Giúp đở về con AT89C2051
  • Giúp đở về con AT89C2051
    Em đang làm tiểu luận về con này, em tìm đọc trong datasheet của nó , có đoạn sau em không biết dịch kỉu gì cho đúng, em ko hỉu nó ra làm sao nữa. Mong các pro giúp em 1 tay .
    Đây là đoạn em ko dịch dc :
    The AT89C2051 is a low-voltage, high-performance CMOS 8-bit microcomputer with 2K bytes of Flash programmable and erasable read-only memory (PEROM). The device is manufactured using Atmel’s high-density nonvolatile memory technology and is compatible with the industry-standard MCS-51 instruction set. By combining a versatile 8-bit CPU with Flash on a monolithic chip, the Atmel AT89C2051 is a power-
    ful microcomputer which provides a highly-flexible and cost-effective solution to many embedded control applications.
    The AT89C2051 provides the following standard features: 2K bytes of Flash, 128
    bytes of RAM, 15 I/O lines, two 16-bit timer/counters, a five vector two-level interrupt
    architecture, a full duplex serial port, a precision analog comparator, on-chip oscillator
    and clock circuitry. In addition, the AT89C2051 is designed with static logic for opera-
    tion down to zero frequency and supports two software selectable power saving
    modes. The Idle Mode stops the CPU while allowing the RAM, timer/counters, serial
    port and interrupt system to continue functioning. The power-down mode saves the
    RAM contents but freezes the oscillator disabling all other chip functions until the next
    hardware reset.
    và đoạn này :
    The Port 1 is an 8-bit bi-directional I/O port. Port pins P1.2 to P1.7 provide internal pull-ups. P1.0 and P1.1 require external pull-ups. P1.0 and P1.1 also serve as the positive input (AIN0) and the negative input (AIN1), respectively, of the on-chip precision analog comparator. The Port 1 output buffers can sink 20 mA and can drive LED displays directly. When 1s are written to Port 1 pins, they can be used as inputs. When pins P1.2 to P1.7 are used as inputs and are externally pulled low, they will source current (IIL) because of the internal pull-ups.
    Port 1 also receives code data during Flash programming and verification.
    Port 3 pins P3.0 to P3.5, P3.7 are seven bi-directional I/O pins with internal pull-ups. P3.6 is hard-wired as an input to the output of the on-chip comparator and is not accessible as a general-purpose I/O pin. The Port 3 output buffers can sink 20 mA. When 1s are written to Port 3 pins they are pulled high by the internal pull-ups and can be used as inputs. As inputs, Port 3 pins that are externally being pulled low will source current (IIL) because of the pull-ups
    Mong các pro giúp đở , xin chân thành cảm ơn.
    connay co jhac ăt9s ko vay cac bac
      seven bi-directional I/O pins with internal pull-ups: có nghĩa là 7 pin này bên trong đã có điện trở kéo lên!
      Port 3 pins that are externally being pulled low will source current (IIL) because of the pull-ups :khi bên ngoài có điện trở kéo xuống thì từ cac chân này sẽ có dòng điện ra ngoài qua các điện trở kéo xuống! (bạn xem thêm các sơ đồ chân bên trong con này đi;các port là chân của cực máng con fet đó!)
      When pins P1.2 to P1.7 are used as inputs and are externally pulled low, they will source current (IIL) because of the internal pull-ups:câu này tương tự câu trên
        bác nào có sơ đồ chân và mạch vi xử lí của ic at9c251 gửi cho em với mail của em nè : hangocquydon.hue1989@gmail.com
          ic at 89c2051
            các bác cho em hỏi!con c2051 cần phải thiết lập đầu ra vào nó mới chạy có phải không ạ!
              Nguyên văn bởi vietnoi Xem bài viết
              Phải lập trình tùy theo mạch yêu cầu và nạp file hex khi đã lập trình cho nó! Nghĩa là phải có phần cứng và phần mềm như máy tính có win mới chạy.
              ĐT: 0972 20 58 68
              Gmail:
              tatdat Tìm hiểu thêm về tatdat
                Hôm qua, 07:44
                Hôm qua, 02:00
                22-02-2025, 22:18
                22-02-2025, 14:51
                22-02-2025, 14:39
                22-02-2025, 14:28
