a gửi cả file lên cho e dk không
[Share-code] Mỗi ngày một bài tập về AT89S52
Nguyên văn bởi hoanganh234 Xem bài viếta gửi cả file lên cho e dk không
Code:#include <REGX51.H> unsigned char preloadTH=0xFF,preloadTL=0xFF; unsigned int pointer=0,ii=0,jj; sbit out=P2^0; //octa: 0 //key : C C# D D# E F F# G G# A A# B code float key_octa0[]={16.35,17.32,18.35,19.45,20.6,21.83,23.12,24.5,25.96,27.5,29.14,30.87}; code unsigned int chuan=1000; code float crystal=11.0592; //music code unsigned char music[]= { "4d~,4d~,3g~,3a~,4d.,4d~,4g~,4a~,4b~,4a=,4g=,4d.,4 e~,3a~,4c~,3g~,3a~,4d~,4d ,4d=,4c=,3a~,4c~,3g~,3a~,4do" "4g~,4g~,4d~,3a~,4g.,4g~,4a~,4g~,4b=,4a=,4g~,4d.,4 g~,4e ,4e~,4d~,4c ,4d~,4d~,3a~,4d~,3b~,3a~,3go,4d ,4go" "4go,4a ,4b~,4a~,4F~,4g.,4d~,4g~,4a~,4a=,4b=,4a~,4g.,4d~,3 a ,3a ,3a~,4d ,4d~,4d ,3a=,3b=,3a~,3g.,4b=,4a=" "4g~,4d~,4g~,4d~,3a.,4g~,4g ,4F~,4a~,5d.,4a=,4b=,4d ,3a ,4go,4d~,4d~,3g~,3a~,4do,4g~,4g~,4d~,3a~,4go,4g~" "4d~,4g~,4a~,4A ,4a~,5d~,4b~,4a~,4g~,4F~,4g ,4d ,4d ,4g~,4a~,4A ,4a~,5d~,4b~,4a~,4g~,4F~,4go,s" }; void doitanso(float tanso) { unsigned int giatrinap; giatrinap=65536-(unsigned int)((1000000*crystal)/(24*tanso)); preloadTL=(unsigned char)giatrinap; preloadTH=(unsigned char)(giatrinap>>8); } void key(unsigned char octa,unsigned char k) { float tanso; switch (k) { case 'c' : tanso=key_octa0[0]; break; case 'C' : tanso=key_octa0[1]; break; case 'd' : tanso=key_octa0[2]; break; case 'D' : tanso=key_octa0[3]; break; case 'e' : tanso=key_octa0[4]; break; case 'f' : tanso=key_octa0[5]; break; case 'F' : tanso=key_octa0[6]; break; case 'g' : tanso=key_octa0[7]; break; case 'G' : tanso=key_octa0[8]; break; case 'a' : tanso=key_octa0[9]; break; case 'A' : tanso=key_octa0[10]; break; case 'b' : tanso=key_octa0[11]; break; } switch (octa) { case '1' : tanso*=2; break; case '2' : tanso*=4; break; case '3' : tanso*=8; break; case '4' : tanso*=16; break; case '5' : tanso*=32; break; case '6' : tanso*=64; break; case '7' : tanso*=128; break; case '8' : tanso*=256; break; } doitanso(tanso); } unsigned int trave(unsigned int ms) { unsigned int a; a=preloadTH; a=a<<8|preloadTL; return (ms*crystal*1000)/12/(65536-a); } unsigned int tempo(unsigned char tem) { switch (tem) { case '=' : return trave(chuan); break; case '~' : return trave(chuan*2); break; case ' ' : return trave(chuan*4); break; case '.' : return trave(chuan*6); break; case 'o' : return trave(chuan*8); break; } } void ngattimer_0(void) interrupt 1 { out=~out; TL0=preloadTL; TH0=preloadTH; if(ii==0) { if(music[pointer]=='s') TR0=0; key(music[pointer],music[pointer+1]); jj=tempo(music[pointer+2]); } ii++; if(ii==jj) { ii=0; pointer+=4; } } void main(void) { P0=P1=P2=P3=0; /*TMOD=17; TL0=0xff; TH0=0xff; ET0=1; EA=1; TR0=1;*/ EA=0; TMOD=0x02;// 8 BIT AUTO RELOAD TL0=0xff; TH0=0xff; ET0=1; EA=1; TR0=1; while(1); }
gmail :
Nguyên văn bởi bienhou Xem bài viếtmình có cái này này. k nhớ tác giả nhé
Nguyên văn bởi hoanganh234 Xem bài viếta có hướng dẫn tạo tần số bài hát cho e vớiNguyễn Huy Biên - 01649 802 694
gmail :
Nguyên văn bởi bienhou Xem bài viếtbạn chịu khó serach có 1 topic trong luồng này bàn về vấn đề này rồi nhé
rất cám ơn bạn đã up những bài hay thế này. Đối với mình, những bài như thế này giúp mình có thể hiểu và áp dụng ngày càng nhuần nhuyễn hơn từ kiến thức của C++ vào việc lập trình cho vi điều khiển. Từ đó phát triển thêm các dạng bài tập mà bạn đưa.
Ngoài ra, bạn có thể gửi mình 1 số tài liệu giáo trình về lập trình C cho 8051 được không ? Mail mình là malphite1993@yahoo.com
Cám ơn nhiều!!!
hay quá đúng cái em đang cần
PK ! $çéü Ä [Content_Types].xml ó (á ┤öMOâ@ å∩&■▓W █z0╞ö÷á⌡¿M¼±╝.C┘╚~dg√⌡∩ JK¬íÑZ╜É└2∩√╠
3â╤Jù╤ <*kR╓Oz, #mª╠,e»╙╟°ûE ä╔Di
ñl
╚F├╦ï┴tφ #¬6ÿ▓" w╟9╩ ┤└─:0tÆ[»Eá[?πN╚ 1 ~▌δ▌piM ΓPi░ßα r1/C4^╤πÜ─Cë,║»_¼╝R&£+ò üHTổng thống + điện = Ăn mày + điện = die => Tổng thống = ăn mày
ặc lỗi font rồi .viết tay vậy .
Đề: chân ngắt của vi điều khiển dc nối với 1 nút nhấn .mỗi khi nhấn tạo ra sự thay đổi trạng thái của vdk .(từ mức cao xuống mức thấp)
chân p2.0 dc nối vs 1 con led đơn
Yêu cầu :
khi nhấn nút (sử dụng ngắt int0) thì đèn sẽ sáng nhấp nháy 3 lần với chu kì là (1s sáng 1s tối)Tổng thống + điện = Ăn mày + điện = die => Tổng thống = ăn mày
Nguyên văn bởi hoangthuanhd Xem bài viếtặc lỗi font rồi .viết tay vậy .
Yêu cầu :
Nguyên văn bởi malphite1993 Xem bài viếtcho mình hỏi lệnh sbit trong c ý nghĩa và mục đích là gì vậy? vì hồi đó giờ toàn dùng define hoặc dùng trực tiếp port luôn nên thấy cái sbit lạ lắm
Code:sbit P0_1 P0^2 //thường trong header của keilc dùng dạng này
Code:sbit P0_1 0x81 //địa chỉ cụ thể của bit trong special function registers
cho mình hỏi chút xíu về cái 89s52 này, mình nạp qua isp nhưng khi ko cắm led + trở vào chân p0.1 thì ok. còn khi mà đề led + trở nối p0.1 là báo lỗi chip k nạp được. Mình dùng progisp.
ai biết về vụ này cho mình lời khuyên vs.
Chân reset mình nối 1 con 104 xuống đất luôn có ok không ?, vì nạp thấy nó vẫn chạy đều mà xem trên net thì thấy còn cần trở 10k nữa
Làm thế, hiệu suất mới cao.
Cánh quạt...-
hôm nay, 01:47 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi vi van phamCảm ơn đệ đã gởi cho huynh đoạn cổ C đó.
Đệ có hiểu cho huynh, cuộc sống của huynh tình bằng ngày, thấy mấy trang mạng quãng cáo phục
hồi accu bằng chiêu trò lừa bịp, huỳnh áy náy lắm, lừa bịp mọi người đến thế là...-
Hôm qua, 22:54 -
Trả lời cho Tại sao bình accu cạn nước thì hư,cách sửa chữa?bởi vi van phamTôi nghĩ hưu đã lâu. không còn Sàn xuất các điện cực.
Gần 50 năm ko s/c bình accu nước nhưng thấy mạng đầy nhóc các phương pháp phục hồi accu vớ vẩn như vắt nước chanh vào accu thật phản khoa học.
Tôi từng sx các...-
Channel: Nguồn!
Hôm qua, 21:30 -
Hôm qua, 20:10 -
Nhấn nút lần 3, LED...-
Hôm qua, 19:00 -
Channel: Nguồn!
Hôm qua, 17:03 -
Hôm qua, 11:37 -
2. Đo công suất: (+/-0.2W)
Hôm qua, 09:31 -
bởi Hóa chất HHNGalvex 18.01 - Giải pháp tẩy rửa tối ưu trong ngành điện tử công nghiệp
Giới thiệu về Galvex 18.01
Trong ngành điện tử công nghiệp, việc duy trì độ sạch của linh kiện là yếu tố quan trọng giúp đảm bảo hiệu suất và độ bền của sản...-
Hôm qua, 09:26 -
