Dành cho người mới tìm hiểu 8051
co bac nao co the thu gon code nay zum e k za. e chỉ mói tập tành thôi nên chua ranh lam. cảm ơn các bác trước nha !
mong các bác giúp đỡ giùm
#include <REGX51.H>
#define sang 1
#define tat 0
sbit led1=P1^0;
sbit led2=P1^1;
sbit led3=P1^2;
sbit led4=P1^3;
sbit led5=P1^4;
sbit led6=P1^5;
sbit led7=P1^6;
sbit led8=P1^7;
sbit led9=P3^0;
sbit led10=P3^1;
sbit led11=P3^2;
sbit led12=P3^3;
sbit led13=P3^4;
sbit led14=P3^5;
sbit led15=P3^6;
sbit led16=P3^7;
void delay( unsigned int ms )
unsigned int i,j;
for (i=0;i<ms;i++)
for (j=0;j<120;j++)
void display_led(unsigned char number)
switch (number)
case 1:
P1=P3=0x80;
break;
case 2:
P1=P3=0x40;
break;
case 3:
P1=P3=0x20;
break;
case 4:
P1=P3=0x10;
break;
case 5:
P1=P3=0x08;
break;
case 6:
P1=P3=0x04;
break;
case 7:
P1=P3=0x02;
break;
case 8:
P1=P3=0x01;
break;
void chopled (unsigned char n)
{ switch (n)
case 1:
P1=P3=0x00; delay(500);
P1=P3=0xff;
break ;
case 2:
P1=P3=0xff;
break;
case 3:
P1=P3=0xff;
break;
case 4:
P1=P3=0xff;
break;
main ()
unsigned char m;
P0=P1=P2=P3=0x00;
while(1)
for (m=0;m<9;m++)
display_led(m); delay(500);
for(m=0;m<4;m++)
chopled(m); delay(500);
P1=P3=0x01; delay(500);
for(m=0;m<8;m++)
P3=P1=P1<<1; delay(500);
P1=P3=0xff; delay(500);
for(m=0;m<8;m++)
P1=P3=P3>>1; delay(500);
for(m=0;m<8;m++)
for(m=0;m<8;m++)
for(m=0;m<8;m++)
for(m=0;m<4;m++)
P1=0x01; delay(500);
P1=0x03; delay(500);
P1=0x07; delay(500);
P1=0x0f; delay(500);
P1=0x1f; delay(500);
P1=0x3f; delay(500);
P1=0x7f; delay(500);
P1=0xff; delay(500);
P1=0xff;
P3=0x80; delay(500);
P3=0xc0; delay(500);
P3=0xe0; delay(500);
P3=0xf0; delay(500);
P3=0xf8; delay(500);
P3=0xfc; delay(500);
P3=0xfe; delay(500);
P3=0xff;
P1=0xfe; delay(500);
P1=0xfc; delay(500);
P1=0xf8; delay(500);
P1=0xf0; delay(500);
P1=0xe0; delay(500);
P1=0xc0; delay(500);
P1=0x80; delay(500);
P1=0x00; delay(500);
P1=0x00;
P3=0x7f; delay(500);
P3=0x3f; delay(500);
P3=0x1f; delay(500);
P3=0x0f; delay(500);
P3=0x07; delay(500);
P3=0x03; delay(500);
}TÌNH YÊU KHÔNG TỰ SINH RA CŨNG KHÔNG TỰ MÂT ĐI
MÀ NÓ CHỈ CHUYỂN HÓA TỪ NGƯỜI NÀY SANG NGƯỜI KHÁC . . . ! ! ! !...
ý tưởng là như dầy.
- sáng led1 va led16 từ ngoài vào trong (led1-->led7,led8<--led16) và ngược lại ( led1<--led7,led8-->led16 )
- chóp tất tất cả các led
-sáng lang tu led1-->led16 va ngược lại led1<--led16
- lại chóp tất led
như vậy thôi cũng được rồi.
cảm ơn bác nhiều !TÌNH YÊU KHÔNG TỰ SINH RA CŨNG KHÔNG TỰ MÂT ĐI
Nguyên văn bởi quynh Xem bài viếtBây giờ bạn lại muốn 8 con led cùng nhấp nháy thì làm sao?cực kỳ đơn giản.
Nối các led như vd trên vào P1(từ P1.0->P1.7)
và chương trình sẽ là:
________________
Code:#include<regx51.h> void delay(unsigned int ms)//hàm này tạo độ trễ thời gian, dơn vị là ms { unsigned int i; unsigned char j;//khai báo kiểu "char"mỗi biến chỉ chiếm 1 byte for(i=0;i<ms;i++) for(j=0;j<120;j++) {}//không làm gì cả } main()//Chương trình chính { While(1)//tạo vòng lặp vô hạn { P1=0x00;//"0x00"là giá trị viết trong hệ hex, cái này=00000000 delay(1000);//tạo độ trễ 1000ms=1s P1=0xff;//"0xff"là giá trị viết trong hệ hex, cái này=11111111 delay(1000); } } }
Nguyên văn bởi pm.long Xem bài viếtko thấy nó nháy. thấy cả 8 đèn sáng hết ah
MÌnh cũng có 1 số tài liệu được coi là cơ bản về VDK 89c nếu ai muốn có thì pm email mình : trinhductrongtk@gamil.com
vì mình chưa up tài liêu lên = cách nào được
Nguyên văn bởi chaynhanhthe Xem bài viếtMọi người nói rõ thêm về ma trận led cho em và các thành viên mới tập đc hiểu rõ với. có hình cụ thể thì hay quá. thanks
http://www.dientuvietnam.net/forums/...mpleted-15613/VNATR Forum:
Nguyên văn bởi chaynhanhthe Xem bài viếtCần mua 1 mạch nạp 89c51. ai bán pm qua sdt 0973987355. em o hanoiVNATR Forum:
Hôm qua, 21:27 -
Hôm qua, 21:24 -
- Tôi cũng có vợ như thế....
Hôm qua, 21:04 -
17-02-2025, 06:08 -
17-02-2025, 01:38 -
17-02-2025, 01:26 -
