Led cube 5x5x5
    Nguyên văn bởi vuong321 Xem bài viết
    Bạn cho mình hỏi sao mình cáp phần lập trình c của bạn vô keil C thì nó báo lỗi
    bạn có thể xem đó là lỗi gì không?
    Build target 'Target 1'
    compiling codecube2.c...
    CODECUBE2.C(5): error C231: 'j': redefinition
    CODECUBE2.C(5): error C231: 'k': redefinition
    CODECUBE2.C(5): error C231: 'n': redefinition
    CODECUBE2.C(7): error C231: 'd1': redefinition
    CODECUBE2.C(8): error C231: 'd2': redefinition
    CODECUBE2.C(9): error C231: 'd3': redefinition
    CODECUBE2.C(10): error C231: 'd4': redefinition
    CODECUBE2.C(11): error C231: 'd5': redefinition
    CODECUBE2.C(12): error C231: 'd6': redefinition
    CODECUBE2.C(13): error C231: 'd7': redefinition
    CODECUBE2.C(14): error C231: 'd8': redefinition
    CODECUBE2.C(15): error C231: 'd9': redefinition
    CODECUBE2.C(16): error C231: 'd10': redefinition
    CODECUBE2.C(17): error C231: 'd11': redefinition
    CODECUBE2.C(18): error C231: 'd12': redefinition
    CODECUBE2.C(19): error C231: 'd13': redefinition
    CODECUBE2.C(20): error C231: 'd14': redefinition
    CODECUBE2.C(21): error C231: 'd15': redefinition
    CODECUBE2.C(22): error C231: 'd16': redefinition
    CODECUBE2.C(23): error C231: 'd17': redefinition
    CODECUBE2.C(24): error C231: 'd18': redefinition
    CODECUBE2.C(25): error C231: 'd19': redefinition
    CODECUBE2.C(26): error C231: 'd20': redefinition
    CODECUBE2.C(27): error C231: 'd21': redefinition
    CODECUBE2.C(28): error C231: 'd22': redefinition
    CODECUBE2.C(29): error C231: 'd23': redefinition
    CODECUBE2.C(30): error C231: 'd24': redefinition
    CODECUBE2.C(32): error C231: 'd25': redefinition
    CODECUBE2.C(33): error C231: 'c1': redefinition
    CODECUBE2.C(34): error C231: 'c2': redefinition
    CODECUBE2.C(35): error C231: 'c3': redefinition
    CODECUBE2.C(36): error C231: 'c4': redefinition
    CODECUBE2.C(37): error C231: 'c5': redefinition
    CODECUBE2.C(49): error C237: '_delay0': function already has a body
    CODECUBE2.C(866): error C237: 'main': function already has a body
    Bạn xem lại code đi,các biến j,k,n,d1,..,d25,c1,...,c5 bạn đã khai báo nhiều lần cho chúng (chỉ khai báo 1 lần),2 hàm ở 2 dòng dưới cùng cũng mắc lỗi tương tự
    vanduc0211@gmail.com
      Ban có thể cho mình xin mach in vẽ bằng orcad được ko ? List linh kiện cần cho mạch. Với vài bức ảnh chụp board của bạn đựoc ko ? Đựoc thì mình cảm ơn nhìu.^^!
        Cho mình hỏi có cách nào để mô phỏng mô hình cube 5x5x5 này ko.
        để tiện cho việc lập trình.mình mới bắt đầu vs 89c51 nên chưa chắc chắn lắm cần phải có mô hình để lập trình.ai cóa cách nào hay chỉ mình với.
          Nguyên văn bởi vanphu92 Xem bài viết
          mình cũng mới làm xong!
          bùn kái là code mình nó chạy ko đẹp và bi lỗi nên phải copy!
          mọi người xem y kiến!
          úi cái này chớp dc theo nhạc ak...
            Nguyên văn bởi uyhuynh91 Xem bài viết
            không bạn ah!
            muốn vậy phải làm thêm ah
              tành iêu mềnh tháng nữa sanh nhật......mình sẽ cố làm cái này tặng vậy....thanks các bác nhiều nhé...:">
                bạn ơi cho mk xin cái mạch nguyen lý hoan bản in luôn cũng đc cả code nua nha thanksss
                  Nguyên văn bởi tuanhue56 Xem bài viết
                  Bạn qua trang này xem nè : Led cube 5x5x5
                    Nguyên văn bởi gacon1990 Xem bài viết
                    Làm xong thành công post hết lên cho anh em làm tặng người thân yêu.tất cả gồm mạch in (mạch điều khiển và mạch led khuyến mại thêm mạch tích hợp cả hai) và code tất tần tật.à quên mình sử dụng altium 10 nhé.
                    [ATTACH]50117[/ATTACH]
                    [ATTACH]50128[/ATTACH]
                    con 89S52 dung lượng ROM là 8K sao bác nạp đc file .hex lớn hơn thế kia đc ak?e ko hiểu??????
                      hay lắm,có gì mới post lên mọi người cùng xen nha
                        Nguyên văn bởi vinhdtdl1993
                        em nap code vao mà sao khi ráp xong mach chạy thử thì nó nháy nhanh lắm. nhanh cực kì. mà led không dược sàng lắm là do đâu hả các anh. giúp em với...
                        cái này thì gặp nhiều
                        em kiểm tra lại 5 con tranito
                        kiểm tra lại từng đường dây
                        và quan trọng nhất là nạp code + code có đúng với phần cứng không
                        chúc thành công
                          Nguyên văn bởi phuphuongbk Xem bài viết
                          không bạn ah
                          dung lượng tôi nhớ không làm là 64k
                          • #28
                            [1]. Về 89C51:
                            ROM trên chíp: 4KB
                            RAM: 128 Byte
                            Bộ định thời: 2 (gồm timer 0, timer 1)
                            Chân vào/ra: 32
                            Cổng nối tiếp: 1
                            Nguồn ngắt: 6
                            [2]. Về 89C52:
                            ROM trên chíp: 8KB
                            RAM: 256 Byte
                            Bộ định thời: 3 (gồm timer 0, timer 1, timer 2)
                            Chân vào/ra: 32
                            Cổng nối tiếp: 1
                            Nguồn ngắt: 8
                            Cả 2 con trên đều sử dụng với điện áp chuẩn 5V. Nếu muốn tìm hiểu chi tiết hơn thì bạn phải tra datasheet của nó.. cai code cua ban 23k nap dc k
                            No __ Comment
                            • #29
                              [1]. Về 89C51:
                              ROM trên chíp: 4KB
                              RAM: 128 Byte
                              Chân vào/ra: 32
                              Cổng nối tiếp: 1
                              Nguồn ngắt: 6
                              [2]. Về 89C52:
                              ROM trên chíp: 8KB
                              RAM: 256 Byte
                              Chân vào/ra: 32
                              Cổng nối tiếp: 1
                              Nguồn ngắt: 8
                              Cả 2 con trên đều sử dụng với điện áp chuẩn 5V. Nếu muốn tìm hiểu chi tiết hơn thì bạn phải tra datasheet của nó. có 8k mak code của bạn 23k thì nạp sao
                              No __ Comment
                              • #30
                                í quên 89c52 với 89s52 bộ nhớ giống nhau nhé
                                No __ Comment
                                gacon1990 ^^ Tìm hiểu thêm về gacon1990
