Thắc mắc giao tiếp I2C giữa 8051 và chip FM RDA5807
  • Thắc mắc giao tiếp I2C giữa 8051 và chip FM RDA5807
    Mình đang làm mạch thu FM dùng 8051 và chip RDA5807 nhưng tới phần cấu hình các thanh ghi cho con RDA thì làm mãi nó không chịu chạy
    mình đọc datasheet của nó và cấu hình như sau
    void Write_Page_To_RDA(unsigned char* pData,unsigned char NoOfBytes)
    unsigned int i;
    I2C_Start(); // Start i2c communication
    I2C_Write_Byte(0x20);
    for(i=0;i<NoOfBytes;i++)
    { // Write NoOfBytes
    I2C_Write_Byte(pData[i]);
    I2C_Send_ACK(); // Write data byte
    I2C_Stop(); // Stop i2c communication
    // Function Purpose: Read_Bytes_From_RDA reads a NoOfBytes bytes from given starting address.
    // Address can have any value fromm 0 to 0x1FFF. Also, NoOfBytes can have any value 0 to 0x1FFF.
    // Read bytes are returned in pData array.
    void Read_Bytes_From_RDA(unsigned char* pData, unsigned int NoOfBytes)
    unsigned int i;
    // Send i2c address of with write command
    I2C_Write_Byte(0x21);
    for(i=0;i<NoOfBytes;i++) // Read NoOfBytes
    pData[i] = I2C_Read_Byte(); // Read next byte from EEPROM
    // Make SCK low, so that slave can stop driving SDA pin
    // Send a NACK to indiacate read operation is complete
    I2C_Send_NACK();
    I2C_Stop();
    void I2C_Send_ACK(void)
    Set_SCK_Low; // Make SCK pin low
    __delay_us(HalfBitDelay/2); // Data pin should change it's value,
    // when it is confirm that SCK is low
    Set_SDA_Low; // Make SDA Low
    __delay_us(HalfBitDelay/2); // 1/4 bit delay
    Set_SCK_High; // Make SCK pin high
    __delay_us(HalfBitDelay); // Half bit delay
    //Function : I2C_Send_NACK sends NACK bit sequence
    void I2C_Send_NACK(void)
    Set_SDA_High; // Make SDA high
    // Function Purpose: I2C_Write_Byte transfers one byte
    unsigned char I2C_Write_Byte(unsigned char Byte)
    unsigned char i; // Variable to be used in for loop
    for(i=0;i<8;i++) // Repeat for every bit
    if((Byte<<i)&0x80) // Place data bit value on SDA pin
    Set_SDA_High; // If bit is high, make SDA high
    else // Data is transferred MSB first
    Set_SDA_Low; // If bit is low, make SDA low
    __delay_us(HalfBitDelay/2); // Toggle SCK pin
    Set_SCK_High; // So that slave can
    __delay_us(HalfBitDelay); // latch data bit
    // Get ACK from slave
    Set_SCK_Low;
    Set_SDA_High;
    Set_SCK_High;
    return SDA;
    // Function Purpose: I2C_Read_Byte reads one byte
    unsigned char I2C_Read_Byte(void)
    unsigned char i, d, RxData = 0;
    for(i=0;i<8;i++)
    Set_SDA_High; // Don't drive SDA
    d = SDA; // Capture Received Bit
    RxData = RxData|(d<<(7-i)); // Copy it in RxData
    return RxData; // Return received byte
    mọi người vào xem giúp mình code sai ở chổ nào
    datasheet con này RDA Microelectronics
    Mọi người vào xem cho mình ý kiến với,giờ chỉ còn cái giao tiếp với con chip FM này là xong mà loay hoay mãi vẫn chưa được.
      Không biết bạn mua RDA này ở đâu, mình mua của TME 2 lần thì có 1 lần mua chạy ok, nhưng 1 lần mua 10 con không chạy, đo không thấy dao động ở thạch anh.
      mtjk8g Tìm hiểu thêm về mtjk8g
