giúp em cái chương trình led ma trận dùng 74HC595 ........
  • giúp em cái chương trình led ma trận dùng 74HC595 ........
    em đang làm bảng quang báo loại lớn (16x160) dùng chip at89s52 và 2.0 clock 2.1 data dịch cột P3 dùng tran kéo hàng
    các pác giúp em với
    đây là code 8x160 của em:
    Code:
    #define SCL P2.1
    #define SDA P2.0
    #define SDA1 P2.2
    #define RUN_DATA 40H
    #define MOC 41H
    #define BIEN_32 42H
    #define TIME_BACK 43H
    TIME_MOVE EQU 44H
    ORG 0000H
    MAIN:
    		DONG1:
    		     LCALL    SCAN
    		     DJNZ   R0, DONG1
    		     MOV    DPTR,#VINHPHAT
    		M1:
    		     MOV    R0,#2
    		M2:
    			LCALL SCAN ;NAP DU LIEU
    			DJNZ R0,M2
    			INC DPTR
    			MOV A,DPL
    			CJNE A,#LOW(VINHPHAT+50),M1
    BACK1: ; MAIN
    MOV RUN_DATA,MOC
    MOV A,RUN_DATA
    MOV TIME_BACK,TIME_MOVE
    BACK3:
    MOV A,RUN_DATA
    MOVC A,@A+DPTR
    MOV P3,A
    LCALL DELAY
    MOV P3,#0FFH
    CLR SCL
    NOP
    SETB SCL
    INC RUN_DATA
    MOV A,RUN_DATA
    CJNE A,#0FFH,DEM_32_LAN
    MOV RUN_DATA,#0
    DEM_32_LAN:
    INC BIEN_32
    MOV A,BIEN_32
    CJNE A,#99,BACK3
    MOV RUN_DATA,MOC
    MOV BIEN_32,#190
    SETB SDA
    CLR SCL
    NOP
    SETB SCL
    CLR SDA
    DJNZ TIME_BACK,BACK3
    INC MOC
    MOV A,MOC
    CJNE A,#0ffh,THOAT
    MOV MOC,#0
    THOAT:
    SJMP BACK1
    SCAN:
    MOV TIME_MOVE,#1
    SETB SDA ; START
    CLR SCL
    SETB SCL
    CLR SDA
    MOV RUN_DATA,#200 ; DEFAUL
    MOV MOC,#200
    MOV BIEN_32,#0
     ret
    SCAN2:
    MOV TIME_MOVE,#1
    SETB SDA1 ; START
    CLR SCL
    SETB SCL
    CLR SDA1
    MOV RUN_DATA,#2 ; DEFAUL
    MOV MOC,#2
    MOV BIEN_32,#0
    ret
    DELAY:
    MOV R6,#250
    delay1:
    nop
    nop
    DJNZ R6,delay1
    RET
    VINHPHAT:
    DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
    ;DB     0FFH,1H,1H,0FDH,0FDH,0FDH,0FFH,1H,1H,6DH,6DH,6DH,0FFH,1H,1H,7DH,7DH,83H,83H,0FFH,0FFH,0FFH,0FFH,0FFH  ;led
    DB     0FFH,1H,1H,0FDH,0FDH,0FDH,0FFH,1H,1H,6DH,6DH,6DH,0FFH,1H,1H,7DH,7DH,1H,83H,0FFH,0FFH,0FFH,0FFH,0FFH
    DB     0FFH,0FFH,80H,80H,0BEH,0BEH,80H,0C1H,0FFH,80H,80H,0FFH,0CDH,84H,0B6H,0B6H,90H,0D9H,0FFH,80H,80H,0B7H,0B7H,87H
    DB     0CFH,0FFH,80H,80H,0FEH,0FEH,0FEH,0FFH,0F0H,0E0H,0DBH,0BBH,0DBH,0E0H,0F0H,0FFH,0FFH,8FH,87H,0F0H,0F0H,87H,8FH,0FFH
    DB     0FFH,0FFH,0DBH,0E7H,81H,0E7H,0DBH,0FFH,0FFH,0FFH,0FFH,0DBH,0E7H,81H,0E7H,0DBH,0FFH,0FFH  ;HOA
    END
    cái này em chưa làm mạch thực chỉ mới mô phỏng trên proteus
    cái em cần giúp là làm sao để kéo dài đoạn văn và có thể chạy dc chữ lớn (2 dòng) mong các pác giúp em
    xin trân thành cảm ơn
    8051 là con em viết thành thạo. em sẵn sàng giúp đỡ các pác nếu em có thể
    sao ko có ai giúp vậy nè bùn quá
      Chịu thôi..Không đủ trình độ. Tui làm dịch chữ trên led 16x64 mà còn toát cả mồ hôi nè...^^
        dài chữ thì dài mã chữ ra,bộ nhớ không đủ thì lắp thêm bộ nhớ ngoài RAM ,ROM chẳng hạn
          Nguyên văn bởi a2ofu Xem bài viết
          bạn có thể gửi cho mình code của led 16x64 đc hok
          gmail: vietdung91hp@gmail.com
          hoangphat đam mê về ngành điện tử Tìm hiểu thêm về hoangphat
