mình phai viet lưu đồ thuật toán cho chương trình hiển thi dòng chữ "ky thuat vien thong B_k47 "cho vi điều khiển 8051 mình đã viết bằng hợp ngữ nhưng mình chưa viết được lưu đồ thuật toán cho chương trình bạn nào biết thì giúp mình với mình xin chân thành cảm ơn : sau đây là chương trình :
;chuong trinh hien thi dong chu "ky thuat vien thongB_k47"
; LCD Display Driver
; Timing code assumes 1.2MHz Clock:
;LCD Registers addresses
LCD_CMD_WR equ 0
LCD_DATA_WR equ 1
LCD_BUSY_RD equ 2
LCD_DATA_RD equ 3
;LCD Commands
LCD_CLS equ 1
LCD_HOME equ 2
LCD_SETMODE equ 4
LCD_SETVISIBLE equ 8
LCD_SHIFT equ 16
LCD_SETFUNCTION equ 32
LCD_SETCGADDR equ 64
LCD_SETDDADDR equ 128
;Reset vector
org 0000h
jmp start
;Start of the program
org 0100h
string3:db ' KY THUAT VIEN THONG '
db 0
string4:db 'B_K47 '
db 0
start: mov A,#038h
call wrcmd
loop: mov A,#LCD_SETVISIBLE+6 ;Make the display & blink visible:
call wrcmd
mov R7,#2
mov DPTR,#200
call wtms
mov A,#LCD_CLS ;Clear screen
call wrcmd
mov DPTR,#string3
call wrslow
mov A,#LCD_SETDDADDR+64
call wrcmd
mov DPTR,#string4
call wrslow
mov A,#LCD_SETVISIBLE+7 ;Show the blink cursor as well.
call wrcmd
mov DPTR,#2000
call wtms
call wrcmd
jmp loop
;Sub routine to write null terminated string at DPTR in program ram.
wrstr: mov R0,#LCD_DATA_WR
wrstr1: clr A
movc A,@A+DPTR
jz wrstr2
movx @R0,A
call wtbusy
inc DPTR
push DPL
push DPH
pop DPH
pop DPL
jmp wrstr1
wrstr2: ret
;Sub routine to write null terminated string at DPTR in program ram. Slowly
wrslow: mov R0,#LCD_DATA_WR
wrslw1: clr A
movc A,@A+DPTR
jz wrslw2
movx @R0,A
call wtbusy
inc DPTR
push DPL
push DPH
mov DPTR,#100
call wtms
pop DPH
pop DPL
jmp wrslw1
wrslw2: ret
;Sub routine to write command:
wrcmd: mov R0,#LCD_CMD_WR
movx @R0,A
jmp wtbusy
;Sub routine to write character:
wrchar: mov R0,#LCD_DATA_WR
movx @R0,A
;Subroutine to wait for busy clear
wtbusy: mov R1,#LCD_BUSY_RD
movx A,@r1
jb ACC.7,wtbusy
ret
;Wait for number of seconds in A
wtsec: push ACC
call wtms
pop ACC
dec A
jnz wtsec
ret
;Wait for number of milliseconds in DPTR
wtms: xrl DPL,#0FFh ;Can't do DEC DPTR, so do the loop by forming 2's complement
xrl DPH,#0FFh ;and incrementing instead.
inc DPTR
wtms1: mov TL0,#09Ch ;100 ticks before overflow = 1ms at 1.2MHz Clock
mov TH0,#0FFh
mov TMOD,#1 ;Timer 0 mode 1
setb TCON.4 ;Timer 0 runs
wtms2: jnb TCON.5,wtms2
clr TCON.4 ;Timer 0 stops
clr TCON.5
inc DPTR
mov A,DPL
orl A,DPH
jnz wtms1
ret
END
