bác nào chuyển hộ mình sang file hex nhé...cảm ơn nhiều
  • bác nào chuyển hộ mình sang file hex nhé...cảm ơn nhiều
    ; Ten chuong trinh : DK do sang den LED bang nut bam.
    ; Nguoi thuc hien : Kyle Ray
    ; Ngay thuc hien : 01/05/2012 - 20h18'
    ; Phien ban : 1.0
    ; Mo ta phan cung : Dung AT89C51 - thach anh 12MHz
    ; : LED noi voi P2
    ; : Nut 1 <=> p1.1
    ; : Nut 2 <=> p1.2
    ; : Nut ON/OFF <=> p1.0
    ; Yeu cau: An ON/OFF DC hoat dong.
    ; An 1 LED 2 sang.
    ; An 2 LED 3 sang.
    ; Hoan thanh : 01/05/2012 - 20h48'
    ; Kiem tra : ...
    ; Nguoi kiem tra : ...
    ; Chu thich : Bam xung o tan so 500Hz. Mac dinh
    ; ban dau xung muc cao (30%) t_on = 600us.
    ;Sau moi lan an UP hoac DOWN thi t_on tang hoac giam 50us.
    ; DINH NGHIA CAC KY HIEU ;
    LED1 data p2.0
    Led2 data p2.1
    Led3 data p2.2
    ON_OFF bit p1.0
    1 bit p1.1
    2 bit p1.2
    VAR equ 30h
    value equ -39
    org 0h
    main: ;bat dau chuong trinh
    mov p2.0, #0h ;tat LED
    mov r1, #28
    mov VAR, #12 ;nap gia tri t_on ban dau = 6ms
    acall kt_on ;goi ct cho phim ON/OFF duoc an
    t_on:
    mov LED, #0ffh
    jb UP, next ;ko an UP => nhay den next
    acall delay_100ms ;goi ct tao tre 100ms de chong rung phim
    jnb UP, $ ;cho nha phim
    inc VAR ;tang bien dem
    mov r0, VAR
    cjne r0, #40, next ;VAR<20 => nhay den next
    mov VAR, #39 ;giu khong cho VAR vuot qua 20
    acall delay_50us
    next: jb ON_OFF, next_1 ;ko an ON_OFF => nhay den next_1
    acall delay_100ms
    jnb ON_OFF, $
    sjmp main
    next_1:
    acall delay_50us
    djnz VAR, next
    t_off:
    mov LED, #0h
    clr c ;xoa co nho
    mov a, #40
    subb a, VAR ;thoi gian t_off duoc luu vao acc
    jnc next_2 ;nhay den next_2 neu khong nho (c=0)
    cpl a ;lay bu 1 acc
    inc a ;tang acc len 1 de tao bu 2
    next_2:
    jb DOWN, next_3 ;nhay den next_3 neu DOWN ko dc an
    acall delay_100ms
    jnb DOWN, $
    dec VAR ;giam VAR di 1 dv de T = const = 20ms
    inc a
    mov r1, a
    mov r0, VAR
    cjne r0, #0, next_3
    inc VAR ;giu cho VAR ko bi am
    next_3:
    jb ON_OFF, next_4
    acall delay_100ms
    jnb ON_OFF, $
    sjmp main
    next_4:
    acall delay_50us
    djnz r1, next_3
    sjmp t_on
    ; CHUONG TRINH CON ;
    kt_on:
    jb ON_OFF, $ ;cho den khi ON_OFF dc bam
    acall delay_100ms
    jnb ON_OFF, $
    ret
    delay_50us:
    mov tmod, #01h ;chon timer 0, che do 16 bits
    mov th0, #high value
    mov tl0, #low value
    setb tr0
    jnb tf0, $ ;cho o day den khi tran
    clr tr0
    clr tf0
    ret
    delay_100ms:
    push 5
    push 6
    push 7
    mov r7, #100
    mov r6, #2
    mov r5, #248
    djnz r5, $
    djnz r6, $-4
    djnz r7, $-8
    pop 7
    pop 6
    pop 5
    ret
    end
    Chương trình này hình như mình viết thì phải nhưng nó chưa tối ưu lắm
    Nếu bạn cần thì liên lạc vào mail: ck33spkt@gmail.com, mình sẽ gửi cho bạn cả code và file mô phỏng của bản mình đã sửa!
    Thân!
    tuonghp88 Tìm hiểu thêm về tuonghp88
