Đồng Hố số sủ dũng DS1307 cần giúp đỡ!
dây là code của tui
#include <REGX51.H>
sbit SDA = P1^1;
sbit SCL = P1^0;
#define PortData P2
#define PortScan P3
#define Set P1_2
#define Back P1_3
#define Next P1_4
#define W 0xD0
#define R 0xD1
#define HOUR 0x02
#define MIN 0x01
#define SEC 0x00
unsigned char code Led7Seg[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x9 0};
char Data,Hour,Min,Sec;
char IncSet=0,Scanled=0,run=0,t=0;
void delay(int t)
while(t--) ;
void Start()
SCL = 1;
SCL = 0;
SDA = 1;
SCL = 1;
delay(2);
SDA = 0;
delay(2);
SCL = 0;
delay(2);
void Stop()
SCL = 1;
SCL = 0;
SDA = 0;
delay(2);
SCL = 1;
delay(2);
SDA = 1;
void Write(unsigned char Data)
unsigned char i;
for (i=0;i<8;i++)
SDA = (Data & 0x80) ? 1:0;
SCL=1;SCL=0;
Data<<=1;
SCL = 1; delay(2);
SCL = 0;
unsigned char Read()
bit rd_bit;
unsigned char i ;
Data=0x00;
for(i=0;i<8;i++)
delay(2);
SCL = 1;
delay(2);
rd_bit = SDA;
Data = Data<<1;
Data = Data | rd_bit;
SCL = 0;
return Data;
unsigned char Read_DS1307(unsigned char DataTime)
unsigned char Bcd_Hex;
Start();
Write(W);
Write(DataTime);
Start();
Write(R);
Bcd_Hex=Read();
Stop();
Bcd_Hex = (((Bcd_Hex/16)*10)+ (Bcd_Hex & 0x0f));
return Bcd_Hex;
void interrupt_Time() interrupt 3 //ngat timer 1 chay dong ho
TR1=0;
TF1=0;
TH1=0x3c;
TL1=0xaf;
TR1=1;
void interrupt_San_Led7Seg()interrupt 1
TH0=0xfc;
TL0=0x18;
TR0=0;
TF0=0;
Scanled++ ;
if(Scanled==1)
PortData=0xff;
PortData =Led7Seg[Hour/10];
PortScan = 0x01;
if(Scanled==2)
PortData=0xff;
PortData =Led7Seg[Hour%10];
PortScan = 0x02;
if(Scanled==3)
PortData=0xff;
PortData = Led7Seg[Min/10];
PortScan = 0x04;
if(Scanled==4)
PortData=0xff;
PortData = Led7Seg[Min%10];
PortScan = 0x08;
if(Scanled==5)
PortData=0xff;
PortData = Led7Seg[Sec/10];
PortScan = 0x10;
if(Scanled==6)
PortData=0xff;
PortData = Led7Seg[Sec%10];
PortScan = 0x20;
Scanled=0;
TR0=1;
void Setup_Timer()
TMOD=0x11;
TH1=0x3C;
TL1=0xAF;
TR1=1;
ET1=1;
TH0=0XFC;
TL0=0X18;
TR0=1;
ET0=1;
EA=1;
void main()
Setup_Timer();
while(1)
if ((run==1)&&(IncSet==0))
run=0;
Hour=Read_DS1307(HOUR);
Min=Read_DS1307(MIN);
Sec=Read_DS1307(SEC);
}Last edited by sansuridan; 17-09-2012, 20:07.
vậy à cám ơn nhiều để tui nghiên cứu mạch thật xem sao
bạn đã làm rúi à nhấn nút luôn không thả củng khong sao à chắc 100% chứ huynhLast edited by sansuridan; 18-09-2012, 14:48.
bởi dinhthuong80"Các chuyên gia đưa ra lời giải thích
Theo các chuyên gia về quạt máy, về cơ bản số lượng cánh quạt không ảnh hưởng nhiều tới hiệu quả làm mát của thiết bị. Tuy nhiên vẫn có một số sự khác biệt nhỏ, đó là quạt nhiều cánh hơn (5 cánh) thường sẽ cho ra nhiều gió...-
hôm nay, 16:32 -
bởi appongthoMã lỗi H-27 và lỗi H-43 tủ lạnh Panasonic là gì?
https://appongtho.com/khac-phuc-loi-...anh-panasonic/
Mã lỗi H-27 và H-43 trên tủ lạnh Panasonic thường xuất hiện khi hệ thống điều khiển phát hiện sự cố nghiêm trọng liên quan đến cảm biến...-
hôm nay, 10:35 -
Trả lời cho Công thức tính công suất biến áp xung ?bởi NGULAUở tần số 50 Hz diện tich lõi sắt S (cm2) có B = 12.000 Gauss được tính bằng công thức S=1,2x căn bậc 2 của P (W)
Nếu có lõi sắt tốt có thể bỏ 1,2 đi
còn ở tần số cao hơn tôi không biết và xin anh em cho biết, đang rất cần-
Hôm qua, 23:00 -
11-04-2025, 15:07 -
10-04-2025, 17:07 -
Còn...-
09-04-2025, 22:10 -
08-04-2025, 20:54 -
Cộng với một bản số liệu...-
08-04-2025, 20:45 -
08-04-2025, 20:28 -
08-04-2025, 18:42 -
