tôi muốn sủa lại code này để thay cai lcd bang led 7 đoạn ạ. có anh em nào ghé ngang giúp với. vìkhong o rành cai vụ này lắm ạ
![Click image for larger version
Name: New Bitmap Image.PNG
Code:
;D4 - P1.0 ;D5 - P1.1 ;D6 - P1.2 ;D7 - P1.3 ;EN - P1.7 ;RW - P1.6 ;RS - P1.5 lcd_port equ P1 ;LCD connected to Port3 en equ P1.7 ;Enable connected to P1.7 var1 equ r2 temp equ r3 temp1 equ r4 delay equ r5 tick equ r6 Freq equ r7 ;4Byte hex 2 Dec conv variables XX0 equ 30H XX1 equ 31H XX2 equ 32H XX3 equ 33H YY0 equ 34H YY1 equ 35H YY2 equ 36H YY3 equ 37H YY4 equ 38H ZZ0 equ 39H ZZ1 equ 3AH ZZ2 equ 3BH ZZ3 equ 3CH ZZ4 equ 3DH BITS equ 3EH UpdateLCD equ 0H org 0H sjmp main org 0BH ;TMR0 ISR ajmp TMR0_ISR org 1BH ;TMR1 ISR ajmp TMR1_ISR main: mov SP,#50H mov tick, #20 mov tmod, #51H mov Freq, #00 setb ET0 setb ET1 setb EA clr UpdateLCD acall lcd_init mov a,#'F' acall lcd_dat mov a,#'r' acall lcd_dat mov a,#'e' acall lcd_dat mov a,#'q' acall lcd_dat mov a,#':' acall lcd_dat mov a,#' ' acall lcd_dat again: mov a,#86H acall lcd_cmd mov TH0, #3CH mov TL0, #0BAH mov tick, #20 mov Freq, #0 mov TH1, #0 mov TL1, #0 setb TR0 setb TR1 jnb UpdateLCD,$ clr UpdateLCD mov XX2,Freq mov XX1,TH1 mov XX0,TL1 acall X2D mov a,ZZ3 acall disp_num mov a,ZZ2 acall disp_num mov a,ZZ1 acall disp_num mov a,ZZ0 acall disp_num mov a,#'H' acall lcd_dat mov a,#'z' acall lcd_dat sjmp again TMR0_ISR: djnz tick, TMR0_ISR_GO clr TR1 clr TF1 clr TR0 clr TF0 setb UpdateLCD reti TMR0_ISR_GO: mov TH0, #3CH mov TL0, #0BAH reti TMR1_ISR: inc Freq reti disp_num: mov DPTR,#hex_table mov temp1,a anl a,#0F0H swap a movc a,@a+DPTR acall lcd_dat mov a,temp1 anl a,#0FH movc a,@a+dptr acall lcd_dat ret lcd_reset: ;LCD reset sequence mov lcd_port, #0FFH mov delay,#20 ;20mS delay acall delayms mov lcd_port, #83H ;Data = 30H, EN = 1, First Init mov lcd_port, #03H ;Data = 30H, EN = 0 mov delay,#15 ;Delay 15mS acall delayms mov lcd_port, #83H ;Second Init, Data = 30H, EN = 1 mov lcd_port, #03H ;Data = 30H, EN = 0 mov delay,#5 ;Delay 5mS acall delayms mov lcd_port, #83H ;Third Init mov lcd_port, #03H mov delay,#5 ;Delay 5mS acall delayms mov lcd_port, #82H ;Select Data width (20H for 4bit) mov lcd_port, #02H ;Data = 20H, EN = 0 mov delay,#5 ;Delay 5mS acall delayms ret lcd_init: acall lcd_reset ;Call LCD Reset sequence mov a,#28H ;4-bit, 2 line, 5x7 dots acall lcd_cmd ;Call LCD command mov a,#0CH ;Display ON cursor OFF acall lcd_cmd ;Call LCD command mov a,#06H ;Set entry mode (Auto increment) acall lcd_cmd ;Call LCD command mov a,#80H ;Bring cursor to line 1 acall lcd_cmd ;Call LCD command ret lcd_wait: mov a,#0CFH mov temp,00H mov lcd_port, a mov temp, lcd_port clr en setb en mov lcd_port, a clr en mov a,temp jb acc.3, lcd_wait ret lcd_cmd: ;LCD command Routine mov temp,a ;Save a copy of command to temp swap a ;Swap to use higher nibble anl a,#0FH ;Mask the first four bits add a,#80H ;Enable = 1, RS = 0, RW = 0 mov lcd_port,a ;Move it to lcd port anl a,#0FH ;Enable = 0, RS = 0, RW = 0 mov lcd_port,a ;Move to lcd port mov a,temp ;Reload the command from temp anl a,#0FH ;Mask first four bits add a,#80H ;Enable = 1 mov lcd_port,a ;Move to port anl a,#0FH ;Enable = 0 mov lcd_port,a ;Move to lcd port acall lcd_wait ret lcd_dat: ;LCD data Routine mov temp,a ;Keep copy of data in temp swap a ;We need higher nibble anl a,#0FH ;Mask first four bits add a,#0A0H ;Enable = 1, RS = 1, RW = 0 mov lcd_port,a ;Move to lcd port nop clr en ;Enable = 0 mov a,temp ;Reload the data from temp anl a,#0FH ;we need lower nibble now add a,#0A0H ;Enable = 1, RS = 1, RW = 0 mov lcd_port,a ;Move to lcd port nop clr en ;Enable = 0 acall lcd_wait ret delayms: mov var1,#230 d: nop nop djnz var1,d djnz delay,delayms ret X2D: CALL CLEARYZ ;;Clear All YY and ZZ bytes MOV YY0,#1 ;;DECIMAL ADDER = 1 ; ;; MOV R0,#XX3 ;;LOCATE HOW MANY BYTES WITH DATA MOV B,#4 ;;POSSIBLE 8 BYTES W/DATA ON XX BITS1: MOV A,@R0 ;;GET BYTE FROM INPUT REGISTER CJNE A,#0,BITS2 ;;JUMP IF FOUND THE FIRST NON ZERO DEC R0 ;;GO TO LOWER BYTE DJNZ B,BITS1 ;;ONE BYTE DONE, GO AGAIN ;; BITS2: MOV A,#8 ;;8 BITS PER BYTE, B CONTAINS BYTE # MUL AB ;;A = QUANTITY OF BITS W/DATA MOV BITS,A ;;SAVE CJNE A,#0,X2DMAIN2 ;;B = NUMBER OF DIGITS W/DATA RET ;;RETURN IF ONLY ZEROS AT XX ;; X2DMAIN1: CALL X2DSHIFTD ;;SHIFT DECIMAL RESULT X2DMAIN2: CALL X2DSHIFTH ;;SHIFT HEXA JNC X2DMAIN3 ;;IF NOT CARRY, JUST SKIP IT CALL X2DADD ;;ADD NEW RESULT X2DMAIN3: DJNZ BITS,X2DMAIN1 ;;ONE BIT DONE, GO AGAIN RET ;;GENERAL EXIT FROM THIS ROUTINE ;;ZZ0 - ZZ7 CONTAINS DECIMAL RESULT ;; X2DSHIFTD: MOV R0,#YY0 ;;YY * 2 (DECIMAL) MOV B,#4 ;;NUMBER OF BYTES CLR C ;;NEED CARRY ZERO X2DSHIFTD1: MOV A,@R0 ;;IGNORE LAST CARRY ADDC A,@R0 ;;ADD BYTE TO ITSELF DA A ;;DECIMAL ADJUST MOV @R0,A ;;PUT IT BACK INC R0 ;;GO TO UPPER BYTE DJNZ B,X2DSHIFTD1 ;;DO IT 8 BYTES RET ;;RETURN ;; X2DSHIFTH: MOV R0,#XX3 ;;SHIFT XX7 --> XX0 RIGHT 1 BIT MOV B,#4 ;;NUMBER OF BYTES SHIFTR0B: CLR C ;;NEED CARRY ZERO SHIFTR0B1: MOV A,@R0 ;;GET BYTE RRC A ;;ROTATE RIGHT THROUGH CARRY BIT MOV @R0,A ;;SAVE IT BACK DEC R0 ;;GO TO LOWER BYTE DJNZ B,SHIFTR0B1 ;;DO IT AGAIN "B" TIMES RET ;;RETURN ;; X2DADD: MOV R0,#ZZ0 ;; GET RESULT ZZ 8 BYTES REGISTER MOV B,#4 ;; 8 BYTES MOV R1,#YY0 ;; GET YY OPERATOR CLR C ;; NEED CARRY OFF X2DADD1: MOV A,@R0 ;; ZZ = ZZ + YY (8BYTES) W/DAA ADDC A,@R1 ;; ADD BYTE TO BYTE 8 TIMES DA A ;; DECIMAL ADJUST MOV @R0,A ;; PUT IT BACK INC R0 ;; BUMP POINTER NEXT BYTE INC R1 ;; BUMP POINTER NEXT BYTE DJNZ B,X2DADD1 ;; ONE BYTE DONE, GO AGAIN MOV A,ZZ3 ;; LAST CARRY TO 9TH BYTE OF ZZ ADDC A,#0 ;; JUST CARRY TO ZZ8 MOV ZZ3,A ;; RET ;; RETURN CLEARYZ: mov r1,#9 clr A mov r0,#YY0 CLEARYZ_1: mov @r0,A inc r0 djnz r1, CLEARYZ_1 ret hex_table: db '0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F' end
