 3 sang
LCall Delay
Mov P0,#00001000B ;===>>>> lam led 4 sang
LCall Delay
Mov P0,#00010000B ;===>>>> lam led 5 sang
LCall Delay
Mov P0,#00100000B ;===>>>> lam led 6 sang
LCall Delay
Mov P0,#01000000B ;===>>>> lam led 7 sang
LCall Delay
Mov P0,#10000000B ;===>>>> lam led 8 sang
LCall Delay
;**>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>lam led P0 sang <<<<<<<<<<<<<<<<<<<
Mov P0,#00000000B ;===>>>> lam P0 tat
LCall Delay
Mov P0,#00000011B ;===>>>> lam led 2 sang
LCall Delay
Mov P0,#00000111B ;===>>>> lam led 3 sang
LCall Delay
Mov P0,#00001111B ;===>>>> lam led 4 sang
LCall Delay
Mov P0,#00011111B ;===>>>> lam led 5 sang
LCall Delay
Mov P0,#00111111B ;===>>>> lam led 6 sang
LCall Delay
Mov P0,#01111111B ;===>>>> lam led 7 sang
LCall Delay
Mov P0,#11111111B ;===>>>> lam led 8 sang
LCall Delay
Mov P0,#01111111B ;===>>>> lam led 8 tat
LCall Delay
Mov P0,#00111111B ;===>>>> lam led 7 tat
LCall Delay
Mov P0,#00011111B ;===>>>> lam led 6 tat
LCall Delay
Mov P0,#00001111B ;===>>>> lam led 5 tat
LCall Delay
Mov P0,#00000111B ;===>>>> lam led 4 tat
LCall Delay
Mov P0,#00000011B ;===>>>> lam led 3 tat
LCall Delay
Mov P0,#00000001B ;===>>>> lam led 2 tat
LCall Delay
;**>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> lam led P2 sang <<<<<<<<<<<<<<<<<<
Mov P2,#00000001B ;===>>>> lam led 1 sang
LCall Delay
Mov P2,#00000010B ;===>>>> lam led 2 sang
LCall Delay
Mov P2,#00000100B ;===>>>> lam led 3 sang
LCall Delay
Mov P2,#00001000B ;===>>>> lam led 4 sang
LCall Delay
Mov P2,#00010000B ;===>>>> lam led 5 sang
LCall Delay
Mov P2,#00100000B ;===>>>> lam led 6 sang
LCall Delay
Mov P2,#01000000B ;===>>>> lam led 7 sang
LCall Delay
Mov P2,#10000000B ;===>>>> lam led 8 sang
LCall Delay
Mov P2,#01000000B ;===>>>> lam led 8 tat
LCall Delay
Mov P2,#00100000B ;===>>>> lam led 7 tat
LCall Delay
Mov P2,#00010000B ;===>>>> lam led 6 tat
LCall Delay
Mov P2,#00001000B ;===>>>> lam led 5 tat
LCall Delay
Mov P2,#00000100B ;===>>>> lam led 4 tat
LCall Delay
Mov P2,#00000010B ;===>>>> lam led 3 tat
LCall Delay
Mov P2,#00000001B ;===>>>> lam led 2 tat
LCall Delay
;**>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>lam led P2 sang <<<<<<<<<<<<<<<<<<<
Mov P2,#00000000B ;===>>>> lam P2 tat
Mov P2,#01010101B ;===>>>> lam led nhay qua
LCall Delay
Mov P2,#10101010B ;===>>>> lam led nhay lai
LCall Delay
LCall Delay
LCall Delay
LCall Delay
LCall Delay
LCall Delay
LCall Delay
LCall Delay
LCall Delay
LCall Delay
Mov P2,#10000001B ;===>>>> lam led 8 va 1 sang
LCall Delay
Mov P2,#10000010B ;===>>>> lam led 8 va 2 sang
LCall Delay
Mov P2,#10000100B ;===>>>> lam led 8 va 3 sang
LCall Delay
Mov P2,#10001000B ;===>>>> lam led 8 va 4 sang
LCall Delay
Mov P2,#10010000B ;===>>>> lam led 5 sang
LCall Delay
Mov P2,#10100000B ;===>>>> lam led 5 sang
LCall Delay
Mov P2,#110000000B ;===>>>> lam led 5 sang
LCall Delay
Mov P2,#00000000B ;===>>>> lam led P2 tat
Ljmp Xuat ; ===>>>> nhay ve thuc hien tu dau
;**>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> delay <<<<<<<<<<<<<<<<<<<<<<<<<<<<
Delay:
Mov R7,#0FFH ;===>>>> gan R7=#0FFH, 1 chu ki may
Kt2: Mov R6,#0FFH ;===>>>> gan R6=#0FFH, 1 chu ki may
Kt1: Djnz R6,Kt1 ;===>>>> giam R6 xuong 1, R6 khac 0-> giam tiep
Djnz R7,Kt2 ;===>>>> giam R7 xuong 1, R6 khac 0-> ve Kt2
Ret ;===>>>> ket thuc chuong trinh con
;_________________________________________________ ________________________________
End ;===>>>> ket thuc chuong trinh
có ai bit thi chỉ em cách làm cho nó chạy chậm lại dc ko8051 là con em viết thành thạo. em sẵn sàng giúp đỡ các pác nếu em có thể
Nguyên văn bởi daominhchien Xem bài viếtTôi vào xem thử mà lằng nhằng ko mở xem đc, bạn hướng dẫn kỹ hơn chút
bạn up lại lên được không ạ?
cảm ơn nhé!
ko hỉu sao nạp vào chip 1 mà nó nháy nhanh đến nỗi thấy giật giật
Delay:
Mov R5,#005H
Kt3: Mov R7,#0FFH ;===>>>> gan R7=#0FFH, 1 chu ki may
Djnz R5,Kt3----------------------
Bể học là mênh mông!
giúp mình với (viết bằng chương trình keil)
Vẽ sơ đồ phần cứng và viết chương trình đồng hồ điện tử trên LCD16x2 có chức năng chính như sau:
- Về phần cứng: một LCD 16x2
- Chương trình:
o Line 1 của LCD hiển thị : “Digital clock”
o Line 2 của LCD hiển thị : HH:MM:SSLast edited by peterhuynhha; 26-03-2009, 13:06.
- Chương trình:
o Line 2 của LCD hiển thị : HH:MM:SS----------------------
Nguyên văn bởi hoangphat Xem bài viếtem cocai1 code như thế này
vâng cảm ơn các pác trch đã chỉ giáo em làm dc rồi thanks
Bạn thử tăng thời gian trễ trong hàm Delay nhiều hơn nữa, thay đổi giá trị R5 -> ở đây thời gian nháy sẽ giảm đi 5 lần so với ban đầu.
Delay:
Mov R5,#005H
Djnz R5,Kt38051 là con em viết thành thạo. em sẵn sàng giúp đỡ các pác nếu em có thể
em mới tập tọe với Vdk bằng ngôn ngữ C! em đang làm cái mạch chạy chữ trên led matran 8x8! viết xong lập trình tưởng chạy ngon ai dè nó báo lỗi! nó báo lệnh ">>" sai! Hình như là do thư viện reg51.h ko hỗ trợ! anh nào có thể cho em biết muốn dùng lệnh đó cần khai báo thêm thư viện nào không ạ?Web:
->Nhận thiết kế, hoàn thiện dự án, sản phẩm điện tử<-
-->Giải pháp GSM/GPRS/GPS - Công nghệ RFID<--
thư viện reg51.h chỉ chứa định nghĩa các thanh ghi cho 8051 thôi, không liên quan đến tập lệnh.
Tập lệnh do trình dịch quy định. Bạn dùng trình dịch gì, có thể đưa code chi tiết lên để mọi người xem sai ở đâu.
Lệnh >> đều có ở các trình dịch, nên chắc bạn sai ở chỗ khác thôi!----------------------
các xsu huynh em bi lỗi như này thi là tại sao?
Build target 'Target 1'
compiling 456.c...
456.C(9): error C141: syntax error near ')'
Target not created
#include<regx51.h>
#define led P1_0
void delay(unsigned int ms)
unsigned int i;
unsigned char j;
for(i=0;i<ms;i++)
for(j=0;j<120;j++)
main()
While(1)
led=0;
delay(1000);
led=1;
delay(1000);
cảm ơn các bác nhé các bac giúp em nhanh nhé!!!!!!!!!!111Last edited by hero8x; 02-04-2009, 16:19.
hôm nay, 00:35 -
Qua cổng song song LPT cổ
Hôm qua, 15:56 -
Hôm qua, 15:32 -
Channel: Vi điều khiển AVR
21-11-2024, 21:00 -
21-11-2024, 16:20 -
21-11-2024, 15:10 -
21-11-2024, 15:10 -
20-11-2024, 14:40 -
Channel: từ PIC tới dsPIC
20-11-2024, 07:20 -
19-11-2024, 22:44 -
