mp3 reader using... VDK
  • mp3 reader using... VDK
    co vụ này cũng hay,làm 1 cái mp3 dùng vxl chơi,nghiệt 1 cái là ko biết cấu trúc mp3 như thế nào,vậy mong các bạn đóng góp
    Dừng nói với tôi là mua về nghe sướng hơn,vì tôi đã biết nhưng vẫn muốn làm
    ban xem cai nay co giup gì cho ban khong ?
    Inside the MP3 Codec - Page 11
    featured with permission from MP3: The Definitive Guide by Scot Hacker
    The Anatomy of an MP3 File
    Aside from being familiar with the basic options available to the MP3 encoder, the typical user doesn't need to know how MP3 files are structured internally any more than she needs to know how JPEG images or Word documents are structured behind the scenes. For the morbidly curious, however, here's an x-ray view of the MP3 file format.
    Inside the Header Frame
    As mentioned earlier, MP3 files are segmented into zillions of frames, each containing a fraction of a second's worth of audio data, ready to be reconstructed by the decoder. Inserted at the beginning of every data frame is a "header frame," which stores 32 bits of meta-data related to the coming data frame (Figure 2-4). As illustrated in Figure 2-5,[13] the MP3 header begins with a " sync" block, consisting of 11 bits. The sync block allows players to search for and "lock onto" the first available occurrence of a valid frame, which is useful in MP3 broadcasting, for moving around quickly from one part of a track to another, and for skipping ID3 or other data that may be living at the start of the file. However, note that it's not enough for a player to simply find the sync block in any binary file and assume that it's a valid MP3 file, since the same pattern of 11 bits could theoretically be found in any random binary file. Thus, it's also necessary for the decoder to check for the validity of other header data as well, or for multiple valid frames in a row. Table 2-1 lists the total 32 bits of header data that are spread over 13 header positions.
    Locking onto the Data Stream
    One of the original design goals of MP3 was that it would be suitable for broadcasting. As a result, it becomes important that MP3 receivers be able to lock onto the signal at any point in the stream. This is one of the big reasons why a header frame is placed prior to each data frame, so that a receiver tuning in at any point in the broadcast can search for sync data and start playing almost immediately. Interestingly, this fact theoretically makes it possible to cut MPEG files into smaller pieces and play the pieces individually. However, this unfortunately is not possible with Layer III files (MP3) due to the fact that frames often depend on data contained in other frames (see "Dipping into the reservoir," earlier). Thus, you can't just open any old MP3 file in your favorite audio editor for editing or tweaking.
    Figure 2-4: Data describing the structural factors of that frame; this data is called the frame's "header"
    Figure 2-5: The MP3 frame header represented visually
    Table 2-1: The Thirteen Header Files' Characteristics
    Position Purpose Length (in Bits)
    A Frame sync 11
    B MPEG audio version (MPEG-1, 2, etc.) 2
    C MPEG layer (Layer I, II, III, etc.) 2
    D Protection (if on, then checksum follows header) 1
    E Bitrate index (lookup table used to specify bitrate for this MPEG version and layer) 4
    F Sampling rate frequency (44.1kHz, etc., determined by lookup table) 2
    G Padding bit (on or off, compensates for unfilled frames) 1
    H Private bit (on or off, allows for application-specific triggers) 1
    I Channel mode (stereo, joint stereo, dual channel, single channel) 2
    J Mode extension (used only with joint stereo, to conjoin channel data) 2
    K Copyright (on or off) 1
    L Original (off if copy of original, on if original) 1
    M Emphasis (respects emphasis bit in the original recording; now largely obsolete) 2
    32 total header bits Following the sync block comes an ID bit, which specifies whether the frame has been encoded in MPEG-1 or MPEG-2. Two layer bits follow, determining whether the frame is Layer I, II, III, or not defined. If the protection bit is not set, a 16-bit checksum will be inserted prior to the beginning of the audio data.
    The bitrate field, naturally, specifies the bitrate of the current frame (e.g., 128 kbps), which is followed by a specifier for the audio frequency (from 16,000Hz to 44,100Hz, depending on whether MPEG-1 or MPEG-2 is currently in use). The padding bit is used to make sure that each frame satisfies the bitrate requirements exactly. For example, a 128 kbps Layer II bitstream at 44.1kHz may end up with some frames of 417 bytes and some of 418. The 417-byte frames will have the padding bit set to "on" (1) to compensate for the discrepancy.
    The mode field refers to the stereo/mono status of the frame, and allows for the setting of stereo, joint stereo, dual channel, and mono encoding options. If joint stereo effects have been enabled, the mode extension field tells the decoder exactly how to handle it, i.e, whether high frequencies have been combined across channels.
    The copyright bit does not hold copyright information per se (obviously, since it's only one bit long), but rather mimics a similar copyright bit used on CDs and DATs. If this bit is set, it's officially illegal to copy the track (some ripping programs will report this information back to you if the copyright bit is found to be set). If the data is found on its original media, the home bit will be set. The " private" bit can be used by specific applications to trigger custom events.
    The emphasis field is used as a flag, in case a corresponding emphasis bit was set in the original recording. Th emphasis bit is rarely used anymore, though some recordings do still use it.
    Finally, the decoder moves on through the checksum (if it exists) and on to the actual audio data frame, and the process begins all over again, with thousands of frames per audio file.
    NOTE
    For more details on the structure of MP3 header frames, including the actual lookup tables necessary to derive certain details from the bit settings previously listed, see the Programmer's Corner section at www.mp3-tech.org/. If you want to go straight to the horse's mouth, start at www.iso.ch.
      ôi cái này dành cho dân IT đọc chơi cho biết,còn để làm mạch thì chịu thôi
        Ha ha ! cái con giai ma mp3 không có bán ở Việt Nam . Lúc trước lên mạng thì nó dùng CPLD hay FBGA làm con giãi mã gì đó quên rồi . Còn uốn đọc file trước tiên phải hiểu cấu trúc bảng FAT cái đã .
        Mạch nạp Little Programmer
        MSC-51,AVR,EEPROM ... etc
        Site Fukusei shop :
          Để làm MP3 cấn có DAC tốc độ cao, 24 bit càng tốt, giao tiếp với thẻ nhớ hay HDD theo chuẩn FAT, ...Nhiều thứ lắm.Anh xem hình.
          CallerID, Cảnh báo BTS, ...
          0988006696
          linhnc308@gmail.com
          http://linhnc308.blogspot.com
            OÁI CHÓNG MẶT QUÁ
            mình chỉ cần biết làm cách nào để nạp 1 file mp3 vào rom rồi dùng vdk để đọc thôi mà
              Nguyên văn bởi voduychau
              OÁI CHÓNG MẶT QUÁ
              Nếu làm như vậy thì cũng không cần đến VDK, chúng ta đem file mp3 hay wav gì ấy mà nạp vào ROM.
              ROM kết nối DAC và ngõ ra đưa đến bộ âm tần-->nghe được bản nhạc!
              Thử lắp một cái gắn vào xe máy cho nó "kêu chơi"!
                Trên mạng có bán con giã mã mp3 và tích hợp AD luôn nó tên là VS1001k : và google nhận chuổi VS1001K và bạn sẽ tải được datasheet con này .
                Site Fukusei shop :
                  liệu có được không?vì con ROM chỉ nạp file hex thoi mà
                  mình cũng vừa có sáng kiến khác đây,nạp file midi cho nó nhỏ gọn,lại ko sợ vi phạm bản quyền.hình như định dạng midi là đúng nghĩa trường phái ktsố thì phải(?!?!)
                  nhắn Mod Duyphi:bạn del bài hơi nhiều đó,đừng lạm dụng
                    Ha ha ! bạn muốn nạp file nào vao con eprom thì tùy bạn chứ ! tại cái chương trình nạp bạn tự chuyên ra file nạp vào con epom mà . Mà nếu con eprom muốn phát nhạc thì phải tuân theo chuẩn PCM à nha .
                    Site Fukusei shop :
                      Để trong sạch BOX 8051, những bài viết của bạn trước đây không nên xuất hiện- một phần bạn đã thiếu tôn trọng đối với tôi-chắc bạn còn nhớ bạn đã nói gì phải không!? Tôi không chấp, vì với công việc của tôi hiện giời thì việc lên diễn đàn là giải trí và giúp đở anh em mà thôi. Do đó các bài viết mang tính thiếu tôn trọng điển hình như của bạn đối với tôi hay với ai khác trước đây chắc chắn chỉ có bạn là người đầu tiên đọc nó và tôi là người cuối cùng biết đến nó mà thôi
                      Chúc bạn luôn vui vẻ, và hãy cố gắng lên mạng nhiều hơn mỗi ngày 1h để có thể mở rộng lòng mình hơn nhé voduychau!
                        liệu có được không?vì con ROM chỉ nạp file hex thoi mà.....................
                        Trở lại vấn đề nạp file nhạc của bạn voduychau!
                        Không nên hiểu là phải cứng nhắc lấy file HEX để nạp cho ROM, vấn đề là phần mềm hõ trợ nó đọc được file đó hay không mà thôi! Chẳng hạn có nhiều phần mềm nạp chương trình chỉ chấp nhận file .BIN chứ không hõ trợ file.HEX và ngược lại.
                        Nếu bạn muốn đưa file nhạc nạp cho ROM thì bạn cứ đem file.wav vì thường thì các bộ nạp file nhạc cho ROM nó hỗ trợ đọc file wav. Còn nếu bạn có file HEX thì nạp trực tiếp bản nhạc đó cho ROM luôn.
                          Tôi copy được cái này của thằng bạn.
                          MP3 player , MMC giao tiếp .
                          Sử dụng PIC18LF452 hoặc PIC18F452 , 18F458 đều chạy , LCD dùng loại I2C Graphic ( nokia 3310 ) > Bạn nên tạo boot loader cho PIC để nạp cho thuận tiện.
                          Tôi có gửi kèm file hex cho PIC18F452 và sơ đồ trong các file zip.
                          Tất cả chỉ có vậy , các bạn có học được chi thì học ( đồ này không phải của tôi ). Đưa lên để các bạn lấy phương hướng thôi.
                            Tôi đoán cái này thằng bạn nó không thể làm nổi cũng lọ mọ ở đâu đấy nhưng thôi "ăn cướp " được có vậy là may rồi
                              ai biết tài liệu vi điều khiển xin hãy chỉ giáo.xin trân thành cám ơn
                              :cafe:
                              voduychau Tìm hiểu thêm về voduychau
