giúp em mạch led ma trận
  • giúp em mạch led ma trận
    em tìm thấy cái này trên mạng
    http://www2.hcmuaf.edu.vn/contents.p...=nguyenbavuong
    nhưng trong chương trình ở chỗ chống lem,em không thấy nhãn DDD,em chạy mô phỏng cũng không đúng.có anh nào giúp em với.thanks nhiều.
    đây là code
    $MOD51
    ORG 00H
    MAIN:
    MOV DPTR,#DATABASE ;DIA CHI NAP DU LIEU
    AAA:
    MOV R0,#5 ;TOC DO HIEN KY TU
    BBB:
    LCALL SCANDATA ;NAP DU LIEU
    DJNZ R0,BBB
    INC DPTR
    MOV A,DPL
    MOV R1,DPH
    CJNE R1,#02H,AAA ;KIEM TRA KET THUC CHUOI ?
    CJNE A,#25H,AAA
    SJMP MAIN
    SCANDATA:
    PUSH ACC
    PUSH 00H
    PUSH 01H
    MOV R0,#00H ;DIA CHI DU LIEU DAU TIEN TRON DATABASE
    MOV R1,#01H ;HIEN THI RA COT DAU TIEN
    SCAN:
    MOV A,R0
    MOVC A,@A+DPTR ;NAP DU LIEU TU DATABASE VAO A
    MOV P2, A ;HIEN THI RA DONG TUONG UNG
    MOV P1,R1 ;HIEN THI RA COT DAU TIEN
    LCALL DELAY5MS ;CHUONG TRINH TAO TRE 5 MS
    MOV R4,#40H ;CHONG LEM
    MOV P1,#00H
    DJNZ R4,DDD
    INC R0 ;HIEN THI DU LIEU KE TIEP
    MOV A,R1 ;CHUYEN SANG COT KE TIEP
    RL A
    MOV R1,A
    CJNE R0,#8H,SCAN ;KIEM TRA QUET COT THU 8 CHUA
    POP 01H
    POP 00H
    POP ACC
    RET
    DELAY5MS:
    PUSH 00H
    PUSH 01H
    MOV R1,#10
    CCC:
    MOV R0,#250
    DJNZ R0,$
    DJNZ R1,CCC
    POP 01H
    POP 00H
    RET
    DATABASE:
    DB 00H,00H,00H,00H,00H,00H ;"KHOANG TRANG"
    DB 02H,02H,0FEH,02H, 02H,00H ;"T"
    DB 0FEH,12H, 32H,52H, 8CH,00H ;"R"
    DB 7EH,80H, 80H,80H, 7EH,00H ;"U"
    DB 7CH,82H, 82H,82H, 7CH,00H ;"O"
    DB 0FEH,04H, 08H,10H,0FEH,00H ;"N"
    DB 7CH,82H, 92H,92H, 74H,00H,00H,00H ;"G"
    DB 10H,0FEH,92H,82H, 82H,7CH,00H ;"D"
    DB 0FCH, 22H,22H,22H,0FCH,00H ;"A"
    DB 82H,0FEH,82H,00H, 00H,00H ;"I"
    DB 0FEH,10H,10H,10H,0FEH,00H ;"H"
    DB 7CH,82H,82H,82H, 7CH,00H ;"O"
    DB 7CH,82H,82H,82H, 44H,00H,00H,00H ;"C"
    DB 7CH,82H,82H,82H, 44H,00H ;"C"
    DB 0FEH,04H,08H,10H,0FEH,00H ;"N"
    DB 7CH,82H,92H,92H, 74H,00H,00H,00H ;"G"
    DB 0FEH, 04H,08H,10H,0FEH,00H ;"N"
    DB 7CH, 82H,92H,92H, 74H,00H ;"G"
    DB 0FEH, 10H,10H,10H,0FEH,00H ;"H"
    DB 82H,0FEH,82H,00H ;"I"
    DB 0FEH, 92H,92H,92H, 82H,00H ;"E"
    DB 0FEH, 12H,12H,12H, 0CH,00H,00H,00H ;"P"
    DB 0FEH,12H, 12H,12H, 0CH,00H ;"P"
    DB 80H,00H ;"."
    DB 0FEH,10H, 10H,10H,0FEH,00H ;"H"
    DB 7CH,82H, 82H,82H, 44H,00H ;"C"
    DB 0FEH,04H, 08H,04H,0FEH,00H,00H ;"M"
    DB 10H,10H,10H,00H,00H ;"-"
    DB 0FEH,10H,28H,44H, 82H,00H ;"K"
    DB 0FCH,22H,22H,22H,0FCH,00H,00H,00H ;"A"
    DB 7CH,82H,92H,92H, 74H,00H ;"G"
    DB 0FEH,92H,92H,92H, 82H,00H,00H,00H ;"E"
    DB 0FEH, 04H,08H,10H,0FEH,00H,00H,00H ;"N"
    DB 02H,02H,0FEH,02H,02H,00H ;"T"
    DB 7EH,80H, 80H,80H,7EH,00H,00H ;"U"
    DB 4CH,92H, 92H,92H, 64H,00H ;"S"
    DB 3EH,40H, 80H,40H, 3EH,00H ;"V"
    DB 44H, 00H,00H ;":"
    DB 0FEH,80H,80H,80H,80H,00H ;"L"
    DB 7EH,80H,80H,80H,7EH,00H ;"U"
    DB 7EH,80H,80H,80H,7EH,00H,00H,00H ;"U"
    DB 02H, 02H,0FEH,02H, 02H,00H ;"T"
    DB 82H,0FEH, 82H,00H ;"I"
    DB 0FEH, 92H, 92H,92H, 82H,00H ;"E"
    DB 0FEH, 04H, 08H,10H,0FEH,00H,00H,00H ;"N"
    DB 10H,0FEH, 92H,82H, 82H,7CH,00H ;"D"
    DB 0FCH, 22H, 22H,22H,0FCH,00H ;"A"
    DB 02H, 02H,0FEH,02H, 02H,00H,00H,00H ;"T"
    DB 0FEH, 04H, 08H,04H,0FEH,00H ;"M"
    DB 4CH, 92H, 92H,92H, 64H,00H ;"S"
    DB 3EH, 40H, 80H,40H, 3EH,00H ;"V"
    DB 44H, 00H ;":"
    DB 7CH, 82H, 82H,82H,7CH,00H ;"0"
    DB 4EH, 8AH, 8AH,8AH,72H,00H ;"5"
    DB 8CH,0C2H,0A2H,92H,8CH,00H ;"2"
    DB 44H, 92H, 92H,92H,6CH,00H ;"3"
    DB 4CH, 92H, 92H,92H,7CH,00H,00H,00H ;"9"
    END
    hi cái này tui có dùng rồi chỗ chông lem báo sai liên tục
    bạn cứ xóa đi là chạy dc ko vấn đề gì nó ko quan trọng
    8051 là con em viết thành thạo. em sẵn sàng giúp đỡ các pác nếu em có thể
      mình thấy kiến thức quang báo của các bạn hạn chế quá, nếu được mình sẽ hướng dẫn cho các bạn chi tiết hơn, sdt 0987324303 có gì cứ gọi nha
      --- cung cấp đèn led, linh kiện điện tử---
        thanks bạn.bạn có tài code và mach nguyên lí thì share cho mình tham khảo với
          oh có người giúp rồi
          em có cái code thế này :
          Code:
          ; <sfr51.inc>
          #define SCL P2.1
          #define SDA P2.0
          #define RUN_DATA 40H
          #define MOC 41H
          #define BIEN_32 42H
          #define TIME_BACK 43H
          TIME_MOVE EQU 44H
          ORG 0000H
          MAIN:
          		DONG1:
          		     LCALL    SCAN
          		     DJNZ   R0, DONG1
          		     MOV    DPTR,#VINHPHAT
          		M1:
          		     MOV    R0,#2
          		M2:
          			LCALL SCAN ;NAP DU LIEU
          			DJNZ R0,M2
          			INC DPTR
          			MOV A,DPL
          			CJNE A,#LOW(VINHPHAT+50),M1
          BACK1: ; MAIN
          MOV RUN_DATA,MOC
          MOV A,RUN_DATA
          MOV TIME_BACK,TIME_MOVE
          BACK3:
          MOV A,RUN_DATA
          MOVC A,@A+DPTR
          MOV P3,A
          LCALL DELAY
          MOV P3,#0FFH
          CLR SCL
          NOP
          SETB SCL
          INC RUN_DATA
          MOV A,RUN_DATA
          CJNE A,#200,DEM_32_LAN
          MOV RUN_DATA,#0
          DEM_32_LAN:
          INC BIEN_32
          MOV A,BIEN_32
          CJNE A,#100,BACK3
          MOV RUN_DATA,MOC
          MOV BIEN_32,#0
          SETB SDA
          CLR SCL
          NOP
          SETB SCL
          CLR SDA
          DJNZ TIME_BACK,BACK3
          INC MOC
          MOV A,MOC
          CJNE A,#92,THOAT
          MOV MOC,#0
          THOAT:
          SJMP BACK1
          SCAN:
          MOV TIME_MOVE,#1
          SETB SDA ; START
          CLR SCL
          SETB SCL
          CLR SDA
          MOV RUN_DATA,#2 ; DEFAUL
          MOV MOC,#2
          MOV BIEN_32,#0
          DELAY:
          MOV R6,#255
          delay1:
          nop
          nop
          DJNZ R6,delay1
          RET
          VINHPHAT:
          DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
          DB     7H,3H,0FDH,0FEH,0FDH,3H,7H                                     ;V
          DB     0FFH
          DB     0H,0H,0FFH        ;I
          DB     0H,0H,0BFH,0DFH,0EFH,0H,0H                                        ;N
          DB     0FFH
          DB     0H,0H,0F7H,0F7H,0F7H,0H,0H                                         ;H
          DB     0FFH,0FFH ,0FFH
          DB     0H,0H,77H,77H,7H,8FH,0FFH                                          ;P
          DB     0FFH
          DB     0FFH
          DB     0E0H,0C0H,0B7H,77H,0B7H,0C0H,0E0H                          ; A
          DB     0FFH
          DB     7FH,7FH,0H,0H,7FH,7FH,0FFH                                       ;T
          KINH :
          DB     0FFH,0FFH,0DBH,0E7H,81H,0E7H,0DBH,0FFH,0FFH,0FFH,0FFH,0DBH,0E7H,81H,0E7H,0DBH,0FFH,0FFH  ;HOA
          DB     0H,0H,0E7H,0DBH,0BDH,7EH,0FFH                                 ;K
          DB     0FFH,0H,0H,0FFH                                                             ;I
          DB     0H,0H,0BFH,0DFH,0EFH,0H,0H,0FFH                              ;N
          DB     0H,0H,0F7H,0F7H,0F7H,0H,0H,0FFH                                 ;H
          DB     0FFH,0FFH        ;CACH
          DB     81H,0H,7EH,7EH,7EH,0BDH,0FFH                                     ;C
          DB     0E0H,0C0H,0B7H,77H,0B7H,0C0H,0E0H,0FFH                   ;A
          DB     81H,0H,7EH,7EH,7EH,0H,81H,0FFH                                    ;O
          DB     0FFH,0FFH        ;CACH
          DB     81H,0H,7EH,7AH,7CH,0H,80H,0FEH                                  ;Q
          DB     1H,0H,0FEH,0FEH,0FEH,0H,1H,0FFH                               ;U
          DB     0FH,7H,0F0H,0F0H,7H,0FH,0FFH                                      ;Y
          DB     0FFH,0FFH        ;CACH
          END
          và mạch như thế này :
          em ko bit làm cách nào để tăng số byte hiển thị
          và tăng thêm 1 dòng nữa
          ai bít giúp em với
          giakien Tìm hiểu thêm về giakien
