em có mã code như dưới nhưng sao em buên dich ra toàn là lổi không ak 4 lổi .
em đang làm đồ án môn học hiện chữ lên lcd dung 89 .ai biết xin giúp đở dùm em ,em xin cảm ơn ạ
mã code:
#include <sfr51.inc>
E BIT P3.2
RS BIT P3.1
RW BIT P3.0
MAIN:
LCALL GHI_LENH ; GOI CHUONG TRINH CON GHI LENH RA LCD
MOV P1,#38H ; KHOI DONG CHE DO 2 DONG
LCALL WAIT
LCALL GHI_LENH
MOV P1,#0EH ;BAT DAU HIEN THI
LCALL WAIT
LCALL GHI_LENH
MOV P1,#06H ; TANG CON TRO SANG PHAI
LCALL WAIT ;CAI DAT LCD
START:
MOV DPTR,#DU_LIEU2 ;DONG 2 DUNG YEN
LCALL GHI_LENH
MOV P1,#0C0H
LCALL WAIT
LCALL HIEN_THI
MOV R2,#0 ;DONG 1 DICH
SHIFT1:
MOV DPTR,#DU_LIEU1
AAA:
LCALL DISPLAY1
LCALL DELEY500
INC DPTR
MOV A,DPL ;KIEM TRA DA DICH XONG DONG CHU RA MAN HINH LCD
CJNE A,#LOW(DU_LIEU1+19),AAA
MOV A,DPH
CJNE A,#HIGH(DU_LIEU1+19),AAA
INC R2
CJNE R2,#2,SHIFT1
MOV DPTR,#DU_LIEU3 ;DONG 1 DUNG YEN
LCALL GHI_LENH
MOV P1,#80H
LCALL WAIT
LCALL HIEN_THI
MOV R2,#0 ;DONG 2 DICH
SHIFT2:
MOV DPTR,#DU_LIEU4
BBB:
LCALL DISPLAY2
LCALL DELEY500
INC DPTR
MOV A,DPL
CJNE A,#LOW(DU_LIEU4+29),BBB
MOV A,DPH
CJNE A,#HIGH(DU_LIEU4+29),BBB
INC R2
CJNE R2,#3,SHIFT2
LJMP START
DISPLAY1:
LCALL GHI_LENH
MOV P1,#80H ; dua con tro ve dau dong 1
LCALL WAIT
HIEN_THI:
MOV R0,#0
LOOP:
MOV A,R0
MOVC A,@A+DPTR
LCALL GHI_DATA
MOV P1,A
LCALL WAIT
INC R0
CJNE R0,#16,LOOP
RET
DISPLAY2:
LCALL GHI_LENH
MOV P1,#0C0H
LCALL WAIT
LCALL HIEN_THI
RET
GHI_LENH:
SETB P3.2
CLR P3.0
CLR P3.1
RET
GHI_DATA:
SETB P3.2
SETB P3.0
CLR P3.1
RET
WAIT:
CLR P3.2
MOV TMOD,#10H
MOV TH1,#HIGH(-500)
MOV TL1,#LOW(-500)
CLR TF1
SETB TR1
JNB TF1,$
CLR TR1
CLR TF1
RET
DELEY500:
MOV R1,#0
DEM:
MOV TMOD,#10H
MOV TH1,#HIGH(-5000)
MOV TL1,#LOW(-5000)
CLR TF1
SETB TR1
JNB TF1,$
CLR TR1
CLR TF1
INC R1
CJNE R1,#50,DEM
RET
ORG 100H
DU_LIEU1:
DB 'DE TAI MON VI DIEU KHIEN '
ORG 150H
DU_LIEU2:
DB 'LOP DH07TD'
ORG 250H
DU_LIEU3:
DB 'KHOA CO KHI'
ORG 300H
DU_LIEU4:
DB 'TRUONG DH NONG LAM TP.HCM'
END
đây là lỗi :
Assembling AssemblyFile1.asm
4 errors found
"D:\mach lcd\codelcd\AssemblyFile1.asm" 111 Undecodable line, Syntax error
"D:\mach lcd\codelcd\AssemblyFile1.asm" 114 Undecodable line, Syntax error
"D:\mach lcd\codelcd\AssemblyFile1.asm" 117 Undecodable line, Syntax error
"D:\mach lcd\codelcd\AssemblyFile1.asm" 120 Undecodable line, Syntax error
mã code:
E BIT P3.2
RS BIT P3.1
RW BIT P3.0
MAIN:
LCALL WAIT
LCALL GHI_LENH
LCALL WAIT
LCALL GHI_LENH
START:
LCALL GHI_LENH
MOV P1,#0C0H
LCALL WAIT
LCALL HIEN_THI
SHIFT1:
MOV DPTR,#DU_LIEU1
AAA:
LCALL DISPLAY1
LCALL DELEY500
INC DPTR
MOV A,DPH
INC R2
CJNE R2,#2,SHIFT1
LCALL GHI_LENH
MOV P1,#80H
LCALL WAIT
LCALL HIEN_THI
SHIFT2:
MOV DPTR,#DU_LIEU4
BBB:
LCALL DISPLAY2
LCALL DELEY500
INC DPTR
MOV A,DPL
MOV A,DPH
INC R2
CJNE R2,#3,SHIFT2
LJMP START
DISPLAY1:
LCALL GHI_LENH
LCALL WAIT
HIEN_THI:
MOV R0,#0
LOOP:
MOV A,R0
MOVC A,@A+DPTR
LCALL GHI_DATA
MOV P1,A
LCALL WAIT
INC R0
CJNE R0,#16,LOOP
RET
DISPLAY2:
LCALL GHI_LENH
MOV P1,#0C0H
LCALL WAIT
LCALL HIEN_THI
RET
GHI_LENH:
SETB P3.2
CLR P3.0
CLR P3.1
RET
GHI_DATA:
SETB P3.2
SETB P3.0
CLR P3.1
RET
WAIT:
CLR P3.2
MOV TMOD,#10H
MOV TH1,#HIGH(-500)
MOV TL1,#LOW(-500)
CLR TF1
SETB TR1
JNB TF1,$
CLR TR1
CLR TF1
RET
DELEY500:
MOV R1,#0
DEM:
MOV TMOD,#10H
MOV TL1,#LOW(-5000)
CLR TF1
SETB TR1
JNB TF1,$
CLR TR1
CLR TF1
INC R1
CJNE R1,#50,DEM
RET
ORG 100H
DU_LIEU1:
ORG 150H
DU_LIEU2:
DB 'LOP DH07TD'
ORG 250H
DU_LIEU3:
DB 'KHOA CO KHI'
ORG 300H
DU_LIEU4:
END
đây là lỗi :
4 errors found
