Thanks bác.
Các chương trình khác thì mình có CLR TR0.Ko hiểu sao tự nhiên ct này thì thiếu nó.(viết lâu rồi,tại hơi lười kiểm tra lại).
Nhưng đối với ứng dụng này thì nó cũng ko ảnh hưởng gì nhiều
Thanks bác.
Cảm ơn bạn nhiều, bạn giải thích cái code này cho mình với, thằng em nó viết cho tui mà không hiểu gì hết. huhu
;**************//////------------ MATRIX 8X8X2 ----------\\\\\\******************
;**////////////////__ Chuong trinh chay chu tren bo led ___\\\\\\\\\\\\\\\\\\\\\\
;**///////////////__ ma tran 8x8 loai 2 mau ________________\\\\\\\\\\\\\\\\\\\\\
;**//////////////___ Su dung vi dieu khien 89C55 cua ATMEL __\\\\\\\\\\\\\\\\\\\\
;**\\\\\\\\\\\\\\ __ Thuc hien bien doi du lieu noi tiep ____////////////////////
;**\\\\\\\\\\\\\\\ ___ sang song song roi dua ra day led ___/////////////////////
;**\\\\\\\\\\\\\\\\ ---------- By Le Quoc Khai ---------- //////////////////////
;@@@ CAC TEN BYTE DUNG TRONG CHUONG TRINH @@@
addrh equ 30H
addrl equ 31H
addrhsource equ 32H
addrlsource equ 33H
addrhend equ 34H
addrlend equ 35H
addrhtemp equ 36H
addrltemp equ 37H
addrhendtemp equ 38H
addrlendtemp equ 39H
chuancolor equ 3AH ;loi:dat ten byte la 40H thi tu dong cac bit dat ben duoi dang le 28H lai chuyen qua 40H va gay loi
speed_value equ 3BH
storage1 equ 20H
storage2 equ 21H
storage3 equ 22H
storage4 equ 23H
storage5 equ 24H
storage6 equ 25H
storage7 equ 26H
storage8 equ 27H
;r4 bank0 dung ho tro delay keo chu
;r5 bank0 chua gia tri du lieu hien tai
;r3 bank0 lam temp de tach byte thanh bit trong che do 8bit
;@@@ CAC TEN BIT DUNG TRONG CHUONG TRINH @@@
col1 bit p2.0
col2 bit p2.1
col3 bit p2.2
fade bit p2.3
mreset bit p2.4
bitdata bit p2.5
gate bit p2.6
clock bit p2.7
sw_up bit p1.0
sw_down bit p1.1
sw_enter bit p1.2
sw_speed bit p1.3
sw_pause bit p1.4
sw_reverse bit p1.5
sw_negative bit p1.6
sw_mode bit p1.7
;40H dia chi bit nam o 28H
bit_sw bit 40H
bit_pause bit 41H
bit_reverse bit 42H
bit_negative bit 43H
bit_mode bit 44H
bit_speed bit 45H
bit_up bit 46H
bit_down bit 47H
bit_change bit 48H
chòi! đây là chương trình hay là tiếng Campuchia???
Ai mà có time đọc được chắc cũng là...người Campuchia
Không biết giữa viết bằng C và assembly thì cái nào hay hơn nhỉ??
sư huynh nào có phần mềm viết code và debug code assembly cho 8051 k?muạc đích là xem chương trình đó chạy như thế nào và các giá trị thanh ghi cũng như cổng I/O thay đổi như thế nào?
mình đã tìm rất nhiều nhưng chảng thây phần mềm chạy mã .ASM mà toàn mà .HEX!mình cần phần mình chạy trược tiếp mã .ASM!
Mình học Khoa Khoa học và kĩ thuật máy tính, ngành khoa học nên chẳng liên quan gì mấy con 8051... sao sao đấy. Thế mà cái môn Kiến trúc máy tính lại bắt học Assembly mới buồn chứ. Thầy thì múa phấn ở trên mà ở dưới SV gục ngã ~_~.
Đang có bài tập lớn: Viết chương trình C hiện thực giải thuật tìm kiếm nhị phân dùng đệ quy, sau đó chuyển chương trình này sang ngôn ngữ Assembly của MIPS ISA. Chương trình được test và chạy được trên MIPS Spim.
Mình trước học C++, giờ học C# không học C nhưng chắc tìm hiểu được. Nhưng còn mấy cái kia thì...mới nghe lần đầu. Bạn nào giúp được mình giải thích cái không? Cảm ơn lắm lắm!!!
rất tiếc cho chú là ASM có rất rất nhiều tập lệnh cho rất rất nhiều loại khác nhau .... mà mình ko biết (học ASM 8051 xong tính chơi sang ASM PIC mà đọc xong thấy có thanh ghi F nên làm biếng luôn hohoho)
Nói thế thì cũng như không. Ôi sao cuộc đời nghiệt ngã
P/S: I am not "chú". I'm a girl
Ha ha !
