Sửa cho em đoạn delay này cái
  • Sửa cho em đoạn delay này cái
    $MOD51
    GIAY EQU R2
    PHUT EQU R3
    GIO EQU R4
    B_GIAY EQU R7
    B_MODE EQU R6
    MODE BIT P3.0
    UP BIT P3.1
    D0WN BIT P3.2
    ORG 000H
    LJMP MAIN
    ORG 00BH
    LJMP ISR_T0
    MAIN:
    MOV TMOD,#01H ;CHE DO TIMER - MODE 1
    MOV TH0,#3CH ;THOI GIAN TIMER - 50MS
    MOV TL0,#0B0H
    CLR TF0 ;XOA CO TRAN
    SETB TR0 ;CHAY TIMER
    MOV IE,#82H ;CHO PHEP NGAT TIMER0
    MOV B_MODE,#0
    TD:
    MOV GIO,#0 ;NAP GIA TRI GIO BAN DAU
    X4:
    MOV PHUT,#0 ;NAP GIA TRI PHUT BAN DAU
    X3:
    MOV GIAY,#0 ;NAP GIA TRI GIAY BAN DAU
    MOV B_MODE,#0
    X2:
    MOV B_GIAY,#0 ;NAP GIA TRI BAN DAU CHO BIEN DEM SO LAN NGAT TIMER
    LCALL HEX_BCD ;DOI GIA TRI THOI GIAN -> BCD -> MA 7 DOAN
    LCALL BCD_7DOAN
    X1:
    LCALL HIENTHI ;HIEN THI THOI GIAN
    JNB MODE,ADJ ;KIEM TRA NUT MODE - DUNG -> PHAN CHINH THOI GIAN ADJ
    CJNE B_GIAY,#20,X1 ;KIEM TRA SO LAN NGAT TIMER - 20 LAN x 50MS = 1S
    INC GIAY ;TANG GIAY
    CJNE GIAY,#60,X2 ;SO SANH DU 60 GIAY - CHUA DU -> QUAY LAI HIEN THI
    INC PHUT ;TANG PHUT
    CJNE PHUT,#60,X3 ;SO SANH DU 60 PHUT - CHUA DU -> QUAY LAI HIEN THI
    INC GIO ;TANG GIO
    CJNE GIO,#24,X4 ;SO SANH DU 60 GI0 - CHUA DU -> QUAY LAI HIEN THI
    SJMP TD ;DU -> QUAY LAI TU DAU
    ;CHUONG TRINH CON DOI HEX -> BCD (TACH SO HEX)
    ;R2 -> 11H & 10H, R3 -> 13H & 12H, R4 -> 15H & 14H
    HEX_BCD:
    MOV R0,#02 ;NAP DIA CHI DAU CUA VUNG NHO CHUA SO HEX
    MOV R1,#10H ;NAP DIA CHI DAU CUA VUNG NHO CHUA SO BCD
    H1:
    MOV B,#10 ;
    MOV A,@R0 ;LAY SO HEX CAN CHUYEN DOI
    DIV AB ;CHIA 10 DE TACH RIENG BYTE THAP VA BYTE CAO
    MOV @R1,B ;CAT BYTE THAP
    INC R1 ;TANG DIA CHI VUNG NHO CHUA SO BCD
    MOV @R1,A ;CAT BYTE CAO
    INC R0 ;TANG DIA CHI VUNG NHO CHUA SO HEX
    CJNE R0,#05H,H1 ;KIEM TRA HOAN TAT VIEC CHUYEN DOI
    RET
    ;CHUONG TRINH CON DOI SO BCD -> MA 7 DOAN
    ;SO BCD (10H - 15H) -> MA 7 DOAN (20H - 25H)
    BCD_7DOAN:
    MOV DPTR,#200H ;NAP DIA CHI VUNG CHUA MA 7 DOAN
    MOV R0,#10H ;NAP DIA CHI DAU TIEN CUA VUNG NHO CHUA SO BCD
    MOV R1,#20H ;NAP DIA CHI DAU TIEN CUA VUNG NHO CHUA MA 7 DOAN
    B1:
    MOV A,@R0 ;GIAI MA
    MOVC A,@A+DPTR
    MOV @R1,A
    INC R0 ;TANG DIA CHI VUNG NHO CHUA SO BCD
    INC R1 ;TANG DIA CHI VUNG NHO CHAU MA 7 DOAN
    CJNE R0,#16H,B1 ;KEM TRA HOAN TAT VIEC GIAI MA
    RET
    ;CHUONG TRINH CON HIEN THI (20H - 25H)
    HIENTHI:
    MOV R0,#20H ;DIA CHI DAU TIEN CUA VUNG CHUA DU LIEU CAN HIEN THI
    MOV A,#0FEH ;MA QUET DAU TIEN
    HT1:
    MOV P0,@R0 ;LAY DU LIEU CAN HIEN THI
    MOV P1,A ;XUAT MA QUET
    LCALL DELAY
    MOV P1,#0FFH ;TAT LED DE CHONG LEM
    LCALL DELAY
    INC R0 ;CHUYEN SANG DIA DIA KE TIEP
    RL A ;THAY DOI MA QUET
    CJNE A,#0BFH,HT1 ;KIEM TRA QUET XONG CHUA - CHUA XONG -> QUAY VE LAM TIEP
    RET ;TRO LAI KHI DA QUET VA HIEN THI XONG
    ISR_T0: ;ISR TIMER0 - 50MS
    CLR TR0
    CLR TF0
    MOV TH0,#3CH
    MOV TL0,#0B0H
    INC B_GIAY ;TANG BIEN DEM SO LAN NGAT - 1 LAN = 50MS
    SETB TR0
    RETI
    ADJ: ;CHUONG TRINH CON XU LY NUT MODE
    LCALL HIENTHI
    JNB MODE,ADJ ;KIEM TRA NHU MODE DA DUOC THA RA HAY CHUA
    INC B_MODE ;TANG SO LAN NHAN NUT MODE
    CJNE B_MODE,#4,ADJ_GPG ;KIEM TRA SO LAN NHAT NUT MODE
    MOV B_MODE,#0 ;DU 3 LAN -> TRO LAI TU DAU
    MOV B_GIAY,#0
    SJMP X2
    ADJ_GPG:
    LOOP1:
    MOV 76H,#10 ;SO LAN CHOP TAT CAP LED DANG DUOC CHINH
    LOOP2:
    MOV 77H,#0FFH ;SO LAN KIEM TRA NUT NHAN
    LCALL HEX_BCD
    LCALL BCD_7DOAN
    LOOP:
    LCALL HIENTHI
    CJNE B_GIAY,#20,Z1 ;KIEM TRA SO LAN NGAT - CHUA DU THI KIEM TRA NUT NHAN
    LJMP TANGGIAY ;DU 20 LAN NGAT -> TANG GIAY
    Z1:
    JNB UP,TANG ;KIEM TRA NUT UP
    JNB D0WN,GIAM ;KIEM TRA NUT DOWN
    DJNZ 77H,LOOP ;GIAM SO LAN KIEM TRA NUT NHAN
    MOV 77H,#0FFH ;NAP SO LAN TAT (THOI GIAN TAT)
    CJNE B_MODE,#1,SS11 ;KIEM TRA NHAN MODE 1 LAN - SAI -> KIEM TRA TIEP SS11
    MOV 24H,#0FFH ;DUNG - NHAN MODE 1 LAN -> NAP GIA TRI TAT LED...
    MOV 25H,#0FFH ;CHO PHAN "GIO"
    SJMP TAT ;HIEN THI TRANG THAI LED
    SS11:
    CJNE B_MODE,#2,SS12 ;KIEM TRA NHAN MODE 2 LAN - SAI -> KIEM TRA TIEP SS12
    MOV 22H,#0FFH ;DUNG - NHAN MODE 2 LAN -> NAP GIA TRI TAT LED...
    MOV 23H,#0FFH ;CHO PHAN "PHUT"
    SS12: ;NHAN MODE 3 LAN -> NAP GIA TRI TAT LED...
    MOV 20H,#0FFH ;CHO PHAN "GIAY"
    MOV 21H,#0FFH
    TAT:
    CJNE B_GIAY,#20,Z2 ;KIEM TRA SO LAN NGAT - CHUA DU THI KIEM TRA NUT NHAN
    Z2:
    DJNZ 77H,TAT ;GIAM SO LAN TAT (THOI GIAN TAT)
    DJNZ 76H,LOOP2 ;GIAM SO LAN CHOP TAT CAP LED
    MOV B_MODE,#0 ;XOA SO LAN NHAN NUT MODE
    LJMP X2 ;QUAY LAI
    TANG:
    LCALL HIENTHI
    CJNE B_GIAY,#20,Z3 ;KIEM TRA SO LAN NGAT - CHUA DU THI KIEM TRA NHU NHAN
    Z3:
    JNB UP,TANG
    CJNE B_MODE,#1,SS1
    INC GIO
    CJNE GIO,#24,LOOP1
    MOV GIO,#0
    LOOP11:
    LJMP LOOP1
    SS1:
    CJNE B_MODE,#2,SS2
    INC PHUT
    CJNE PHUT,#60,LOOP1
    MOV PHUT,#0
    SJMP LOOP1
    SS2:
    INC GIAY
    CJNE GIAY,#60,Z5
    MOV GIAY,#0
    Z5:
    LJMP LOOP1
    GIAM:
    LCALL HIENTHI
    CJNE B_GIAY,#20,Z4 ;KIEM TRA SO LAN NGAT - CHUA DU THI KIEM TRA NUT NHAN
    Z4:
    JNB D0WN,GIAM
    CJNE B_MODE,#01,SS3
    DEC GIO
    CJNE GIO,#0FFH,K1
    MOV GIO,#23
    K1:
    LJMP LOOP1
    SS3:
    CJNE B_MODE,#02,SS4
    DEC PHUT
    CJNE PHUT,#0FFH,K2
    MOV PHUT,#59
    K2:
    LJMP LOOP1
    SS4:
    DEC GIAY
    CJNE GIAY,#0FFH,K3
    MOV GIAY,#59
    K3:
    LJMP LOOP1
    TANGGIAY:
    MOV B_GIAY,#0
    INC GIAY
    CJNE GIAY,#60,EXIT
    MOV GIAY,#0
    INC PHUT
    CJNE PHUT,#60,EXIT
    MOV PHUT,#0
    EXIT:
    LJMP LOOP
    DELAY: ;CHUONG TRINH CON TAO THOI GIAN TRE 150US
    MOV 7FH,#50H
    DJNZ 7FH,$
    RET
    ORG 200H ;VUNG MA 7 DOAN
    DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H
    END
    Đây là code của đồng hồ số. em dùng thạch anh 11.0592 mà nó chạy chậm hơn đồng hồ điên thoại, Cứ 1 phút nó chạy chậm hơn đồng hồ điện thoại 5s.Anh nào biết sửa hộ em cho nó chạy nhanh hơn 1 tý ko.cảm ơn các bạn nhiều
    cho em hỏi nốt câu này nữa.em muốn mắc thêm 8 led đơn ở port2 thì phải lập trình như thế nào để đồng hồ vẫn chạy bình thường mà 8led đơn vẫn nháy đc nhiều trạng thái.chúc các bạn 1 ngày vui vẻ.thank
      Khi có giao tiếp với máy tính mới dùng thạch anh 11.0592Mhz để đạt tốc độ baud cao nhất 19200 bps.
      Với thạch anh 11.0592 thì chu kỳ máy là T = 12/f là một số lẻ ==> đồng hồ chạy sai sau 1 thời gian hoạt động. Bạn dùng thạch anh 12Mhz thì chu kỳ máy là 1us thì hoạt động ít sai số hơn đáng kể và khi đó giá trị cho timer ở chương trình ngắt:
      MOV TL0,#LOW(-20000)
      MOV TH0,#HIGH(-20000)
      Người nhỏ bé.
        cảm ơn bạn.ở chỗ mình ko có bán thach anh.
        hieuhht Tìm hiểu thêm về hieuhht
          20-02-2025, 11:52
