Ngắt INT0
  • Ngắt INT0
    Không biết vì sao em chỉ dùng ngắt int0 chỉ được 1 lần.
    Code:
    SCL BIT P3.0
    SDA BIT P3.1
    DULIEU EQU 50H
    ADD_DATA EQU 54H
    GIO EQU 51H
    PHUT EQU 52H
    GIAY EQU 53H
    ORG 00H
    LJMP MAIN
    ORG 0013H
    CHINH_GIO:
    JNB P3.2,OUTH
    MOV A,GIO
    MOV DULIEU,GIO
    CALL HIENTHI_H
    CALL CHECK
    SJMP CHINH_GIO
    OUTH:
    MOV ADD_DATA,#02H
    CALL SEND_DATA
    JNB P3.2,$
    sjmp CHINH_PHUT
    CHECK:
    JB P1.0,CHECK2
    JNB P1.0,$
    INC GIO
    SJMP CHECK
    CHECK2:
    JB P1.1,EXIT
    JNB P1.1,$
    DEC GIO
    EXIT:
    RET
    CHINH_PHUT:
    JNB P3.2,OUTP
    MOV A,PHUT
    MOV DULIEU,PHUT
    CALL HIENTHI_P
    CALL CHECKP
    SJMP CHINH_PHUT
    OUTP:
    MOV ADD_DATA,#01H
    CALL SEND_DATA
    JNB P3.2,$
    sjmp CHINH_GIAY
    CHECKP:
    JB P1.0,CHECKP2
    JNB P1.0,$
    INC PHUT
    SJMP CHECKP
    CHECKP2:
    JB P1.1,EXIT
    JNB P1.1,$
    DEC PHUT
    RET
    CHINH_GIAY:
    JNB P3.2,OUTS
    MOV A,GIAY
    MOV DULIEU,GIAY
    CALL HIENTHI_S
    CALL CHECKS
    SJMP CHINH_GIAY
    OUTS:
    MOV ADD_DATA,#00H
    CALL SEND_DATA
    RETI
    CHECKS:
    JB P1.0,CHECKS2
    JNB P1.0,$
    INC GIAY
    SJMP CHECKS
    CHECKS2:
    JB P1.1,EXIT
    JNB P1.1,$
    DEC GIAY
    RET
    ORG 40H
    MAIN:
    MOV IE,#10000100b
    WAIT:
    CALL HIEN_NORMAL
    SJMP WAIT
    HIEN_NORMAL:
    CALL HIEN_S
    CALL HIEN_P
    CALL HIEN_H
    RET
    HIEN_S:
    MOV ADD_DATA,#00H
    CALL READ_DATA
    MOV GIAY,DULIEU
    CALL HIENTHI_S
    RET
    HIEN_P:
    MOV ADD_DATA,#01H
    CALL READ_DATA
    MOV PHUT,DULIEU
    CALL HIENTHI_P
    RET
    HIEN_H:
    MOV ADD_DATA,#02H
    CALL READ_DATA
    MOV GIO,DULIEU
    CALL HIENTHI_H
    RET
    SEND_DATA:
    CALL START
    MOV A,#0D0H
    CALL SEND
    SETB SCL
    CLR SCL
    MOV A,ADD_DATA
    CALL SEND
    SETB SCL
    CLR SCL
    MOV A,DULIEU
    CALL SEND
    SETB SCL
    CLR SCL
    CALL STOP
    RET
    READ_DATA:
    CALL START
    MOV A,#0D0H
    CALL SEND
    SETB SCL
    CLR SCL
    MOV A,ADD_DATA
    CALL SEND
    SETB SCL
    CLR SCL
    CALL STOP
    CALL START
    MOV A,#0D1H
    CALL SEND
    SETB SCL
    CLR SCL
    CALL RECIVE
    SETB SCL
    CLR SCL
    CALL STOP
    RET
    SEND:
    MOV R1,#8
    LOOP:
    RLC A
    MOV SDA,C
    SETB SCL
    CLR SCL
    DJNZ R1,LOOP
    RET
    RECIVE:
    MOV R1,#8
    CLR A
    LOOP1:
    MOV C,SDA
    SETB SCL
    CLR SCL
    RLC	A
    DJNZ R1,LOOP1
    MOV DULIEU,A
    RET
    START:
    SETB SDA
    SETB SCL
    NOP
    CLR SDA
    NOP
    CLR SCL
    RET
    STOP:
    CLR SCL
    CLR SDA
    NOP
    SETB SCL
    NOP
    SETB SDA
    RET
    HIENTHI_S:
    MOV P2,#00000000B
    SWAP A
    ANL A,#00001111B
    MOV 	DPTR,#MALED		;
    MOVC 	A,@A+DPTR
    MOV P0,A
    SETB P2.0
    CALL DELAY
    CLR P2.0
    MOV A,DULIEU
    ANL A,#00001111B
    MOV 	DPTR,#MALED		;
    MOVC 	A,@A+DPTR
    MOV P0,A
    SETB P2.1
    CALL DELAY
    CLR P2.1
    RET
    HIENTHI_P:
    MOV P2,#00000000B
    SWAP A
    ANL A,#00001111B
    MOV 	DPTR,#MALED		;
    MOVC 	A,@A+DPTR
    MOV P0,A
    SETB P2.2
    CALL DELAY
    CLR P2.2
    MOV A,DULIEU
    ANL A,#00001111B
    MOV 	DPTR,#MALED		;
    MOVC 	A,@A+DPTR
    MOV P0,A
    SETB P2.3
    CALL DELAY
    CLR P2.3
    RET
    HIENTHI_H:
    MOV P2,#00000000B
    SWAP A
    ANL A,#00001111B
    MOV 	DPTR,#MALED		;
    MOVC 	A,@A+DPTR
    MOV P0,A
    SETB P2.4
    CALL DELAY
    CLR P2.4
    MOV A,DULIEU
    ANL A,#00001111B
    MOV 	DPTR,#MALED		;
    MOVC 	A,@A+DPTR
    MOV P0,A
    SETB P2.5
    CALL DELAY
    CLR P2.5
    RET
    DELAY: MOV R1,#99
    DJNZ R1,$
    RET
    MALED:
    	DB 		40H,79H,24H,30H,19H,12H,02H,78H,00H,10H,21H,08H,11H,7FH,46H,48H
    END
    sau khi bạn ngắt ở bên ngoài thì khi đó cờ ngắt bên trong vđ khiển nó được bật lên bởi phần cứng, rồi vì vận bạn muốn ngắt tiếp thì bạn phải tắt cờ ngắt bằng phần mềm là code
    facebook:
      Nguyên văn bởi THSANG AUTO Xem bài viết
      ý của anh là lệnh RETI ah
        Nguyên văn bởi xamdor_bka Xem bài viết
        asm thì mình ko rõ.
        facebook:
          asm thì mình ko rõ.
          vâng,thank anh!
            hầu hết các nguyên nhân ngắt của 89 đều đc phần cứng tự động xóa về 0, chỉ có ngắt do port phát nối tiếp và ngắt do tràn timer2 thì phần cứng mới ko tự xóa cờ ngắt thôi.
            chương trình của bạn sai cấu trúc viết của asm nên ko chạy, bạn sử dụng lệnh ret hoàn toàn sai trong trình phục vụ ngắt, trình phục vụ ngắt quá dài vượt quá địa chỉ 0040h của main nên main sẽ đè lên gần hết trình phục vụ ngắt.
            Bạn cần xem lại cấu trúc viết 1 chương trình có sử dụng ngắt, sách 8051 của Tống Văn On có viết rất chi tiết ở trang 112 tới trang 115
              cảm ơn anh chung nhá!không trách j em không nhảy qua được phần CHINH_PHUT
              mà em dùng lệnh reti để trở về ngắt mà,chứ có dùng mỗi ret đâu
                trình phục vụ ngắt của bạn lồng quá nhiều chương trình con, nếu quản lý ko kĩ sẽ dẫn tới tràn Stack, khi tràn stack chương trình chính sẽ chạy 1 cách ngẫu hứng
                  thank anh!
                    trình phục vụ ngắt của bạn lồng quá nhiều chương trình con, nếu quản lý ko kĩ sẽ dẫn tới tràn stack, khi tràn stack chương trình chính sẽ chạy 1 cách ngẫu hứng
                    thank anh chung nha.em lam được rồi.kaka
                      Trong Phan Information Technology mục Học tập/project 8051 có vi dụ về ngắt INT1, các bạn tham khaoe xem.
                      0912666017
                      xamdor_bka Tìm hiểu thêm về xamdor_bka
